Sponsored by BAVSOUND
Old 01-22-2013, 01:16 PM   #1
hizhinezz
My Ride: 01 330i
Best amp and setup for sub and HK audio
I have found numerous threads with some of this info, but forgive me for asking anew: (if you know the best thread please just link, much appreciated)
I am going with JL Audio setup as clearly is preferred fro easy install... adding sub to stock HK system in 2001 330.
1. What do people think is the best JL audio amp for pairing with a JL W1 12" Subwoofer?
2. What is the ideal setup in terms of install/wire placement? (insert link, lol)
3. What do people see as ideal setup for optimal sound?
Basically just looking for opinions on which JL amp to go with, then the links to the install/setup info... couldn't find one specific to this model...
Thanks!
hizhinezz is offline   Reply With Quote
Old 01-23-2013, 08:14 PM   #2
hizhinezz
My Ride: 01 330i
nobody?
Old 01-26-2013, 10:15 PM   #3
Arfboy
My Ride: 04 M3
1. I doubt you'll see much difference in the various JL amps in terms of SQ and that's not a power-hungry sub, so I'd just go with the XD300/1 (assuming you're set on JL amps).
2. Your wire placement would really depend on where you mount your sub enclosure and amp. However, it shouldn't be too much work, seeing as how all the wiring is already in your trunk. You'll just tap into the HK amp harness for your remote and for the signal out to a line out converter. I'll PM you a few links to get you started.
3. There's only so much you can do with the stock setup without gutting it and starting from scratch. A simple amp/sub addition will help fill in the lower end nicely, but you're still limited by the factory system components.
Arfboy is offline   Reply With Quote
Old 01-27-2013, 05:30 PM   #4
Grande D
My Ride: E36 M3
What he said ^^
It will change your life!
Old 01-28-2013, 01:43 AM   #5
eJack
My Ride: 2004 330Ci ZHP
I have a 500/1 sub amp with a 300/2 stacked with their STACK-KIT-2. The STACK-KIT-2 is unfortunately discontinued but their -3 kit should easily be used with spacers in between. The BMW Business CD interfaces directly quite nicely with the JL audio amps and sounds fabulous. I'm sorry I did not cut the harness and do this many years ago. The HK amp is shameful.
Happy Listening!
eJack
2004 330Ci ZHP
BMW Performance Style 269 Wheels
BMW Performance Carbon Fiber Strut Brace
THIEL Audio PowerPlane Loudspeakers
THIEL Audio 12" Subwoofer
JL Audio Slash 300/2v2 Stereo Amplifier
JL Audio Slash 500/1v2 Sub Amplifier
USA Spec PA-12 iPod Interface
BMW Business CD stock head unit - yes it sounds great once you disconnect that garbage H/K amp!
eJack is offline   Reply With Quote
Old 01-29-2013, 02:12 PM   #6
hizhinezz
My Ride: 01 330i
I got a used JL 500 amp and will attempt install this weekend. Thanks for all the helpful info (especially arfboy for sending links etc). Cannot wait for bass in face.
