Thread Tools Search this Thread Rating: Thread Rating: 39 votes, 4.90 average. Display Modes
Old 01-04-2013, 09:19 PM   #561
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Very nice. You're going to love the car.
Old 01-04-2013, 09:31 PM   #562
///Mvious
My Ride: E46 330
Now if all that only showed up on my front porch! Lookin fwd to the install, videos & dyno!
///Mvious is online now   Reply With Quote
Old 01-05-2013, 11:54 AM   #563
330Cole
My Ride: 01' 330Ci
Originally Posted by secono330ci View Post
I dont know about the 272's, but I talked to bluejeansonfire and he said he liked the 264's over the 248/256 FI cams. This is on a turbo car btw. I don't think NA cams would work well on a supercharger due to its characteristics.
so if i want to do cams&VAC headwork, while keeping the possibility of going fi down the road, 264's are the way to go?
  • KW V1
  • Meyle HD Diff & Subframe Bushings
  • Meyle RTAB & TMS RTAB Limiter kit
  • Lemforder ZHP HD Control Arms
  • Meyle HD FCAB
  • TMS Subframe Reinforcement kit
  • TMS Swaybars F/R & Adjustable Endlinks
  • 3.38 Open Diff
  • BMW Performance SSK
  • BB Gen 3 Headers
  • Eisenmann Race Exhaust
  • 3.5" Longtube CAI
  • 3.5" Conforti Eurosport Filter
  • Shark Injector
  • Stoptech Slotted Rotors
  • TMS SS Brakelines
  • ST Sport Pads
330Cole is offline   Reply With Quote
Old 01-05-2013, 12:26 PM   #564
TrippinBimmer
My Ride: Just Fast!
So what cams u get?
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 01-05-2013, 12:53 PM   #565
Steven747
My Ride: 05 330ci
Originally Posted by trippinbimmer View Post
so what cams u get?
264
Old 01-05-2013, 04:01 PM   #566
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Originally Posted by rkneeshaw View Post
I just chubbed
Originally Posted by serdar255 View Post
Originally Posted by DarkJoker View Post
that's a good amount of toys
Just waiting on the cam tool and clutch alignment tool. Videos will be posted hopefully in the next week or two!
If you're going turbo then according to a few sources yes. If a supercharger then stick with FI cams. Pei330ci would know more about this than I would.
Originally Posted by TrippinBimmer View Post
So what cams u get?
Originally Posted by Steven747 View Post
264
Yup 264/248
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 01-21-2013, 07:16 PM   #567
secono330ci
Cams are in.
I took the car out for a drive and it hesitates up to 4.5k rpms. Is the timing off? Or could it be that the computer needs time to adapt? There is no check engine light..I drove for about 20 miles.
Old 01-21-2013, 07:18 PM   #568
Andy2108
My Ride: SpecE46 & E46 M3
You could try pulling the battery connection which will reset the adaptions, but I think it could be that your timing is off =/
Old 01-21-2013, 09:10 PM   #569
aggieE46
Keep it clean
aggieE46's Avatar
Something is wrong.
Old 01-21-2013, 11:16 PM   #570
secono330ci
I just drove back from a friends house and now the car drives normal. This is weird.
Old 01-22-2013, 12:11 AM   #571
Steven747
My Ride: 05 330ci
Fyi not sure if it relates I forgot to tell you there's. specific way to start your car after removing cams to get oil around and primed of sort.. You have to crank it until the red oil light disappears on the dash maybe 10-15 seconds.. My car started right up with zero problems .. Good luck hopefully you figure it out
Old 01-22-2013, 12:22 AM   #572
secono330ci
Already started it lol.
Ok so I got code p0014. I found this quote on bimmerforums "P0014 is the VANOS code, not the engine itself timing code (if there are such codes at all)".
Is this true? If so maybe a solenoid?
Old 01-22-2013, 12:27 AM   #573
TrippinBimmer
My Ride: Just Fast!
Timings off...
If you clear code it won't pop the cel until you restart...
Alpine White M3
MaximumPSI Stage4
Old 01-22-2013, 01:46 AM   #574
Steven747
My Ride: 05 330ci
Damn timing that's a bitch and what I was scared of
Old 01-22-2013, 07:28 AM   #575
jared_wiesner
My Ride: 1999 328i (M54b30)
Ya it really should run just fine right away. It may have adapted to run better in the condition it's in but as much as I hate to say it and as much as you probably hate hearing it, your going to have to tear back into it.
jared_wiesner is offline   Reply With Quote
Old 01-22-2013, 12:46 PM   #576
secono330ci
Ok thanks guys. Gonna re-do it again today.
Old 01-22-2013, 01:19 PM   #577
serdar255
My Ride: '01 325ci / '90 325i
How long was the whole cam job? Is the timing hard to do and/or fix?
Sent from my A500 using Bimmer App
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 01-22-2013, 01:28 PM   #578
Steven747
My Ride: 05 330ci
Took 4 hours or less to remove cams.. Took 2 days to get the new 1's in and timed because I had no idea what the hell I was doing lol
Old 01-22-2013, 01:56 PM   #579
SoloII///M
My Ride: Many
If you have the tools and follow the TIS it really couldn't be easier. The TIS lists every step in painful detail.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 01-22-2013, 02:18 PM   #580
secono330ci
Not too hard, just time consuming.
That's why I can't believe it's off
