Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 01-20-2013, 10:44 PM   #181
MarcusLSB
My Ride: BMW's
Originally Posted by wanganstyle View Post
What did you change up the diff to? Can the m-variable unit even handle the power? I wonder how close to the 4b motorsports drag full race car your street can get- david ran around 9.2/159mph with irs and built up stock diff I setup.
As low as 2.65 ratio is avail to fit the 210mm with ability to configure high lock clutch LSD. I'm still waiting on that s54 block/crank from my friend: do you still need one?
I'm running an OS Giken diff right now with a Motorsports 24 solid billet cover (no bushings). I'll likely see better times with a 2.xx r&p but right now I'm going to see what the stock gearing will do.
I might be interested in that S54 if you still have it. I've got extra trannys and blocks already but what I could really use would be a extra crank or two.
Originally Posted by evilstar View Post
So does that mean the bet with chris is off for mfest?
Still on if the car is done in time.. I have the tendency of surprising people.. so I'm sure it will be there with bells on.
Originally Posted by InDiGlOM3 View Post
Something unbalanced in the motor? Who has built it these four times?
Sent from my PG86100 using Bimmer App
I've replaced the flywheel, etc.. multiple times.. something is unbalanced somewhere.. the flywheel bolts keep backing out. I've replaced the drive shaft, with a solid one piece, and a new 2 piece.. after 1000mi the flywheel bolts are literally falling out.
It happened once in vegas.. didn't think much of it.. assumed it was installation error or a locktite issue, etc.. pulled it, put it back in.. i got home.. started doing it again.. i pulled the flywheel/clutch, reinstalled with a new flywheel and new bolts, etc.. did it again at almost exactly 1000mi.. now here we are .. so I guess its done it 3 times then.. regardless something is unablanced somewhere.. when the bolts backed out the first time one sheered and ****ed up the crank snout...
Unrelated but I did a compression test on the motor.. it solid across the board.. Saad built one beast of a motor, that's for sure. I've done nothing but beat on it since we got done with it back in April.
Originally Posted by Commanderwiggin View Post
Still on...cept it's gonna be good ol blue doing the 6MT job
Indeed I'm bringing a knife to a gun fight but, regardless I'm not going to back down.
youtube.com/marcuslsb -- Photography by Gheybe!
Old 01-20-2013, 11:05 PM   #182
wanganstyle
My Ride: 1998 e36 M3
Os Giken is great: I use them also but more for roadcourse/drift cars
With the os giken L1 you are using the lowest ratio that will fit is 3,15- the flange offset for lower ratios is different
I'll keep my eyes out for a crankshaft for you- are you killing harmonic dampers? Stock damper or ati?
Do you think the flywheel bolts backing out is damper related?
Sent from my GT-N7100 using Bimmer App
Billet LSD retrofit to E46&E39 NON-M
http://forum.e46fanatics.com/showthread.php?p=14989087
S54B32 E36 1997 M3 Sedan Street car swap + DTA S100:
http://forums.bimmerforums.com/forum....php?t=1437471
1987 E30 + 2006 e46 320D ZF 37DZ- 6 speed conversion
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 01-20-2013, 11:16 PM   #183
MarcusLSB
My Ride: BMW's
With the os giken m1 unit you are using the lowest ratio that will fit is 3,15- the flange offset for lower ratios is different
Could be damper related.. I was considering switching to an ATI. But now that my snout on my crank is all mauled up I'm sure its only adding to the issues..
Right now I have to pull the tranny again, check everything out, retighten the bolts, and if I wanted to I could swap to the ati balancer and reassemble.. put another 1000mi on it and see what happens..
When the bolts start to back out I literally have about 10mi before the come completely out. Everything sounds/behaves normal.. then within about 10 miles it deteriorates FAST. Right now its within the first mile or two of me noticing the issue.. haven't disassembled it yet.
Old 01-21-2013, 12:47 AM   #184
evilstar
My Ride: 633csi & 325i
Well im keeping my fingers crossed for you but it's going to be real tough going up against the drag car.
evilstar is online now   Reply With Quote
Old 01-21-2013, 01:13 PM   #185
InDiGlOM3
My Ride: HPF M3 stg 2.5
How are you locking the motor to tighten flywheel bolts? And what tq are you going to, sequence etc.
InDiGlOM3 is online now   Reply With Quote
Old 01-21-2013, 01:59 PM   #186
MarcusLSB
My Ride: BMW's
BMW TDC Locking Pin and following the torque/pattern instructions that came with the OS Giken clutch/flywheel.
