///M3 Forum
Old 01-20-2013, 04:52 AM   #1
mango79
My Ride: E46
Exclamation car wont start up //SMG problem - help please
hello everyone,
last summer while I'm parking to get somthing from the shop I heard some noise and the car has stopped I tried to start it again but it wont. I had to rent car to pull it and I found some oil beneth it .
Please any one has the same issue now the transmission light is on and it wont start any more
BMW E46 /2006
mango79 is offline   Reply With Quote
Old 01-20-2013, 06:52 PM   #2
illestminimike
My Ride: Project Drama
Salmon relay. Search it.
Old 01-20-2013, 09:57 PM   #3
NICKBRUM
My Ride: 2004 M3
Yes search function is your friend. With that being said the DME cover is the black plastic lid in the engine bay upper left corner. Remove the torx and the relay is there its the pink" salmon"colored one.
Current:
2006 E46 M3 ZCP silver gray on black SMG
|Stoptech BBK ST40 X 355mm| Style 219 wheels|
|Ceramic coated euro headers| Custom 200 cell section 1|
|TTFS Motor & SMG tune, 315 whp| GC coil overs |
Previous: Totaled
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|CSL/SMG Flash|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|PFC DD Front Rotors|
NICKBRUM is offline   Reply With Quote
Old 01-21-2013, 03:28 AM   #4
mango79
My Ride: E46
this is good news I hope this is the problem, any one know the part number for this relay it will be helpful information. thanks
Old 01-21-2013, 10:34 AM   #5
NICKBRUM
My Ride: 2004 M3
I threw you a bone already. Use the search function here or on Google.
Current:
Previous: Totaled
Old 01-21-2013, 04:28 PM   #6
///mteknikk
My Ride: 02 E46 M3
heres the part # 12631742690
and heres the link to the website that sells it
http://www.ecstuning.com/BMW-E46-M3-...ssion/ES31912/
///mteknikk is offline   Reply With Quote
Old 01-23-2013, 02:51 AM   #7
mango79
My Ride: E46
thanks all I will try it and let you know soon...
Old 03-08-2013, 04:04 PM   #8
mango79
My Ride: E46
here is the update I bought the Salmon relay, changed it and nothing happened . but I notice SMG oil tank is almost empty and the gears lamp is on on left side.
ID:	494558   Click image for larger version
ID:	494559   Click image for larger version
Old 03-08-2013, 08:57 PM   #9
$ilent ///M
My Ride: 03.5 M3 smg lsb
Then you have a leak some where in your system, try and put it on a lift and trace the leak
$ilent ///M is offline   Reply With Quote
Old 03-10-2013, 03:56 AM   #10
mango79
My Ride: E46
Thanks but is that mean if I add some oil it will start again ?
Old 03-10-2013, 12:05 PM   #11
$ilent ///M
You may have air in the system. but you could try just cycle the gears a few times although you wiil need to hook it up to a machine to get it bled properly
Old 03-13-2013, 07:55 AM   #12
mango79
My Ride: E46
latest update : added some fresh oil CHF 11S the car still not starting. Is there some sensor detect that oil is min or system need to be reset ?
Old 03-13-2013, 08:25 AM   #13
$ilent ///M
Are you able to cycle the gears? R-N-1-2 without starting can you hear the pump working if you can?
Old 03-14-2013, 02:55 AM   #14
mango79
My Ride: E46
There is some noise when starting the first time but I'm not sure if it belongs to SMG Pump or Patrol Pump. yes I remember I tried to cycle N-1-2 there were fine
