Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 01-23-2013, 12:05 AM   #1
heechkass
My Ride: 323i Touring, 2000
Got cracked diff bushing...what else to do while there?
Discovered that I have cracked differential bushing. Wondering what else to change while I have it apart.
heechkass is offline   Reply With Quote
Old 01-23-2013, 12:13 AM   #2
BMWCaptain
My Ride: 03 325iT Sport Wagon
The rear lower control ARM brushing.
BMWCaptain is offline   Reply With Quote
Old 01-23-2013, 12:23 AM   #3
heechkass
Flex disc?
Old 01-23-2013, 12:33 AM   #4
BMWCaptain
Originally Posted by heechkass View Post
Flex disc?
Not unless it is bad. Would require removal of exhaust, drive shaft and heat shields.
Old 01-23-2013, 12:43 AM   #5
heechkass
By the way, I have 155000 miles on this...to provide context
Old 01-23-2013, 12:48 AM   #6
tock172
100% star stuff
tock172's Avatar
My Ride: 2004 330i
Csb.
Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One
Old 01-23-2013, 05:20 AM   #7
Ballistic325
My Ride: slow and steady
Drop in a LSD
Seriously though, changing rear end bushings will pay off... check other stuff like sway links. If you can manage to do RTABs it would serve you well.
Good luck
Sent from my V9 using Bimmer App
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 01-23-2013, 08:21 AM   #8
heechkass
I'll probably focus on bushings this round and leave csb and flex disc for another time.
Old 01-23-2013, 09:44 AM   #9
Stinger9
My Ride: '04 330Ci
History of diff seals?
Lots fail at much lower mileage. Cheap when you have the axles removed.
Stinger9 is online now   Reply With Quote
Old 01-23-2013, 11:11 AM   #10
Kubica
My Ride: 2003 325xi
Diff seals is a good one.
Upgrade to the M3 ball joint instead of another bushing here.
Old 01-23-2013, 11:57 AM   #11
Stinger9
My Ride: '04 330Ci
I know, mine went out at less than 90K miles.
What does that substitution look like?
Old 01-23-2013, 09:22 PM   #12
heechkass
Less extreme temps here...
Old 01-23-2013, 09:23 PM   #13
heechkass
^no salting in winter time.
My guess
Old 01-23-2013, 10:18 PM   #14
Stinger9
My Ride: '04 330Ci
My car gets driven only in summer.
Has never seen a salted road.
I'm in LA every summer.
Old 01-25-2013, 09:27 AM   #15
teamdfl
Lemony Fresh
My Ride: 325it
Replace every piece of suspension rubber under the car:
Diff bushings
rear subframe mounts
rear trailing arm bushings
upper and lower control arm bushings
Mod the driver first. Participate in your local BMWCCA driving school. Have you joined BMWCCA yet?
My Track Schedule
The solution to the lack of headroom in the X6
teamdfl is offline   Reply With Quote
Old 02-02-2013, 05:09 PM   #16
heechkass
Diff bushings
Sound advise. Is it easier to drop the exhaust and the whole rear axle to get all this done? Or is there a easier or better way to do this?
By the way, I was going through the list of all bushings to order and got stumped by a pair on realoem without a part number. I posted a separate tag to see if anyone can help identify it.
Old 02-02-2013, 05:17 PM   #17
Stinger9
My Ride: '04 330Ci
Are you sure it is for your car on realoem? If there is no part number, good chance it isn't for your car.
Yes, big nasty job to drop the rear and exhaust.
What is an upper control arm?
Old 02-02-2013, 11:03 PM   #18
heechkass
Thanks stinger. Your post made me go back into realoem...and found the note that explained why the part wasn't listed.
Notes:
Items pictured but not listed are not installed on your vehicle.
Items pictured without a number are listed on another diagram.
