Old 01-21-2013, 01:00 PM   #1
limpiabota809
My Ride: 330 XI
dsc light flashes in a hard corner
When taking a hard corner at different speeds always under 15 MPH though, the DSC light will flash and I can feel the ABS pulse on the front left wheel. I'm pretty sure I need an alignment as the car also pulls slightly to the left while I'm going 40+. That'll be taken care of tomorrow but is there anything else that i should be looking for or any other reason as to why the DSC light will flash while turning?
DSC issue started today, but I do however live in NYC so the streets are horrible(maybe this plays a role as to what is happening) haven't hit a pothole though or anything else for that matter.
limpiabota809 is offline   Reply With Quote
Old 01-21-2013, 01:08 PM   #2
FastHackem
My Ride: E60 M5
This is normal operation of the DSC system. Please refer to page 19 in your owners manual.
The Mind Is A Terrible Thing.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
FastHackem is offline   Reply With Quote
Old 01-21-2013, 01:13 PM   #3
limpiabota809
My Ride: 330 XI
Very true, however I've been taking this same road to work and never the issue until today
Instagram - @Limpiabota_e46
Old 01-21-2013, 01:16 PM   #4
FastHackem
My Ride: E60 M5
There are several things that can affect the DSC senstitivity. Start with your alignment and then report back. A proper alignment is crucial for the system to work correctly. Be sure the shop can re-calibrate the steering angle sensor as well. If they can't find a place that can.
2006 M5
2005 Impreza WRX
2002 330i
1983 944
Old 01-21-2013, 01:19 PM   #5
jcns
My Ride: California
could be a number of things
how are the tires? could be going bald causing slip. Check front and rear tires
is it colder now than before? Tires could be harder due to lower temps, hence less grip
Could be alignment related, if your alignment is really off.
tire pressure? A leaking/low pressure tire, will show lower speed than the rest and going around the corner this could meet/exceed the abs/dsc treshold activating the system.
jcns is offline   Reply With Quote
Old 01-21-2013, 01:27 PM   #6
limpiabota809
My Ride: 330 XI
Getting alignment done tomorrow will report then,
Will check tire pressure on my break they do seem lower than normal but not much maybe 35, definitely has gotten colder so I could see where that would play a role.
Old 01-21-2013, 01:39 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
It's normal. My car does the same on certain corners on my way to work.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-21-2013, 01:44 PM   #8
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
What ever the reason is, it sounds like it's working the way it's designed to.
HacksawMark is offline   Reply With Quote
Old 01-21-2013, 01:54 PM   #9
SK8URDEAD
My Ride: TopazBlu 325I
agreed, but mine is turned off all the time
325i Topaz Bluuu
Umnitza MTech II Body Kit, M3 Steering wheel, ZHP Weighted Shift Knob, Muffler Delete, Resonator Delete, Khoalty LED Tail lights, LED Corners, Bimman LED Side markers, Long CAI, Koni FSD's + B&G Lowering Springs, Black Suede Headliner + Pillars, Thule 753 Roof Rack n Fairing, AvinAvant2, 5% Rear 20% Front Tint. No such thing as DONE lol.
SK8URDEAD is offline   Reply With Quote
Old 01-21-2013, 02:02 PM   #10
TArse
My Ride: 03 330xi, 87 325is
do you guys race to work?
TArse is offline   Reply With Quote
Old 01-21-2013, 02:07 PM   #11
SK8URDEAD
i live on a base speed limit is 25mph buttt since im in cali and no one knows how to drive here compared to tx... i do keep up with them and go 75+on the highway.... i swear going back home in a few months i'll feel like im driving super slow haha.
325i Topaz Bluuu
Old 01-21-2013, 02:34 PM   #12
Hovs13
My Ride: E46 325ci
Mine did the same. I would go around a corner and dsc would kick in where it didn't during prior drives. found out my rear shocks needed replacement.
Hovs13 is offline   Reply With Quote
Old 01-21-2013, 05:39 PM   #13
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
check your RCABs. When they get worn, they can contribute to dsc light coming on when covering.
BMWCaptain is offline   Reply With Quote
Old 01-21-2013, 07:11 PM   #14
jakksfor20
My Ride: ZHP,Slow 323ci
I had the same thing happen after getting my rear tires replaced with new ones. I dealt with it for a week and couldn't get over the pulsing in the corners (more pronounced to the left). Didn't have any issues before that, so I went ahead and had the fronts replaced. Problem fixed. If the DSC sees too big of a difference between rotation front to rear is what I determined.
jakksfor20 is offline   Reply With Quote
Old 01-22-2013, 08:00 PM   #15
limpiabota809
My Ride: 330 XI
Ok, so I checked the tire pressure it was a tad low around 30 on the rears...I put some air to get them to 38 and I went for a drive and couldn't recreate the issue
