Sponsored by BAVSOUND
Old 01-18-2013, 04:49 PM   #1
turbokid
My Ride: 2005 325i
Hey sub guys! What LOC did you use
Hey, I need to get a LOC for my setup but I want to make sure I get the right one. Some say adjustable, high to low converter ect...
What do I need, and what have you guys used that gives good sound.
Also if I do need an adjustable one, what do I "adjust" the settings to for optimal bass?
Appreciate the help.
Regards,
turbokid is offline   Reply With Quote
Old 01-18-2013, 10:21 PM   #2
albarran9
My Ride: E46, E53, E90
I'm currently using an LOC from Pac. It's been working great for getting RCA's for my amp form the rear speaker wires. I'm considering switching to an AudioControl LOC because they have models with built in line drivers that boost your RCA's output. I'd stick with a full frequency LOC and skip the adjustable ones, but that's just me. I let my crossovers do the work of splitting the low's for my subs and high's for my font components. For optimal bass it just depends on the sub/box combo you choose and how you set your amp settings. If you want good bass in your component speakers, clean power is key. With a good LOC form Pac or AudioControl paired with a nice amp should do.
albarran9 is offline   Reply With Quote
Old 01-18-2013, 11:36 PM   #3
Derek325
My Ride: 2001 325xi Touring
If you are just adding a sub to your factory system then the Audio Control LC2 would work well for you, and it has an optional sub level control.
Derek325 is offline   Reply With Quote
Old 01-19-2013, 06:14 AM   #4
turbokid
My Ride: 2005 325i
Yes this will be simply for a amp and single sub. A JL 700/1 v2 amp and JL 10w6 sub. Just want to make sure all of the sound is going to the sub, I had a different one that came with the car and the sub just sounds too quiet, so this time I want to make sure I get whats right.
Regards,
Old 01-19-2013, 04:41 PM   #5
ultimatemj
My Ride: 04 E46 M3
I don't see a 700/1v2 listed, but if this is slash v2 series amp (and you stil lhave the factory HU) you don't need to use a LOC...as they accept balanced differential inputs, which is what the BMW factory deck uses.
I disconnected my rear speakers and used the signal from the HU to feed my sub amp, to allow the fader to work as kind of a bass volume knob~
ultimatemj is offline   Reply With Quote
Old 01-19-2013, 05:16 PM   #6
turbokid
My Ride: 2005 325i
Ah damn, well I went ahead and got the LC2i. (maybe I'll return it?)
But now you have no rear speakers lol? Why not just T into them haha?
Thanks for the help guys!
Regards,
Old 01-20-2013, 08:16 PM   #7
ultimatemj
My Ride: 04 E46 M3
No need for rear speakers in a coupe
The way the "bass fade" works is because you are fading between vocals and sub to fine tune how much you thump.
That said, I find I rarely use it, so if you want to keep your rear speakers T'ing may be fine. I see the JL slash amps also sell a bass knob, so I'd T into the fronts and fade the rears to just lightly fill.
2cents~
Show us your results!
Old 01-21-2013, 09:46 AM   #8
turbokid
My Ride: 2005 325i
Will do, though I just decided to start looking for a M3 so I won't be installing all the gear I just bought into this car. Thanks for the input.
Regards,
Old 05-29-2013, 06:37 PM   #9
[w.b]
My Ride: 328ci
would you disconnect the rear tweeters too?
[w.b] is offline   Reply With Quote
