Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 01-16-2013, 09:36 AM   #661
InDiGlOM3
My Ride: HPF M3 stg 2.5
Originally Posted by Dreikraft View Post
lets us know what you find on pricing. i've been thinking about mine
This might sound ghetto but i got a alternator from autozone lol running good for over a year now and a limited lifetime warranty, mainly meaning as long as i dont have a system its a lifetime warranty.
Sent from my PG86100 using Bimmer App
Old 01-16-2013, 04:54 PM   #662
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
New alternator arrived and am installing now.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is online now   Reply With Quote
Old 01-16-2013, 09:36 PM   #663
being3
Modded ///Member
being3's Avatar
Well just finished installing alternator ( what a pain) ran much better. Wine in stereo gone voltage was at 12 volts ?? and was not fluctuating. Then the alternator Light came on and the voltage dropped to 11
The unit lasted less than 10min! so much for buying a rebuilt unit.
Old 01-16-2013, 10:38 PM   #664
02black330ci
My Ride: spaceship
The unit lasted less than 10min. so much for buying a rebuilt unit.
F-U-K-A-M-E!!!! Sorry man, keep at it though, you came this far.
02black330ci is offline   Reply With Quote
Old 01-16-2013, 11:47 PM   #665
being3
Modded ///Member
being3's Avatar
Ok reset connectors and battery cable and the alternator seems to be working again.
Old 01-16-2013, 11:48 PM   #666
Commanderwiggin
My Ride: 900rwhp Turbo M3
Lol you got gremlins man
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 01-16-2013, 11:49 PM   #667
being3
Modded ///Member
being3's Avatar
Here's a video of the car now idling great with the AEM monitoring voltage linked to my iPad Very cool
Old 01-17-2013, 12:34 AM   #668
being3
Modded ///Member
being3's Avatar
Yes I do. Lol. Seems that the new alternator is flaky so ill need to replace it ASAP. I'm going to a local shop and have them rebuild my old one tomorrow morning. I have the next 3 days off so ill be hard at it.
Old 01-17-2013, 12:43 AM   #669
Commanderwiggin
Keep up the great work!
Old 01-17-2013, 03:27 PM   #670
being3
Modded ///Member
being3's Avatar
Seems that the new alternator quits working after its been warmed up. Instead of rebuilding my old one I decided on ECS to replace the alternator and expedite it to me at their expense. They were very accommodating. So it will be next week. I am learning a lot of patience. Lol
I might slap the intake on as it is and go for a short run just to see how the car is.
Old 01-17-2013, 09:35 PM   #671
being3
Modded ///Member
being3's Avatar
Well I slapped on the intake and took it for a spin with the new flaky alternator. Running great very stable throttle and AFRs. Did some data logging and looks excellent. The TPS / RPM fuel map is now stable and not jumping all over the place when cruising. My stereo since I had the car had a whine / buzz. That noise is now gone and so are the unstable voltages. Now back to putting in the replacement alternator for next week. Then off to the AEM Dyno tunner about 90 minutes drive down the road...
For fun I also was able to test out the Virtual Dyno software. Simulates a dynojet from the AEM logs when u calibrate for the car: driver & car weight, final drive, trans gear ratio, tire height, and drag coefficient etc... Worked fairly well compared to my actual dyno numbers. It seemed to give reasonable numbers
Old 01-19-2013, 04:38 PM   #672
being3
Modded ///Member
being3's Avatar
While I'm waiting on my replacement alternator I am configuring my new AEM serial gauge with the EMS. I am now able to configure up to 19 different channels from the EMS and view them on a single gauge. I have set Alarms to flash the gauge on certain conditions. All user customizable. I have it setup for knock sensors, timing, AFR, O2 feed back percent, batt volts, tps volts, rpm, speed, throttle percent, boost , air temp, cam1 & 2 degrees etc... This is some of the flexibility I have been looking for... If I have any parameters that I'm monitoring trigger it gives me a warning and saves on the gauge that hi or low value. It will also send out 2 different out puts for a dash light or trigger low boost etc... I can then just plugin the laptop to download the log and diagnose... Considering the codes that the car throws with the kit this will be a great way to see any issues.
Old 01-19-2013, 06:34 PM   #673
being3
Modded ///Member
being3's Avatar
I am going to do a little video on the AEM Serial gauge and how I have it hooked up monitoring the engine. The goal is to implement what I learned via a lot of trial and error about what can go wrong such as Vanos, TPS issues etc. It can now be setup for the gauge to be a flashing alarm for lets say for example if cams not operating due to Vanos / cam sensor failure or even TPS sensor failure/ malfunction. These can now be monitored via the new gauge should issues crop up in the future I would know very quickly what area the problem is. Here's a pic setting up the EMS data. The video is to follow. I don't want to speak for HPF but this would be an easy addition and feature for their kit. It's taken me a few hours just to dial in the gauge with what I want. The neat thing is u can save the configuration so if anyone wanted it I would be happy to send it to them. Click image for larger version
Old 01-20-2013, 03:53 PM   #674
Cipri
My Ride: E46 M3 2002
For what MAP did you configure the boost monitor?
Cipri is offline   Reply With Quote
Old 01-21-2013, 09:38 PM   #675
being3
Modded ///Member
being3's Avatar
5bar base map. I then configured the gauges using the telemetry serial data. I created a spreadsheet that does all the math for non signed and signed data channels to accurately configure the gauge. If anyone wants it shoot me a pm.
Correction 3.5 map sensor
Old 01-22-2013, 03:33 PM   #676
being3
Modded ///Member
being3's Avatar
Replacement alternator will be here Thursday so hopefully that will get me back on the road and things running smoothly.
Old 01-24-2013, 06:10 PM   #677
being3
Modded ///Member
being3's Avatar
Ok replacement alternator arrived and am now installing i,m becoming very skilled in taking this car apart. Lol
Old 01-24-2013, 06:13 PM   #678
djtrini
My Ride: 04 M3 & 05 330i ZHP
lol good stuff, its always best to know how to wrench on your own vehicle! Hope the replacement alternator works out better for you.
djtrini is offline   Reply With Quote
Old 01-25-2013, 01:18 AM   #679
being3
Modded ///Member
being3's Avatar
Ok all done. Installed new alternator. Working great. Went for a drive & car drives great. It's raining so there only so much I can do. Idles great & AFRs are bang on. Drives smooth. Here's a small video of it running. now I can go to the dyno for some mods
Old 01-25-2013, 07:52 AM   #680
Commanderwiggin
Great work man!
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
