Old 01-19-2013, 04:31 PM   #1
Rad811
My Ride: E46
Key lock broken and battery flat!!!!
Hi,
I bought an e46 sedan today and knew that the car lock was broken. The key could just lock the car but i guess it was not charged enough as i could no longer open it now! ( A few hours after)
Any idea how i can re-open the car?
Many thanks in advance,
Rad811 is offline   Reply With Quote
Old 01-19-2013, 06:17 PM   #2
asma123
My Ride: E70x5 m3conv m3coupe
you can open your trunk with the key and put the seats down and get in that way
asma123 is offline   Reply With Quote
Old 01-19-2013, 08:17 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Open trunk and get battery charged or jump the car?
Ebay for the door lock repair parts.
www.bmwgm5.com for info in case your GM5 module is questionable.
A E46 with only 1 keyfob is a dangerous thing!
Old 01-20-2013, 04:30 AM   #4
Rad811
My Ride: E46
Thank you guys for the reply. But can the rear seats of an e46 sedan go down from the back?
Old 01-20-2013, 10:48 AM   #5
2003 325i
My Ride: '03 Orient Blue 325i
they can if you have fold down seats. They don't from inside the cabin.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 01-20-2013, 11:59 AM   #6
sgoetz628
My Ride: 2002 330 CiC
Does the ignition have to be on for the key to be charging, or could I just leave it in overnight? I don't like to use the 2nd keyfob, as all the settings are different. Also, do you recommend charging the 2nd keyfob from time to time?
thanks
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 01-20-2013, 12:00 PM   #7
2003 325i
definitely recharge second fob from time to time. I would think ignition would have to be on to charge the key but my bentley is at work so i'd have to see a wiring diagram (not sure if it's even in the manual).
Old 01-20-2013, 12:07 PM   #8
sgoetz628
Will do then. Thanks
Old 01-20-2013, 02:04 PM   #9
scottjoh
My Ride: '99 323i & '02 540i
The ignition needs to be in the Acc or On positions to charge the internal battery in the diamond keys. The key should be charged at the very least every 6 months for several hours.
scottjoh is offline   Reply With Quote
Old 01-20-2013, 04:00 PM   #10
jfoj
The settings are not stored in the keyfob, they are in car memory.
If you save your seat position the same for position 1 & 2 and set all other things the same then you will not see a difference between the keyfobs.
Old 01-20-2013, 05:15 PM   #11
scottjoh
That is true. If you don't want the setting from the 2nd key to change the seat, mirror, etc then open the car with the key in the door instead of with the remote (the car won't know which key was used and therefore won't change anything.)
Old 01-20-2013, 06:13 PM   #12
jfoj
I think??? depending on how the car is coded, that radio station presets and climate control settings can be stored as well. Or at least the last climate control settings that were used may be recalled when the key is used?
It can be a bit of a PITA to get sorted, but as long as you are the sole driver it should not be too big of an issue.
Old 01-20-2013, 09:57 PM   #13
sgoetz628
First off, sorry to hijack the thread. Secondly, thanks for the advice. Great to learn new things about my car - even 10 years after!
Old 01-21-2013, 09:49 AM   #14
04-330ci-ny
My Ride: 2004 330Ci
FYI I've been locked out like that once and I called AAA to come open the car. The guy used one of those airbag wedges to get the driver door open enough to stick a metal rod in and and hit unlock.
To our surprise when he hit the button the car deadbolted into some sort of security mode. (apparently this has to do with a weight sensor in the seat recognizing that there's no one in the seat) He ended up leaving but I later discovered you have to hit the button multiple times and also lasso the drivers side door handle to get it.
I'm not sure the exact sequence but it was something like unlock button (center console) then lasso door and pull then unlock again..if anyone knows the exact sequence for the e46 security system it might be worth posting!
04-330ci-ny is offline   Reply With Quote
Old 01-21-2013, 10:21 AM   #15
jfoj
Some year cars might behave slight different, usually you need to push the center console button once, the pull the door handle.
Old 01-21-2013, 01:14 PM   #16
04-330ci-ny
My Ride: 2004 330Ci
Yeah I read that everywhere but beware on the 04 330Ci it's two unlocks...not sure what other models have this too
