Old 01-24-2013, 08:55 PM   #1
vorceb23
My Ride: 04 330i
Angel eyes that can turn off?
Who sells LED angel eyes for the e46 that can be turned off? I found some on ebay that claimed to be able to but I'd rather buy from Umnitza or another sponsor. PS sorry if this has been asked but when I did search I didn't find anything.
Brendan
R.G.V. 1929-2013 Forever Loved
vorceb23 is offline   Reply With Quote
Old 01-24-2013, 09:00 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Turned off in what regards? Through a switch so you have control?
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-24-2013, 09:05 PM   #3
mkodama
mkodama's Avatar
Use a DDM Tuning relay harness and take out the fuse; they will turn off.
Alternatively, if you want to switch the angel eyes on and off from inside the car, add a switch in series with the trigger wire that turns the angels eyes on when your car is on. A switch will be like $2 from radioshack. This is also using a DDM Tuning relay harness.
Old 01-24-2013, 09:58 PM   #4
vorceb23
My Ride: 04 330i
Thats what I was thinking like through a remote or something but what he was saying seems like it will work^. Thanks
Old 01-24-2013, 10:36 PM   #5
Tiag46
My Ride: e46
I've wired in a switch so I can turn mine off whenever I like from my drivers seat.
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 01-24-2013, 10:45 PM   #6
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
+1
Took like 15 mins & $8.
Bimmer4Lyfe is offline   Reply With Quote
Old 01-24-2013, 10:49 PM   #7
rossisboss
My Ride: '03 330i sedan ZHP
same here, I got a switch with orange LED indicator and mounted it under my E-brake, the black matched very close to the interior, the LED is a little more orange than the factory interior lights.
it involved a little work, and I don't remember if I have any photos from it anymore. basically you buy some 20-22 gauge wire and extend the signal wire for the relay to a switch inside the car, and back out to the relay. My switch needed a ground for the LED so I used one of the E-brake mounting bolts and an eyelet on the ground wire.
I ran it in through the rubber boot in the passenger footwell area, just used a sharp pick to poke a small hole in an unused nipple of it. then under the dash to the center console coming through the radio/shifter area.
EDIT:
heres my switch.
http://www.wiringproducts.com/conten..._switches.html
rossisboss is offline   Reply With Quote
Old 01-24-2013, 11:11 PM   #8
vorceb23
My Ride: 04 330i
Did you do the same thing as rossisboss^?
Old 01-24-2013, 11:17 PM   #9
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
You should just wire in a switch. Should be pretty easy with some electrical know how
Old 01-25-2013, 05:20 AM   #10
Tiag46
My Ride: e46
Yep basically.
Wire up exactly as per normal. I.e. wire up the trigger wires to the ignition wire in the ecu, and to the footwell light.
then just wire in a switch inbetween the trigger wires.
Really quite simple.
Old 01-25-2013, 09:06 AM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Look at this
http://www.bimmerfest.com/forums/sho...349&highlight=
Old 01-25-2013, 09:26 AM   #12
BRccKLYN
My Ride: Topaz 01 330ci
I just wired my lights to my fogs. I diddnt use my fogs often in the past just to look good so now they go on with the halos!
BRccKLYN is offline   Reply With Quote
Old 01-25-2013, 09:29 AM   #13
jerseyzillest
My Ride: 325 CI
I made my own XD just buy a switch from RadioShack, put it where you want in the car and run a wire from the red with yellow dot wire to the switch and run the other one out to the angel eyes.
DONE!
If I had pictures I'd show you but I have none at the moment.
Photobucket
^Taken with iPhone^
:rofl:
jerseyzillest is offline   Reply With Quote
Old 01-25-2013, 06:49 PM   #14
vorceb23
My Ride: 04 330i
DONE!
What kind of wire and where can I get it from?
Old 01-25-2013, 07:52 PM   #15
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
All you need is a switch, 6' of 16g copper multi-stranded wire, a coat hanger, some electrical tape, 2 female space connectors, and a 1/2" drill or dremel.
Total work - 20 minutes
Total cost - $5 including switch.
Run an extension to the primary trigger into the switch, run the wire from the switch back out to the ECU, mount the switch through the hole, done.
Old 01-25-2013, 08:40 PM   #16
The Thomas J
My Ride: 2002 325Cic
Same here.
The Thomas J is offline   Reply With Quote
angel eyes, led, remote, umnitza
