Ethylene Glycol Antifreeze vs. Regular antifreeze..?? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-18-2013, 08:37 PM   #1
RonJon
My Ride: 2002 Bmw 325ci conv
hey guys. I live in Atlanta. The temperature here fluctuates alot. well, about a week, and this morning, the temperature was below 45 degrees. each time my coolant light came on briefly, and eventually went off. I want to know is it mandatory that I replace the coolant with bmw coolant or is it ok to put regular antifreeze in the reservoir? it's a 2002 bmw 325ci.
RonJon is offline   Reply With Quote
Old 01-18-2013, 09:06 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If you only need a cup or two, and I hope that's all it is, just use distilled water. Otherwise, it's best to use the same stuff you have in there in a 50/50 mix. If you don't know what that is, distilled, until you need to use more of it.
Monitor level accurately...in a.m. on level ground...so you can tell if you're losing coolant from a leak, or just had a very minor long-term seepage.
Look for leaks...remove underskirt and look with good led. Depending on what you've done already...you might want to consider overhaul and be done with it.
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 01-18-2013, 09:09 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest a mix of BMW Antifreeze and distilled water if you do not want issues.
BMW Dealer or Olympus Auto Parts usually has both Gallon and Liter bottles.
Old 01-18-2013, 09:13 PM   #4
dwtaylorpdx
My Ride: 2005 330xi
Xerex G05 is for European cars as well. Specifically for the all aluminum engines...
Dave
dwtaylorpdx is offline   Reply With Quote
Old 01-18-2013, 09:17 PM   #5
jfoj
I believe Pentosin is the manufacturer of BMW coolant?
Check your local Import parts stores and see if they carry a suitable substitute or BMW coolant.
http://www.pelicanparts.com/bmw/tech...lant-Flush.htm
Old 01-21-2013, 11:35 AM   #6
hummer
My Ride: 2001 330CI
Isn't all coolant these days ethylene glycol? It may be colored blue, green. pink or orange. But, you shouldn't mix ethylene and propylene if that's what you mean.
Old 01-24-2013, 01:21 PM   #7
RonJon
thanks for your input guys. I bought an all purpose anti-freeze that was supposedly for all makes, models, and colors of antifreeze. I only had to pour about a 1/2 of a quart, and that topped it off. My coolant light has not come on since. My car never over heated, and my temperature gauge has really never been past 1/2. Thanks again....
Old 01-24-2013, 02:19 PM   #8
bumere46
My Ride: E92
drain that sh*tt asap
put bmw coolant
trust me
bumere46 is offline   Reply With Quote
Old 01-24-2013, 04:19 PM   #9
jayb328i
My Ride: E46 2000 328i
Do it right, use the BMW coolant (blue) or the identical product. The AM auto stores do not usually carry it. Do not use the green stuff.
jayb328i is offline   Reply With Quote
Old 01-24-2013, 04:22 PM   #10
TiALT6
My Ride: 2000 328Ci
If its an emergency, use what you have. But i wouldnt leave that all-purpose coolant for a prolonged period of time.
TiALT6 is offline   Reply With Quote
Old 01-24-2013, 04:27 PM   #11
TrickTizzle
My Ride: 325i
Just search the forum for your answer....There's a new thread every other day about this so shouldn't be hard ....
Old 01-24-2013, 04:31 PM   #12
WDE46
My Ride: '13 128i, '04 330Ci
If you already had BMW coolant in there, then the best course of action would just be to top off with distilled water. Since you are in Atlanta, you don't really need the 50/50 mix.