Old 01-21-2013, 02:34 PM   #187
E85head
My Ride: E46 M3
If you win... It will be the most impressive thing in racing history since John Britten made his own motorcycle in his basement beating Ducati! lol
E85head is online now   Reply With Quote
Old 01-21-2013, 02:45 PM   #188
Commanderwiggin
My Ride: 800rwhp Turbo M3
The drag car has been mia for a very long time...I wouldn't be worried.
Old 01-21-2013, 02:46 PM   #189
MarcusLSB
My Ride: BMW's
I don't know about that! Lol. If I built a second drag car, from scratch. But I just don't have time for it. I've had help with this car from every vendor, Saad, ProEFI, FSR and even HPF. I've done some on my own but most has been with some assistance.
Old 01-21-2013, 02:50 PM   #190
MarcusLSB
My Ride: BMW's
Last we saw of it, it ran a 10.2 I think, which would beat my 10.56. So I've got quite a bit to do to get to my car to a 10.1 or better and I'm sure Chris isn't sitting on his laurels, but I also know he's been distracted with other stuff. Should be interesting if we both make it.
Old 01-21-2013, 03:41 PM   #191
wanganstyle
I have a known good oem damper here from my own car that was only used with stock dual mass that you are welcome to try using or compare your current stock unit to if you would like- would be my hunch that the damper may be on the way out and sending pulses to terminate on the bolts. Did you ask OSG engineers if they have experienced similar?
I Have ran OSG clutch on japanese cars without any vibration/bolts issues
Old 01-21-2013, 03:42 PM   #192
MarcusLSB
My Ride: BMW's
No, but I should. However if I'm going to go to the trouble I figure I might as well throw an ATI on there.
I heard some people say that if the issue ISN'T with the balancer the ATI could make the situation worse. Not sure if thats true or not.
Old 01-21-2013, 03:45 PM   #193
wanganstyle
I would first try a diffent stock damper or a brand new one before ati- some ati units have failed miserably in track use conditions with relatively standard s54 engines
Is your crankshaft a standard unit or offset ground for more stroke?
Old 01-21-2013, 03:48 PM   #194
MarcusLSB
My Ride: BMW's
Thanks for the tip!
Btw, is your block/crank still at your house? If so I'll pick it up from you in a few weeks. I still have the axles sitting here waiting to send them to DSS.. been so dang busy.
I'll head over to BMW and order a new stock damper.
Old 01-21-2013, 03:51 PM   #195
wanganstyle
Thanks for the tip!
Its at my friends about an hour and half south, been meaning to pick it up 4th quarter 2012 but got swamped w work and now am overseas on family biz (funeral). Will let you know when I pick it up- probably late feb early march-
Id order a brand new oem bmw damper and see if there is any delamination on the current unit from heat etc
Old 01-21-2013, 03:54 PM   #196
MarcusLSB
My Ride: BMW's
My car has about 50k miles on it.. if the damper shows excessive signs of delamination or a split wouldn't that be a sign that something in the motor (or rotating assembly) is off balance causing excessive heat and vibration that the damper is attempting to counteract.
You know I live about an hour south of you, so if you want me to pick it up before Feb/Mar I can.
Sorry about your loss, my grandmother passed yesterday and I'll be traveling all this week for the service/funeral/etc.
Old 01-21-2013, 04:02 PM   #197
wanganstyle
Thank you
I need to visit some friends down south anyways, hopefully all will fall in place when I return. Rip and my condolences to your family also, has been a really big family time for me
Failure at ~50k area is unusual but not unheard of. Usually they fail on track race cars with elevated redlines and light weight single mass flywheels- im pretty sure the thrust of acceleration of the turbocharged power is also stressful for it.
Old 01-21-2013, 05:32 PM   #198
Twin_Turbo_S54
My Ride: M3
I was able to use 2,65 / 2,81 / 2,93 / 3,07 with OS LSD.
8 seconds 1/4 mile & sub 3 seconds 60-130 mph AWD M3X coming soon
4,23 s 60-130 mph E46 M3 TT
4,49 s 60-130 mph E36 M3 TT, 3,49 s coming soon RWD mode
8,45 s 60-130 mph 997 Turbo
Twin_Turbo_S54 is offline   Reply With Quote
Old 01-21-2013, 05:36 PM   #199
Commanderwiggin
Which one was your favorite?
Old 01-21-2013, 05:37 PM   #200
Twin_Turbo_S54
My Ride: M3
Marcus,
May God save your grandmother.
Regarding your bolt issues:
I am still on oem vib damper.
1- check the tightening specs on the bolts.
2- get your flyheel balanced, just a precaution. It may be off balance.
