Old 01-22-2013, 07:17 PM   #1
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
The next step of my Technique Tuning turbo setup.
Well I've been at this fit a long time now but I just recently got by own garage. ...
Anyways all I'm waiting on now is money for the clutch.
So I'm shooting for 450whp, I'm not sure if it's possible..... tell me what you guys think.
This is what I have compared to the TT stage 2
14.5 psi /13psi
.82ar exhaust/.63ar
ZHP cams/oem
I'm not sure if that's worth 75 hp/tq but I hope it's close.
Anything I should change, add, or do differently while it's still out?
Sent from my SCH-I605 using Bimmer App
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 01-22-2013, 10:10 PM   #2
mike@maximumpsi
My Ride: 02M3T
What exhaust are you running? We are fairly close and could help you with your goals.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 01-22-2013, 10:14 PM   #3
zx5rider
The magnaflow cat back I got from a group buy chopped to fit after Nick's cat.
'03 M3
'11 BMW s1000rr
Old 01-22-2013, 10:17 PM   #4
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Can't wait to see you finished. You have to give me a ride after its done.
Timeless Motor Group
Old 01-22-2013, 11:19 PM   #5
djtrini
My Ride: 04 M3 & 05 330i ZHP
+1 for the results! I'm on the fence on trading in my wife's 05 330 ZHP 6spd sedan for a 335 M-Sport. The car has been bulletproof for me since day 1, just needs more power!
djtrini is offline   Reply With Quote
Old 01-22-2013, 11:42 PM   #6
Grande D
My Ride: E36 M3
I'd wager that a 330 with Nick's kit would be more reliable than a 335i...
It will change your life!
Old 01-23-2013, 12:09 AM   #7
zx5rider
A newer twin turbo 3 L putting out 300bhp vs a single turbo 3L putting out over 400. This is not why I started this but I feel life the engine that was designed for the turbos all be more reliable. ....... Just me though
'03 M3
'11 BMW s1000rr
Old 01-23-2013, 05:32 PM   #8
Guest021715
Account closed.
Just wondering, wasn't that catback supposedly optimized for power around 210hp?
I remember reading something about it a while back (Rob43?)
Old 01-23-2013, 05:53 PM   #9
Grande D
My Ride: E36 M3
I agree- that'd be the normal, logical conclusion. However, the N54 has been far from reliable. From the turbos to the waste gate to the HPFPs.
The N55 seems better. But it doesn't have much headroom.
Old 01-23-2013, 07:06 PM   #10
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
What do 2 X 2.5" exhaust pipes flow? The TT kits re-use the OEM exhaust and see well over 300rwhp....I imagine the Magnaflow to be a bit better....
Old 01-23-2013, 07:36 PM   #11
daemonicus
My Ride: batmobile
did Nick tune your DME for the extra boost and new cams or are you just running a base stage 2 tune?
perhaps Nick or even PEI can answer, are there any potential dangers in running a base tune that was made for less boost and different cams or is it a small enough change that the car can safely adapt?
daemonicus is offline   Reply With Quote
Old 01-23-2013, 07:49 PM   #12
TrippinBimmer
My Ride: Just Fast!
DME can Adv or Retard so much Timing and can Adj -/+ the whole fuel map on the ms45. The DME can only do so much. It is best not to drive it until Dyno Tune is done or Street Tune with Datalogging all the important parameters..
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 01-23-2013, 08:10 PM   #13
zx5rider
What?
'03 M3
'11 BMW s1000rr
Old 01-23-2013, 08:11 PM   #14
zx5rider
We'll talk about this once I get the car running
'03 M3
'11 BMW s1000rr
Old 01-25-2013, 09:42 PM   #15
Guest021715
Account closed.
What?
I've been trying to find the thread where the Magnaflow was supposedly "tested" and came up as a bottleneck. Calling Rob43 for clarification!
Was curious on the opinions of others in regards to the issue. I completely agree with both of your viewpoints "wtf is this guy talking about" LOL
Old 01-25-2013, 11:29 PM   #16
TrippinBimmer
My Ride: Just Fast!
It was Jae and he is boosted. It was the rear muffler and the Y to the tips. That was causing the high whine pitch noises....
Alpine White M3
MaximumPSI Stage4
Old 01-26-2013, 09:34 PM   #17
zx5rider
How do you guys feel about putting an electric cut out right before the cat? I've read that turbos are best with no exhaust at all. if so any brand recommendations?
'03 M3
'11 BMW s1000rr
Old 01-27-2013, 12:15 AM   #18
TrippinBimmer
My Ride: Just Fast!
This is what I am doing with my 3" exhaust system. I am going to use this cutout...
http://www.quicktimeperformance.com/OVAL/
Alpine White M3
MaximumPSI Stage4
Old 01-27-2013, 10:07 AM   #19
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Those things don't have the best reliability record. I would PM Cameron (HighboostingM3) on BFc....I seem to remember he has some other brand of cutout that he's really happy with.
Looking at doing this myself as well....as I really don't want to run nitrous exhaust through a cat.
Old 01-27-2013, 10:09 AM   #20
TrippinBimmer
My Ride: Just Fast!
I will check into it Thanks Adam!!!
Alpine White M3
MaximumPSI Stage4
