Rating:
#941 |
Bottom RIGHT hose has the coolant temp sensor on it. Learn this stuff well so we know what you are talking about.
Did you lube well? Remove, clean, reposition O-ring, lube and retry. Full system does not do what you need. Sorry, you need to drain. I'd not leave my car where yours is now. |
#942 | |
Modded ///Member
#943 |
#944 |
Modded ///Member
so i drained and pulled the RIGHT side hose off the radiator. I put it back on, it snapped into place and I locked it down. Still looks ever so canted - not much better then before. I'm going to run it like this for a few days, keeping a close eye on it, and see how it goes.
I mean it's locked into place - could have just been loose the first time, then residue coolant leaking out around the next few times I checked. We'll see. |
#945 |
I will have to add this(since it is my problem now)the LOWER RADIATOR HOSE TEMPERATURE SENSOR COOLANT!,I have a 2003 330ci A/T,the dash was constantly showing the lower coolant level warning light..it was hard to find,but today showed it was the culprit,the o ring in this sensor degraded and allowed a small amount of coolant to drip....my two cent here!
#946 | |
Which are you talking about? The low coolant level sensor has no O-ring. The sensor on the lower hose is not a level sensor. |
#947 | |
Level sensor (Bottom of ET)will report to the low coolant "mango lightŪ", and has no O ring. Fan switch/Temp sensor on lower hose has an O ring, if you have a leak here the level at the ET diminishes, and triggers the low coolant light...followed by overheating. Regardless, glad you sorted it out.
#948 |
The sensor i'm talking about is located at one of the ends of the lower radiator hose,that fan switch sensor has an o-ring/seal,once the seal goes bad,coolant starts dripping from the sensor's housing,thus the coolant level decreases and then triggers the colant level sensor...makes sense now?
#949 |
Yes
Everyone replaces this sensor with O-ring when they replace the lower coolant hose. Last edited by Stinger9; 01-21-2013 at 10:06 PM. |
#950 |
Its a good kit, I just used the kit from pelicanparts.com which came with all the necessary and is around $400. I added a new oem expansion tank, Ac belt, and idler pulley. Total was around 520.
*no radiator included. Radiator is approx an additional 200 Sent from my SAMSUNG-SGH-I747 using Bimmer App |
#951 |
Ps. It comes with the o ring!
#952 | |
And new oe rad is under $150 Can edit posts. Last edited by Stinger9; 01-21-2013 at 10:32 PM. |
#953 |
My Ride: 2005 325xi
Mango, I know you had been looking for the TIS bleeding instructions for our E46 M54's I just got the TIS so I screen printed it.
Rubs the roundel on its skin or else it gets the hose again.
#954 |
awesome.good stuff
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#955 |
Can I ask you a question about the bleeding TIS. Should we put the car on ramps before we remove everything? How do I move it to ramps once I have no coolant? Trying to figure out the best way.
Thanks,Joe
2003.5 LSB/BLK M3/6SP/Non-Sunroof/Bluetooth/PSS9/SSR-GT3 - Sold
2007 TiAG/BLK 335I Sedan/6SP/Sport/Premium/Cold Weather - Sold 2003 AW/Tan 330XI/AT/Sport/Premium/Cold Weather - Winter Car |
#956 |
Thanks,Joe
#957 |
I did my cooling system refresh starting out on ramps and kept it there for the whole job. No need to bleed until you're back on level ground.
#958 |
Can anyone confirm the washer for the block is copper and not silver? The one I received from BMA parts is copper per the part # from Mango.
#959 |
I have no doubt that the washer you received will work just fine.
As long as it fits the plug, use it and relax. |
#960 |
My Ride: 2005 325xi
The ETK does in fact call for aluminum, but I don't see why copper couldn't be used in place.There isn't anything in the cooling system that will eat copper.
| Tags |
| bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump |
| Rate This Thread | |
