Old 04-28-2012, 02:05 PM   #1
Weste46
My Ride: 2001 330ci
PA Soft EU2 Tuning DIY?
I recieved my BMW Scanner 1.4.0 from xcar360 today to delete my DRL's, but I also have a "hunting idle" while going into neutral occasionally. I'm going to be replacing some suspects of the cause, but I thought it may be wise to do the EU2 scan while I can.
Is there a specific DIY on the EU2 tune with this scanner? I've seen where it's located but I don't want to screw anything up. I keep seeing posts about flashing adaptations and such, and just want to know exactly how I should go about doing this.
Any help would be great. Thanks!
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 01-22-2013, 02:49 AM   #2
E46Snowball
My Ride: 330i
http://forum.e46fanatics.com/showthread.php?t=898241 in This thread a few posts down there is a diy.
2003 330i
Imola Red
Zhp Package
6 speed
E46Snowball is offline   Reply With Quote
Old 01-22-2013, 08:57 AM   #3
Weste46
My Ride: 2001 330ci
Thanks a lot!!
Sent from my DROID RAZR MAXX
Old 01-22-2013, 09:15 AM   #4
Guest021715
Account closed.
The EU2 tune is not done with PA Soft, as you'll read in the thread posted.
Old 01-22-2013, 12:12 PM   #5
Weste46
My Ride: 2001 330ci
Yup, gotcha. Can the same chord be used for both?
Old 01-22-2013, 01:05 PM   #6
trj
My Ride: 325Ci
No.
I think AC answered both of the questions you asked on that thread to me.
lol.
PA soft cant load the EU tune, nor can the cable used for the same purpose.
Buy a modified vag-com cable for around $14 on ebay and try loading the programs yourself if you are feeling adventurous.
Old 01-22-2013, 01:43 PM   #7
Weste46
My Ride: 2001 330ci
Originally Posted by trj View Post
No.
lol.
Alrighty thanks a lot!
Old 01-22-2013, 10:42 PM   #8
Weste46
My Ride: 2001 330ci
Just ordered the cable with software from where the OP of that thread ordered from!
Old 05-12-2016, 06:05 AM   #9
Weste46
My Ride: 2001 330ci
I was never able to get the software operational on Windows 8.1, so it might be more difficult for me to try on Windows 10 now that I've gotten a new computer, but I will try again. Definitely need to change my idle and am hoping PA Soft will allow me.
Does anyone know if it allows idle adjustment?
Thank you.
Edit: disregard, I should be asking in the other software post.
Old 11-25-2016, 06:34 PM   #10
evanr614
My Ride: 2000 328Ci
well got around to finding a cable that works, opened winkpf, entered desired ZUSB (7528722 for EU2) clicked program, took about 2 minutes with no error prompts, "programming ok" prompt comes up and i press ok and that was it. my check engine light is off now, and i have no rear o2's hooked up, but when i go to identification in INPA it has my old dme number listed still, not the EU2 number. it was also weird how quick the flash was. the car is running perfectly and took it for a 5-10 minute drive with no problems. kind of confused but it appears to have worked...anyone have any ideas as to whats going on?
put the car into cat prep mode with no problems...
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is online now   Reply With Quote
Old 12-08-2016, 02:07 AM   #11
evanr614
My Ride: 2000 328Ci
anyone have a clue why the assembly number never changed? why the flash only took 2 minutes?
i noticed the other day my electric fan was blowing on full blast for some reason until i restarted the car, the idle dropped a little bit with this...pretty weird
Old 12-08-2016, 09:45 AM   #12
GhostFlame
My Ride: E46 Sedan
I can't confirm for sure, but I've experienced the same 2min flash for a later model E46.
It probably depends on your base coding - what's there / what's missing.
Same situation with the DME version being reported. Doesn't bother me.
I took that same car to an indy for a transmission software update.
Their professional equipment was able to determine I did indeed have the latest DME flash.
GhostFlame is offline   Reply With Quote
Old 12-08-2016, 11:32 AM   #13
evanr614
My Ride: 2000 328Ci
It doesn't bother me either really, since it was my first time flashing anything it just made me a little uneasy. So you're saying it's most likely not a problem...
