Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 01-21-2013, 11:29 PM   #15201
trj
My Ride: 325Ci
Fixed my exterior door handle. The handle had been out for 2 weeks.
Had to remove window, guides and the exterior handle actuator. What a pain. Hopefully it will never come out again.
Old 01-22-2013, 12:18 AM   #15202
trentcdrums
My Ride: BMW 323i Sedan
Originally Posted by NFSx328ci View Post
Parked my car in the garage. Snow=suck
Really? I want snow!
Old 01-22-2013, 02:05 AM   #15203
CK325
My Ride: 323Ci, 325xi
got some stored codes read, got an inspection, toyed with a some faulty turn signal issue.
next on the list; window regulator. hopefully the easy zip tie fix will do the job.
CK325 is offline   Reply With Quote
Old 01-22-2013, 02:14 AM   #15204
NightRaider93
My Ride: 2007 Z4 Coupe
Fixed my rattling exhaust with a $7 AutoZone fix.
-Spencer
NightRaider93 is offline   Reply With Quote
Old 01-22-2013, 03:34 AM   #15205
My Ride: 2016 Lexus
Originally Posted by WDE46 View Post
I have yet to see another clean E46 in my area. I plan to be the only one. Hahaha. The CSL wheels are overplayed in the showroom but there isn't a car within 50 miles of me that has them.
There's at least two within 20 yards at home and at work with CSL wheels. That's so cal for ya
I think I may end up with some K1s or better yet LTW5s for their weight advantages. CSLs look nice but i've only seen one quality rep. dont feel like going to 18s...
Old 01-22-2013, 11:29 AM   #15206
Kracingti
My Ride: E46 320i Touring 02
I need HELP..!!!!
I need to find how to install the camshafts, head gears and chains in my 320i to set the timing up. It got overheated And now I have to replace the head gasket. I know there are some tools to do this job and donīt get lost in the set up.
Do you know where can I find more information? I have searched but may be I am not using the correct words...
Thank you..!!
http://www.dadooda.com/uploads/images/26444.jpg
Kracingti is offline   Reply With Quote
Old 01-22-2013, 11:33 AM   #15207
My Ride: 2016 Lexus
Originally Posted by Kracingti View Post
I need HELP..!!!!
Thank you..!!
Just curious. Why/how did you overheat? I think I've seen you around before.. did you not heed my warnings about overheating?
Old 01-22-2013, 12:08 PM   #15208
Kracingti
Yesss... I know... my fault...
Days before I replaced the water tank, and the bottom O-ring was worn... I just added some silicone hi-temp to seal it. But guess what... it started to leak and I just refill until I get the o-ring to be replaced. But I think that day I did not purge it well and it hit the 125°C (262°F) without throwing any "low level" warning in the dash... I just saw the needle in the RED zone and I stopped the car...
Now it throw the compresion by the water tank... so we need to replace the head gasket and resurface the head. I just got an oversized thickness head gasket to be replaced.
Old 01-22-2013, 12:22 PM   #15209
My Ride: 2016 Lexus
Be careful cause the threads in block might strip. are you reusing the holes or putting inserts?
Old 01-22-2013, 12:31 PM   #15210
WDE46
My Ride: 2004 330Ci OBM
Did you compression test it? How did you verify your head gasket is blown and the head is warped.
Old 01-22-2013, 12:43 PM   #15211
limpiabota809
My Ride: 330 XI
I used to have black grills (I might give them away) but went back to stock.
http://forum.e46fanatics.com/showthread.php?t=918180
ill take them off your hands ill pay the shipping mago
limpiabota809 is offline   Reply With Quote
Old 01-22-2013, 12:47 PM   #15212
Kracingti
Yeah... I was aware of the threads, but we will go "in god we trust" way...
I was thinking in reuse the holes and get new bolts for it.
Is there a "safe" way to out them off? What you mean with inserts?
Old 01-22-2013, 12:51 PM   #15213
My Ride: 2016 Lexus
Sorry I was gonna have some kind of contest. might as well be entertained. gotta earn it son! did you even vote for me??
Old 01-22-2013, 12:52 PM   #15214
Kracingti
Because you can feel and even see the water coming out from the expansion tank. And when you add water the idle comes very rough...
I think those are symptoms of a blown gasket and warped head doesn't it?
Old 01-22-2013, 01:06 PM   #15215
My Ride: 2016 Lexus
leakdown test. listen and look for air in the coolant or theres a chemical test too for th coolant that detects combustion gases
Old 01-22-2013, 01:14 PM   #15216
Kracingti
Yes, there was a lot of air... before I first opened the tank cap, I screw the aside stud and it seems an air compresor... lot of air.
Any recommendation to avoid strip the threads??
Old 01-22-2013, 01:23 PM   #15217
WDE46
Be prepared to strip threads. Learn how to put in time serts and have them on hand. Anyway, you should do an actual compression test first, but those symptoms you list are suspicious.
Old 01-22-2013, 01:34 PM   #15218
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Hmm, seems like my car is misfiring... Pulled up a code for cylinder 3. Cleared it so we'll see if it comes back.
I have to go to my parts guy to pick up some parts today anyways (cabin and oil filter, new wiper blades, coolant)
Old 01-22-2013, 01:40 PM   #15219
My Ride: 2016 Lexus
you know the drill. swap coils, see if follow. if not, injector or plug. or the dme is misinterpreting another misfire or rough running condition for cylinder 3??
Old 01-22-2013, 02:11 PM   #15220
Solidjake
Zero. Leaks.
Solidjake's Avatar
I will do that probably tomorrow. way too cold today to be playing around outside.
Rate This Thread
