Sponsored by The Tire Rack
Old 01-22-2013, 09:26 PM   #21
COBYATCH
My Ride: 03 325i
yes those will work. without them you run the risk of having the wheel not centered on the hub correctly and experiencing vibrations at high speeds.
COBYATCH is offline   Reply With Quote
Old 01-22-2013, 10:01 PM   #22
CSP
My Ride: m54
You have already been given help... The hub rings you posted are correct. You won't rub if you're on stock suspension. It will probably look goofy though with poke like that and 4" of gap.
CSP is offline   Reply With Quote
Old 01-22-2013, 10:13 PM   #23
trentcdrums
My Ride: BMW 323i Sedan
What If I dropped it 1.5"?
Old 01-22-2013, 10:31 PM   #24
CSP
My Ride: m54
Couldn't say for sure. I'd put money on you rubbing. Mine rub ever so slightly and I'm .6" lower than you. If you go with narrower tires and pull your fenders you might be fine. I strongly doubt it'll fit without modification if you have 235's on there.
Old 01-22-2013, 10:55 PM   #25
trentcdrums
The tire calculator look like it'll fit :/
Old 01-22-2013, 11:22 PM   #26
CSP
My Ride: m54
I don't know what you're looking at. I'm telling you that I'm .6" lower than stock with a +20 offset. I have 225's and rub mildly. If you want to go down 1.5" you're going to need modifications to something and significantly narrower tires. If you think they'll fit then go ahead and buy them. It's only $350.
Old 01-22-2013, 11:30 PM   #27
trentcdrums
I was hoping to stay stock, which would be even better with the fitment and no rub. Got a picture of yours?
Old 01-22-2013, 11:45 PM   #28
CSP
My Ride: m54
Stock should be fine. I can't say for sure how yours would look being higher but having wider tires. I don't have any pictures on my current setup but ill snap one tomorrow morning and post up for you.
Old 01-22-2013, 11:50 PM   #29
trentcdrums
I think they are 8" wide if I'm correct. He sent me some pictures of the rashes on them. Can't tell if I even want to pay $350 for that,, he just have let salt eat at it a bit
Old 01-23-2013, 09:54 AM   #30
CSP
My Ride: m54
16x8 et 20 with 225's on them
ID:	487343   Click image for larger version
ID:	487344   Click image for larger version
