Old 01-20-2013, 05:49 PM   #1
Stevo77101
My Ride: 2000 328i
What do these lights mean???????
My alternator went out and I just replaced it and these two red lights rights next to the trunk diagram came on. they sorta look like the bright lights symbol but theyre red. Anybody know what they mean?
Stevo77101 is offline   Reply With Quote
Old 01-20-2013, 05:53 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Check your lights in the back.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-21-2013, 12:02 AM   #3
Stevo77101
My Ride: 2000 328i
They're all working. I'm at a loss.
Old 01-21-2013, 12:20 AM   #4
Snik
Snik's Avatar
My Ride: IR M3 Vert.
they can be triggered by the trunk lights too, and i believe the reverse lights, check ALL of them.
Some LED license plate lights will trip em even tho they work.
Do you ride a sportbike?
Old 01-21-2013, 11:21 AM   #5
Stevo77101
My Ride: 2000 328i
And the button to open the trunk isn't working either
Old 01-21-2013, 11:28 AM   #6
DHK
My Ride: 2002 BMW 325Ci
Check your fuses.
DHK is offline   Reply With Quote
Old 01-21-2013, 11:36 AM   #7
TArse
My Ride: 03 330xi, 87 325is
it means your thrusters went out.
TArse is offline   Reply With Quote
Old 01-21-2013, 12:32 PM   #8
lcoleman
My Ride: '79 Massey Ferguson
Check the wiring harness going to the trunk. You may have some abraded wires.
Old 01-21-2013, 12:41 PM   #9
Snik
Snik's Avatar
yep, def the wiring... as dude said, check where it bends at the trunk. hinges.
Old 01-22-2013, 12:41 PM   #10
Stevo77101
My Ride: 2000 328i
Just checked the wiring an that's all good. Now which fuse would control all that. I keep hearing 37 Is that a big red fuse?
Old 01-22-2013, 12:45 PM   #11
WDE46
My Ride: '13 128i, '04 330Ci
If a fuse blew, then it blew for a reason. That would indicate shorted wiring. The trunk wiring breaking is a common problem. You may have to buy a multimeter to see where the power is stopping or shorting.
Old 01-22-2013, 02:49 PM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
See my 'elephant trunk' thread. It's a broken wire...you can't see it because it broke inside the insulation.
I explain how to get to the wires easily and repair with inline slice, solder, shrink tubing. Have an soldering iron with at least 40W...easy repair.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-22-2013, 04:49 PM   #13
Stevo77101
My Ride: 2000 328i
Ok no fuses are blown. Used a multimeter and there's power getting to the license plate lights. And where the wires are wired through the hinge of the trunk are good except two, they're still connected but the plastic covering the wire is broke and some wire is exposed. There's also a connection that's near the battery that's not connected and I can't figure where it would go. Ugghhgh
Old 01-22-2013, 04:56 PM   #14
dmax
dmax's Avatar
connection near battery is nothing...used for shipping only.
You have to pull the wires apart to find the broken ones...yank from top and bottom and try to break each wire in the loom apart. Repair as needed.
Don't know how the insulation on the wires is broken, but you're looking for broken wires inside insulation. The wires that break when you yank are your problem.
There's also a reversing light, you know...and the failed trunk latch...also a broken wire. I'll even give you a 99% guarantee. If it doesn't fix your issue, I'll refund 99% of the cost!
Mangofy your E46!
Old 01-22-2013, 08:33 PM   #15
lcoleman
Wrap the abraded wires tightly with electrical tape and see if it helps your problem.
Old 01-25-2013, 07:31 PM   #16
Stevo77101
My Ride: 2000 328i
What voltage should be reaching the lights. 12 or 6?
Old 01-25-2013, 08:58 PM   #17
lcoleman
12, lol. Everything in the car, save a few of the engine sensors, runs on 12V. Those sensors will be 5v.
Old 01-26-2013, 11:55 PM   #18
Stevo77101
My Ride: 2000 328i
Well there's only 6 getting to the lights. I guess I'll follow the wire. It's either that or the housing.
