Health & Fitness
Discuss any topics related to heath and fitness here. |
#41 |
Shoulders:
Standing military presses 1 x 90lbs 5 reps, 2 x 85lbs 6 reps Behind the neck presses 3 x 85lbs 6 reps rear delts 3 x 20lbs 10 reps side delts 3 x 25 lbs 8 reps close grip cable traps pull 3 x 60 8 reps reversed delts cable pulls 3 x 30lbs 10 Abs: planks 1 min x 2 |
#42 |
Took a week off for having the Flu. I feel like ****.
Back Deadlifts (smith machine): 1 x 3 250lbs 2 x 5 230lbs Behind bench head pull: 3 x 10 55lbs Weighted pull-ups: 1 x 8 with 30lbs plus 4 reps assisted with 3 sec pause on way down 1 x 6 with 30lbs with 3 sec pause 1 x 6 body weight with 3 sec pause chin-ups 2 x 6 with 30lbs 1 x 10 with body weight only Abs Planks 1 min x 2 Last edited by z00; 01-13-2013 at 08:54 PM. |
#43 |
Chest
Incline DB Press - 1 x 6 65lbs, 2 x 8 60lbs DB Bench Press - 2 set of 65lbs X 8 and 1 x 8 60lbs Dips 1 x 12 reps, 2 x 10 reps with 40lbs Pushups 3 x 6 with 40lbs high Cable flies 3 x 10 25lbs Abs: 2 planks for 30 sec with 40lbs weights 2 x 15 leg-ups |
#44 |
Legs:
No more smith machine. Screw my old gym. Front squats: 3 x 5 135lbs Back squats: 3 x 6 165lbs Leg Presses: 3 x 20 90lbs Superset with Calves 3 x 20 90lbs Ham extentions: 3 x 8 160lbs |
#45 |
glad we bullied you into switching!
#46 |
Glad I listened.
I talked to my old gym's manager and asked about racks. He said they don't plan to have racks even after renovation is completed because some people had hurt themselves. I asked him to cancel my membership. He tried to convince me to use dumbbells for DLs and that racks are only needed if I plan to do power lifting and competition. What a dumbass. |
#47 |
#48 |
Shoulders
seated DB press 2 x 5 50lbs, 1 x 7 50lbs side laterals with palms back, 3 x 10 10lbs front raises 3 x 8 25lbs cable rear delts 3 x 10 20lbs wide upright rows 3 x 8 60lbs shurgs 3 x 10 90lbs Bis: seated DB curls 3 x 8 35lbs |
#49 |
Back
DL 2 x 5 225lbs, 1 x 6 225lbs T-bar rows 3 x 8 100lbs Hammer low rows 3 x 8 210lbs pull-ups x 6 body weight chin-ups x 8 body weight 21's 1 x 135lbs (7, wide grip, close grip palms in, close grip palms out) |
#50 |
Chest
DB Bench Press - 2 set of 65lbs X 7 and 1 x 6 70lbs Incline DB Press - 1 x 6 65lbs, 2 x 7 60lbs Dips 1 x 12, 1 x 10 with 40lbs, 1 x 9 with 35lbs Pushups 1 x 8, 1 x 6 with 40lbs, 1 x 5 with 35lbs high Cable flies 3 x 10 40lbs each handle Abs: 1 planks for 30 sec 2 x 15 leg-ups I need to do something different for chest. I don't bench. Should I? Or what else? |
#51 |
AKA....X5_Scribe
My Ride: X5/M3/848/128i
You need more intensity in your workouts man. What you're doing is like a warm-up!
#52 |
Like what? A complete example would be great especially for legs and chest.
I think after you helped me with back it's ok, and shoulder day is ok as well. I'm doing 4 exercises per muscle group with low reps and heavy weights. Most splits I have researched have the same structure. What am I missing? |
#53 | |
#54 | |
3x5 squats 3x10 lunges each leg 3x8 Leg Press 3x8 romanian deads 3x15 calf bull sh1t This can all be debated and mixed and matched a million different ways. If you're having trouble moving up and down stairs when you're done then you did a good job. |
#55 |
I read so many debates on bench vs dumbbells. DBs seemed the better exercise overall. Am I missing something by not doing barbell presses?
I already do exactly what you do except for barbell but less volume than you. 3 sets, 4 exercises, finish with push ups. How can I make it more intense? I already can barely move my arms when I'm done. For legs, front squats, back squats, lounges, stiff deadlifts, calf. 3 sets of each excluding warm up. My legs would be sore for days after that. Last edited by z00; 01-25-2013 at 09:27 AM. |
#56 | |
And barbell bench will result in making your overall more powerful. DB's isolate a little better I think so I do both right now. |
#57 | |
AKA....X5_Scribe
P.S. z00....add more volume. You're not going to grow doing it the way you're doing it.
#58 |
Details bro, volume? What to increase in this?
DB Bench Press - 2 set of 65lbs X 7 and 1 x 6 70lbs Incline DB Press - 1 x 6 65lbs, 2 x 7 60lbs Dips 1 x 12, 1 x 10 with 40lbs, 1 x 9 with 35lbs Pushups 1 x 8, 1 x 6 with 40lbs, 1 x 5 with 35lbs high Cable flies 3 x 10 40lbs each handle -PS I'll swap flat DB press to barbell, but I won't lift as heavy as I don't have a spotter. |
#59 | |
AKA....X5_Scribe
Flat bench - 5 sets/varying weight Incline bench superset with Incline DB - 5 sets/varying weight Cable flies - 5 sets/varying weight Dips - 5 sets varying weight Try to get at least 40-50 reps (..not including warm-up sets ) during each of those 5 sets per exercise. Increase your time under tension. Force your body to grow and adapt. Right now you're getting 40 total reps over two press exercises. NOT ENOUGH!!! You'll get 80-100 reps over the course of your press workout by adding volume. Huge difference!
#60 | |
Supersetting incline bench BB with incline DB means I won't be lifting heavy. So reduce the weights and increase reps? I'll go heavy on the flat bench.
