Sponsored by BimmerWorld
Old 01-22-2013, 11:38 PM   #1
Airborne82id
My Ride: 330CI
Clunking sound front end.
While I'm here ...
Been having this metallic sounding noise coming outta the front end, possibly the passenger side.
It happens when going over bumps or road imperfections. I tried to establish a pattern as to when it happens and it seems strangely random. I can go over a road bump, and nothing. Then a small crack on the road and I hear it. And it's not perpetual.
I'm waiting to have some time to lift her up and look under there. I did crawl down there and nothing seems outta the usual.
I know it can't be control arms and/or bushing.
Airborne82id is offline   Reply With Quote
Old 01-22-2013, 11:40 PM   #2
Nerdy46
My Ride: 328i
check your swaybar end links
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 01-22-2013, 11:41 PM   #3
tock172
My Ride: '12 135i Dinan S2
When did you last refresh your suspension components?
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 01-23-2013, 12:20 AM   #4
Airborne82id
My Ride: 330CI
I got this car 20k ago with 117k on odo. New Bilstein rear shock. Rear shock mount reinforcement. Shock mount rear. Rear shock compression absorber (bump stop). It's got new swaybar in the front and new power slot cryo rotors and pads all 4.
I can tell it's got original control arms and bushings- Also, I don't see any receitpts for them. Springs and shock absorber also stock and I've been contemplating on replacing them just for ride quality. I've replaced my CA and bushings on my previous e46 and they were beyond shot; didn't experience any clunking sound.
Old 01-23-2013, 12:22 AM   #5
MercForHire
My Ride: M235i 6MT
another case of dried up lithum grease in strut mounts
Old 01-23-2013, 12:32 AM   #6
Airborne82id
My Ride: 330CI
I think you're right. It does sound exactly like it's coming from a spring.
How do you fix that?
Old 01-23-2013, 12:35 AM   #7
MercForHire
My Ride: M235i 6MT
pop the hood and squeeze some lithum grease into the strut mount ball bearings.
Old 01-23-2013, 01:27 AM   #8
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
I'm glad I am not the only one anymore who was suggesting to grease the strut mounts.
BMWCaptain is offline   Reply With Quote
Old 01-23-2013, 01:30 AM   #9
BMWCaptain
Still need to look at your LCAB.
Check your ball joints too. I had one that was loose and caused a noise when going over bumps.
Old 01-23-2013, 09:14 AM   #10
RayPooley
My Ride: 320i SE Coupe
While I'm here ...
This .....
Old 01-23-2013, 10:16 AM   #11
taibinhvuong
My Ride: E46 99' 328i
It looks like your passenger side control arm inner ball joint is shot.
Jack both front end up, swing front right tire to full extend left and right, use a flash light careful to examine the rubber cover of the inner ball joint (one that mounted to the brake assembly, not the middle one), you may find it cracked and grease is leaking, this is the indication of a bad ball joint and will give you the clunk when go over sharp bump or road crack.
A loose or bad right sway bar bushing may also contribute to the clunking, check the bushing mounting bracket to make sure it is tight as well.
taibinhvuong is offline   Reply With Quote
Old 01-23-2013, 07:27 PM   #12
Airborne82id
My Ride: 330CI
I think Mercforhire suggestion is more likely the culprit.
When CAB are totally shot, it's not the sound that will alert you the most; It's the ride quality. As I've mentioned I've replaced control arms and bushings on my previous e46. This is different.
The sound sounds more like "ding", as if metal touching another metal but very hollow and light. I'm suspecting that spring, either hitting something or the bearings like Mercforhire suggested.
