Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 01-19-2013, 11:47 AM   #941
Stinger9
My Ride: '04 330Ci
Bottom RIGHT hose has the coolant temp sensor on it. Learn this stuff well so we know what you are talking about.
Did you lube well?
Remove, clean, reposition O-ring, lube and retry.
Full system does not do what you need. Sorry, you need to drain.
I'd not leave my car where yours is now.
Old 01-19-2013, 11:53 AM   #942
caleb6
My Ride: 2005 330XI
Did you lube well?
left from front looking down. right from drivers seat. sorry, is the drivers position the correct reference for all directions all the time?
caleb6 is offline   Reply With Quote
Old 01-19-2013, 12:20 PM   #943
Stinger9
My Ride: '04 330Ci
yes
Old 01-20-2013, 02:22 PM   #944
caleb6
My Ride: 2005 330XI
so i drained and pulled the RIGHT side hose off the radiator. I put it back on, it snapped into place and I locked it down. Still looks ever so canted - not much better then before. I'm going to run it like this for a few days, keeping a close eye on it, and see how it goes.
I mean it's locked into place - could have just been loose the first time, then residue coolant leaking out around the next few times I checked. We'll see.
Old 01-21-2013, 06:30 PM   #945
Fabe330ci
My Ride: 2007 328i coupe
I will have to add this(since it is my problem now)the LOWER RADIATOR HOSE TEMPERATURE SENSOR COOLANT!,I have a 2003 330ci A/T,the dash was constantly showing the lower coolant level warning light..it was hard to find,but today showed it was the culprit,the o ring in this sensor degraded and allowed a small amount of coolant to drip....my two cent here!
Fabe330ci is offline   Reply With Quote
Old 01-21-2013, 08:32 PM   #946
Stinger9
My Ride: '04 330Ci
Clarification please.
Which are you talking about?
The low coolant level sensor has no O-ring.
The sensor on the lower hose is not a level sensor.
Old 01-21-2013, 09:30 PM   #947
///MPR77
My Ride: 02 ///M3 Tri-Ped
+1
Level sensor (Bottom of ET)will report to the low coolant "mango lightŪ", and has no O ring.
Fan switch/Temp sensor on lower hose has an O ring, if you have a leak here the level at the ET diminishes, and triggers the low coolant light...followed by overheating.
Regardless, glad you sorted it out.
Old 01-21-2013, 10:03 PM   #948
Fabe330ci
The sensor i'm talking about is located at one of the ends of the lower radiator hose,that fan switch sensor has an o-ring/seal,once the seal goes bad,coolant starts dripping from the sensor's housing,thus the coolant level decreases and then triggers the colant level sensor...makes sense now?
Old 01-21-2013, 10:05 PM   #949
Stinger9
My Ride: '04 330Ci
...makes sense now?
Yes
Everyone replaces this sensor with O-ring when they replace the lower coolant hose.
Old 01-21-2013, 10:18 PM   #950
GroggyCarpet
My Ride: 2004 325i
Its a good kit, I just used the kit from pelicanparts.com which came with all the necessary and is around $400. I added a new oem expansion tank, Ac belt, and idler pulley. Total was around 520.
*no radiator included.
Radiator is approx an additional 200
Sent from my SAMSUNG-SGH-I747 using Bimmer App
GroggyCarpet is offline   Reply With Quote
Old 01-21-2013, 10:20 PM   #951
GroggyCarpet
My Ride: 2004 325i
Ps. It comes with the o ring!
Old 01-21-2013, 10:31 PM   #952
Stinger9
My Ride: '04 330Ci
$400 with no radiator or ET doesn't sound too competitive.
And new oe rad is under $150
Can edit posts.
Old 01-23-2013, 04:42 PM   #953
7xWDC-MSC
My Ride: 2005 325xi
Mango, I know you had been looking for the TIS bleeding instructions for our E46 M54's I just got the TIS so I screen printed it.
Rubs the roundel on its skin or else it gets the hose again.
7xWDC-MSC is offline   Reply With Quote
Old 01-23-2013, 04:58 PM   #954
My Ride: Lexus
awesome.good stuff
Old 01-28-2013, 01:29 PM   #955
SeattleLSB
My Ride: 2003 330XI, 2003 M3
Can I ask you a question about the bleeding TIS. Should we put the car on ramps before we remove everything? How do I move it to ramps once I have no coolant? Trying to figure out the best way.
Thanks,Joe
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 01-28-2013, 01:29 PM   #956
SeattleLSB
Thanks,Joe
Old 01-28-2013, 02:01 PM   #957
Stinger9
My Ride: '04 330Ci
I did my cooling system refresh starting out on ramps and kept it there for the whole job. No need to bleed until you're back on level ground.
Old 01-29-2013, 03:09 PM   #958
SeattleLSB
Can anyone confirm the washer for the block is copper and not silver? The one I received from BMA parts is copper per the part # from Mango.
Old 01-29-2013, 03:16 PM   #959
Stinger9
My Ride: '04 330Ci
I have no doubt that the washer you received will work just fine.
As long as it fits the plug, use it and relax.
Old 01-29-2013, 03:56 PM   #960
7xWDC-MSC
My Ride: 2005 325xi
The ETK does in fact call for aluminum, but I don't see why copper couldn't be used in place.There isn't anything in the cooling system that will eat copper.
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
