Thread Tools Search this Thread Rating: Thread Rating: 39 votes, 4.90 average. Display Modes
Old 01-22-2013, 03:35 PM   #581
TrippinBimmer
My Ride: Just Fast!
Originally Posted by secono330ci View Post
Not too hard, just time consuming.
That's why I can't believe it's off
Never go counterclock wise. Go a tad will throw it all off...
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 01-22-2013, 11:46 PM   #582
jared_wiesner
My Ride: 1999 328i (M54b30)
After the time involved anyone could mix a step up or do something backwards. If enough people do the job, someone's bound to slip up eventually. To say its simply following steps is removing the human element. Mistakes happen. Most of us are just lucky enough to forget things like putting back on the plastic undercover, or forgetting to loosen wheel bolts before jacking or something else easily identified and remedied. Secono was not so lucky this time.
jared_wiesner is offline   Reply With Quote
Old 01-22-2013, 11:48 PM   #583
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Just re-did the timing and took it for a drive. Everything seems to be working better than before. No more hesitation.
Driving impressions:
This thing pulls HARD. I love it. Especially after 5k it just freaking opens up. The low end torque is nuts (from the new vanos seals). Also the sound is just...
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 01-22-2013, 11:49 PM   #584
jared_wiesner
Great to hear it!
Old 01-22-2013, 11:54 PM   #585
secono330ci
Originally Posted by jared_wiesner View Post
Great to hear it!
Thanks! Yea it happens, just glad I got it right the second time
Old 01-23-2013, 12:59 AM   #586
secono330ci
Or not...code p0014 came up again when I started the car. WTF.
Old 01-23-2013, 07:11 AM   #587
jared_wiesner
Your sure your getting the Vanos alignment right? And the exhaust side cam sensor is plugged in for sure right?
Old 01-23-2013, 10:57 AM   #588
SoloII///M
My Ride: Many
That is exactly what I was thinking. This sounds like a VANOS alignment problem.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 01-23-2013, 01:05 PM   #589
secono330ci
The sensor is plugged in yes. What do you mean by Vanos alignment? I followed the assembly here step by step..http://germanautosolutions.com/diy_t..._tools_diy.php
Old 01-23-2013, 01:23 PM   #590
SoloII///M
My Ride: Many
If you followed all those steps you shouldn't be having any problems.
John V
Old 01-23-2013, 01:27 PM   #591
jared_wiesner
Vanos alignment is the part where you use the Vanos jig or the pins they provide in their personal set to set the Vanos pistons to their proper place (pushed in/out relative to each other and the cams)
Did you use the GAS personal kit or the premium kit or get the tools elsewhere?
Old 01-23-2013, 01:52 PM   #592
secono330ci
Used the GAS Professional Kit
Old 01-23-2013, 02:06 PM   #593
TrippinBimmer
My Ride: Just Fast!
take pics of steps next time? had to do mine the second time but its much better and don't throw a light but I am going to redo it again soon...
-Anthony
Alpine White M3
MaximumPSI Stage4
Old 01-23-2013, 02:16 PM   #594
jared_wiesner
Ok, well I definitely know the GAS kit works. Hmm, there is very little room for error when setting those pistons with it too. It's always possible that somehow the cam sensor got damaged during the install but seems unlikely. It's really hard to know where to start. From what I gather, that code is suggesting the exhaust cam is too far advanced out of range. In other words, the computer has is seeing the exhaust cam as too far retarded to bring back within tolerance using vanos because it started too far in the advanced position. Or maybe I'm backwards and it started too far retarded and can't be advanced enough. Either way something is off or the sensor is not reading right. The only thing that differed from my install is the Vanos seals. Did everything go well there? Anything that maybe didn't work the way you expected?
My other thought is maybe the chain tensioner tool wasn't set up right and over/under tensioned the chain and threw off the timing?
Old 01-23-2013, 02:33 PM   #595
TrippinBimmer
My Ride: Just Fast!
Send u a pm with # in a few
Alpine White M3
MaximumPSI Stage4
Old 01-23-2013, 03:07 PM   #596
secono330ci
-Anthony
Ok I will snap some pics
Interesting point about the chain tensioner tool. To be honest, I couldn't really tell how much I was suppose to tighten it. I may have over tightened it.
I'm going to open up the Vanos and check if the seals are properly seated. Also gonna swap the Vanos solenoids and see if the code switches to the intake side.
Do you think maybe the AA tune I have can affect this?
Old 01-23-2013, 03:29 PM   #597
TrippinBimmer
My Ride: Just Fast!
Tensioner is the problem. Once I get back in town will hit u up. Tune shouldn't matter. They only mess with fuel maps...
Alpine White M3
MaximumPSI Stage4
Old 01-23-2013, 04:30 PM   #598
secono330ci
Ok sounds good. Hopefully it is the tensioner.
Old 01-23-2013, 08:24 PM   #599
SoloII///M
My Ride: Many
When I did my cams I didn't have the tensioner tool. I modified the stock tensioner to eliminate the spring temporarily and replaced it with a section of rubber tubing. You don't have to crank it down - the goal is just to take up the slack on the exhaust side of the timing chain.
John V
Old 01-23-2013, 08:49 PM   #600
jared_wiesner
Exactly, you have to make sure to take up all the slack but also not crank it to high heaven either.
