Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 4.92 average. Display Modes
Old 10-16-2011, 02:16 PM   #61
grandcarrera
My Ride: 330xi 2003
Originally Posted by grandcarrera View Post
is it like this ?
ant idea ?
grandcarrera is offline   Reply With Quote
Old 01-28-2012, 01:31 PM   #62
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
thanks for the DIY.
My car is starting to show this issue so I need to get this fix. not bad for a 125,000 miles car (production yr: 2000)
Old 03-12-2012, 07:57 PM   #63
ronhetz
My Ride: 330xi
Smile blower with cover
Originally Posted by samytampafl View Post
(don't know what happened to the pics.. let's try again)
Ok.. here's the DIY for the cricket/electric buzz behind the dashboard (driver's side) culprit was the fan. You will need the following description and part number from the dealership: BLOWER WITH COVER PART NO. 12-14-1-437-454. Cost $70.00. It takes approx. 30 mins to change and you will need the following tools a hexagonal tool set and a phillips screw driver.
Here we go.. STEP 1: remove the plastic cover just above the pedals..
JUST A FRIENDLY REMINDER REMOVE THE PIN
COMPLETY OFF THE FASTENER..
IF U PULL THE FASTENER WITH THE PIN INSIDE IT WILL BREAK!!!
STEP 2: remove the 3 screws from the blower.. yes this is the culprit to the cricket noise!!.. which dealer could never find..
Warning! once blower is free.. it's NOT!..
DO NOT PULL ON IT!! it's not yet free from the electric connection..
STEP 3: open hood.. head out to the front of the car.. find the electric box and remove the 4 hex screws, then remove the plastic cover..
STEP 4: Where my index finger is, in the back of the box you will see the connector to the blower slide it off (after releasing the safety clip it slides down not up...) Then disconnect the blower and retrieve it from the inside..
STEP 6: get replacement, connect it.. and place everything back!!
Hope this helps and enjoy u'r cricket free car!!
Where did you buy your blower? I can't findit withthe part number? Thanks
ronhetz is offline   Reply With Quote
Old 04-14-2012, 10:14 PM   #64
Sanchjer
My Ride: 323i e46 SOLD!
when you look for the part number take the "-" out of the number.
Sanchjer is offline   Reply With Quote
Old 08-18-2012, 09:05 PM   #65
Starless
My Ride: 02' 325i
Took the blower out and lubricated the shaft from both sides it with my P.T.F.E precision lubricator. Hopefully it will prolong its life for a couple of more years.
Starless is offline   Reply With Quote
Old 08-28-2012, 05:27 PM   #66
Got_S54?
My Ride: 2002 M3
info on part numbers
FYI, it looks like part number 12-14-1-437-454 (12141437454) has been superseded.
It looks like there are two versions - one with a 3-prong connector and one with a 2 prong connector.
To check which you need, go to www.realoem.com and look up the part making sure you choose the correct year/model. From the main group, go to #12 - Engine Electrical System, then go to the Subgroup and choose 12-35 Control Unit Box.
You're looking for part #5 called the "Cover with blower".
It looks like for cars up to 2003, the correct part number is 12907571019
For cars 2003 and up, the correct part number is 12907570074
Double check with RealOEM or your local dealer to be sure.
05 TT 225 Quattro - APR Stage 1|FK coilovers|Megan Adj.Cont.Arms|APR catback|15F/20R spacers|OEM ALMS 18's - daily
02 M3 AW/IR - sold but not forgotten
Got_S54? is offline   Reply With Quote
Old 09-01-2012, 11:23 AM   #67
ecopvm
My Ride: '03 BMW 325xi
If I get the e-box fan disconnected, do you think I can make a 4000 mile trip without any problems? I have the fuse 28 problem, if I connect the fan the fuse keeps blowing.
ecopvm is offline   Reply With Quote
Old 01-24-2013, 05:26 AM   #68
CrazyOneToo
My Ride: 1999 328i 4dr
Ok.. I haven't checked the thread in a while, but did find some information about it.. I would replace the blower.. it's not that expensive... the thing is that if u live in warm weather places ie: Florida, Texas and such.. the blower will keep that cluster at a lower temp than the rest of the engine compartment.. so as w/ any DIY is up to each individual to do it.. or not.. my advice save the money then change the blower.. the cricket shouldn't come up again for long time.. good luck!
My car has the chirp also but goes away when I turn the fan speed up or off.
That would be the other fan right? The one out under the hood?
I guess I can unplug this blower under the hood and see if the chirp is still there.
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
Old 01-24-2013, 06:04 AM   #69
jfoj
My Ride: 330CiC, M5, X5, E93
If your noise goes away buy turning the HVAC blower up a few bumps or turn ilt off, then your HVAC blower is the problem.
Old 01-24-2013, 12:33 PM   #70
CrazyOneToo
OK thanks
Old 01-24-2013, 01:11 PM   #71
jfoj
4 common cricket/motor sounds in these cars are:
1. DME blower
2. HVAC main blower fan
3. HVAC controller micro fan
4. SAP air pump motor, but this thing is not really a cricket when it goes bad, more like an angry bear!
Old 01-25-2013, 12:19 AM   #72
CrazyOneToo
1. DME blower
Is number 3 the removal fix shown on this DIY page??
Old 03-25-2013, 10:36 AM   #73
Tokapeba
My Ride: 2003 325xi
I was able to quiet my DME fan motor with a small dab of lithium grease. I took the fan all the way out, but it would be much easier to do it without taking the fan out.
Under the dashboard the fan and motor are accessible after removing the trim. The cover on the fan motor isn't screwed in ,so it just snaps off. Move the wire out of the way pop the cover off, put a small dab of lithium grease, snap the cover back on put the shield back and thats it.
Tokapeba is offline   Reply With Quote
Old 05-06-2013, 12:58 PM   #74
mikegrad
My Ride: 2005 325 XI
Great info
this is great info, thanks to everyone who has posted! I have an intermittent screech that goes away when i turn the fan off, so i am replacing the HVAC motor this weekend. This really helped me narrow down the issue!
Anyone have a DIY link for replacing the hvac fan blower?
mikegrad is offline   Reply With Quote
Old 05-06-2013, 02:11 PM   #75
cvx5832
My Ride: 325Ci, 325Cic, C300
http://forum.e46fanatics.com/showthread.php?t=418987
Read the entire thread. A lot of tips, suggestions and part numbers have come to light since the original 2006 post.
cvx5832 is offline   Reply With Quote
Old 09-13-2015, 11:50 AM   #76
Teraxx
My Ride: 2002 330Ci
So glad this post exists!!! -- I had the same sound (not like a cricket, but a high-pitched wheezy whine, almost like a buzzer that sounded 'off')....I'd start the car and immediately kept blowing out Fuse 28. Turns out the e-box fan was bad and causing a short. Ordered a new one (OEM, under 90 dollars at FCP Euro) and will perform this DIY this week.
<font size=3><font face=Lucida Sans Unicode>My 2002 330Ci</font></font>
Teraxx is offline   Reply With Quote
Old 09-02-2016, 04:09 PM   #77
lingon300k
My Ride: 2005 325xi Automatic
I did this today. I pulled out the fan and lubed it with Tri-Flow: http://www.triflowlubricants.com/pro...nt-drip-bottle
How were people adding grease to this fan? I had to drip the Tri-Flow under the fan itself to lubricate the motor shaft.
The sound is gone now, and I'm hoping it stays gone.
Thanks to samytampafl for the DIY!
lingon300k is offline   Reply With Quote
blower, cover
