Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 39 votes, 4.97 average. Display Modes
Old 01-28-2013, 10:43 AM   #481
mbadger
My Ride: E46 M3, E70 X5
Originally Posted by spurs51 View Post
Ok, let me know how you get on. You have got a subwoofer I take it ? My amp is connected only to the sub.
yup, amp and sub only connected to it.
mbadger is offline   Reply With Quote
Old 01-28-2013, 10:58 AM   #482
spurs51
My Ride: 316 ti
Have you used the loc with the B146? I have had this problem for weeks and my friend who installed the sub says the unit is at fault. I am sure there is a way to fix it. Sometimes when it cuts out I press the horn and it comes back on. In the mornings I turn the engine on and you can hear it through the sub and then it will cut out soon after then come back on when it feels like it.
spurs51 is offline   Reply With Quote
Old 01-28-2013, 11:01 AM   #483
mbadger
It's definitely an issue with the new head unit as I had my sub installed and working flawlessly prior to installation of the new unit. It does seem to have a mind of it's own. As you stated, comes and goes as it pleases.
Old 01-28-2013, 11:16 AM   #484
spurs51
My Ride: 316 ti
Did you used the loc with B146/Eonon D5113 ?
Old 01-28-2013, 11:22 AM   #485
mbadger
yes, that's what is tapped into my rear deck speaker to give me the RCA that connects to my Amp...in other words the only thing I did was to replace the head unit.
Old 01-28-2013, 11:37 AM   #486
spurs51
My Ride: 316 ti
Ok, lets hope we find a solution soon. I sure others must have had this problem, hopefully they will chip in and suggest what needs doing.
Old 01-28-2013, 12:17 PM   #487
mbadger
I'll let you know if the direct RCA from the head unit to the amp fixes it. Kind regards.
Old 01-28-2013, 02:42 PM   #488
spurs51
My Ride: 316 ti
Cheers
Old 01-30-2013, 09:33 AM   #489
mbadger
Cheers
Okay, pulled the radio this morning to do a couple of things:
1) connect the subwoofer rca (didn't realize it's mono single rca that works out for me, used the other to connect to the auxillary video out in case I want to use it later) - so far the subwoofer hasn't gone out once like it did with the LOC
2) connect my L (right angle) radio antenna - works great now
Everything is buttoned back up and no wires in sight anywhere, if anything goes awry with the sub hook up I'll let you know...love the fact I can turn the sub up, down or off now (wife factor+++).
Old 01-30-2013, 09:53 AM   #490
spurs51
My Ride: 316 ti
Ok thats good. So you saying you did'nt use a y-cable, just the single rca from the radio to the amp? Maybe I should give it a try. Did you heat shrink wrap the connections ?
Old 01-30-2013, 10:36 AM   #491
mbadger
Exactly, I run the amp in Mono anyway so I didn't need to put a splitter in, but it's always an option if I change my set up. no heat shrink, just electrical tape.
Old 01-30-2013, 10:58 AM   #492
spurs51
My Ride: 316 ti
Ok cheers, I will try that and let you know.
Old 01-30-2013, 11:04 AM   #493
mbadger
Thanks, Watching Man U or the Gunners today?
Old 01-30-2013, 11:10 AM   #494
spurs51
My Ride: 316 ti
No bloody way It will be Norwich v Spurs
Old 01-30-2013, 11:22 AM   #495
mbadger
Ok man, go Spurs. Later.
Old 01-31-2013, 05:37 AM   #496
spurs51
My Ride: 316 ti
I am happy to report that I followed your lead yesterday evening and took out the splitter cable from the HU end and connected mono to the sub out rca but I use another splitter cable at the amp end in order to use left and right channels. I also electric taped up the unused plugs. The result is the engine noise has gone and the system is sounding more powerful than before and I drove into work 14 miles this morning and no cut outs.
Old 01-31-2013, 05:48 AM   #497
mbadger
Awesome, enjoy! Cheers!
Old 01-31-2013, 06:09 AM   #498
spurs51
My Ride: 316 ti
Thanks man. I am thinking maybe the enco unit was not intended to be used with a splitter cable hence the single sub out rca or the splitter cable was faulty.
Old 02-28-2013, 09:07 PM   #499
josephtillman11
My Ride: 04 325i
Has anyone purchased one of these recently? (Within the last 2-3 months?) I'm curious if any improvements have been made. I spoke with Jolly yesterday and she informed me that the volume problem had been fixed but the random boot problem was still there. I asked for the current firmware version on the most recent units but she has yet to respond....looking to purchase soon but want to see if unit has improved.
josephtillman11 is offline   Reply With Quote
Old 03-01-2013, 06:33 AM   #500
Brevik
My Ride: Tiag M3
The best way to deal with the random boot is the power down the unit before you turn your car off.
Brevik is offline   Reply With Quote
