Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 01-28-2013, 03:11 PM   #15421
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by JZambrano7 View Post
So I woke up a coolant light this morning. Opened up the tank and saw it empty. Refilled it up but then noticed this. I just had the expansion tank replaced this summer. Should I be worried? I did notice a slight leak nothing crazy regardless taking it to the shop tomorrow
You need a coolant hose. That is not the OEM fitting. The OEM fitting is a molded plastic piece with an oring and a clip. That is a hose clamp.
Wait I'm a moron. That is the OEM hose, but you need a new one. That's gonna fail soon. Don't have the dealer do this. They'll charge you $200 for a 20 minute job and a $30 part.
Old 01-28-2013, 03:21 PM   #15422
JZambrano7
My Ride: 2003 325xi
Thank you for your response I did manage to do a little research on the part. But I'm not very good at DIY so I'm glad you confirmed it to me. I have a personal mechanic who's fair in his pricing, we'll see what he quotes me tomorrow.
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 01-28-2013, 03:23 PM   #15423
trj
My Ride: 325Ci
Upper radiator hose cracked.
Do not drive with the hose cracked like that.
You can get one from the dealership or from NAPA.
NAPA one will cost you around $30, dealership will cost you around $50. That was last year around this time.
I know because I cracked the same hose when I hammered the fanclutch nut and the wrench hit the hose.
Got one from dealership and one from NAPA to compare. I used the one from the dealership just to be safe and returned the NAPA one. But both looked the same except for the BMW marking.
Old 01-28-2013, 03:31 PM   #15424
JZambrano7
My Ride: 2003 325xi
The leak is minimal but I won't be moving the car until tomorrow. Don't want to risk it too much. I just hope it holds up on the way to the mechanic
-JZ7-
Old 01-28-2013, 03:31 PM   #15425
RKiepper
My Ride: 1999 E46 328I x2
Originally Posted by Hermes View Post
ah... didn't know that's what you were asking about. Why not just a thin coat of nightshades to darken it?
If I can find an amber tint to go over it, I'd go that route. The 'amber' I found was actually orange, and that shade I managed is with two layers.
RKiepper is offline   Reply With Quote
Old 01-28-2013, 03:41 PM   #15426
WDE46
Just watch the temp needle the whole way. If it so much as thinks about moving, pull over. The $100 tow will be worth it. You don't want to buy a hose AND a headgasket replacement.
Old 01-28-2013, 03:44 PM   #15427
tcphoto
My Ride: E92 335 MT Coupe
It's a $30 fix and takes about 30 minutes including clean up, testing and the first beer. Why pay someone to do such a simple task?
tcphoto is offline   Reply With Quote
Old 01-28-2013, 03:44 PM   #15428
trj
My Ride: 325Ci
Its not about the amount that is leaking right now, its about the air it has introduced to your cooling system. I'd advice against driving it.
Get a radiator hose from NAPA or dealership(a good idea to get a gal of coolant) and ask your mechanic to drive to you when he is free. It will take max 30 mins to replace including toping(or bleeding) coolant. Give him an hours worth of labor. Just 0.2 cents.
You will spend more if you overheat or even if you have to tow your car there.
You may get away with duct tape and coolant top up before you drive to your mechanic, but it will need a proper bleed anyway as air has been introduced to the system.
When I cracked that hose, I was in a friend's shop trying to DIY. I left the car there for a night and asked his employee to replace the hose later next day. I didnt even start it after I cracked it.
Old 01-28-2013, 03:55 PM   #15429
illestminimike
My Ride: Project Drama
Originally Posted by 777eThOd* View Post
Got tired of getting pulled over so much, so I got my front plates made and put them back on!
Please take off the eyelids and red angel eyes.
Old 01-28-2013, 03:55 PM   #15430
WDE46
Originally Posted by trj View Post
Just 0.2 cents.
You cheap bastard. You can't even give a full cent?
Old 01-28-2013, 03:58 PM   #15431
JZambrano7
My Ride: 2003 325xi
Yeah I hear you, I learned about all the consequences during my expansion tank replacement. I will def be on the look out.
If I had an idea of what I was doing I would be more than glad to, besides it's way too cold in NY to be outside working on your car. Rather take it to someone who knows what they're doing and who I trust.
Thanks for the advice, I will maybe try duck taping it and filling it up until Im at the shop. Sorry for the question but what is the problem with air entering the coolant system? Do i have anything to worry about until tomorrow?
-JZ7-
Old 01-28-2013, 04:02 PM   #15432
trj
My Ride: 325Ci
Yah, he was so keen on driving the car with cracked hose that I thought a full cent wasnt worth it.
Old 01-28-2013, 04:06 PM   #15433
trj
My Ride: 325Ci
No need to worry until tomorrow, but need to fix and get the air out of the system before turning over the engine.
If air is present in a sealed system your temp needle will go whacko and may over heat the engine.
Why risk it? Get a radiator hose and DIY or ask a mechanic or some fellow member near you to help you out. Pay him the amount you were going to pay for the tow.
Old 01-28-2013, 04:22 PM   #15434
WDE46
IDK it looks kinda cool.
Old 01-28-2013, 04:34 PM   #15435
My Ride: Lexus
Just ordered the last BMW structural foam in stock for the subframe reinforcement from Mike @ bmwpartstore. All I need now is seam sealer, mega's injection gun, a drill bit, and some nerves of steel as I undergo this intimidating project. Fairly simple but I don't want to waste $200 worth of foam :/
BMW part# 83190445721
I also hope no cracks had developed from the last time i "checked" the subframe area until now (couple months??)
Old 01-28-2013, 04:43 PM   #15436
///MPR77
My Ride: 02 ///M3 Tri-Ped
Let me know when you're going to do this, I would like to hang out and watch, or help.
Sent from my SCH-R530M using Bimmer App
Old 01-28-2013, 04:45 PM   #15437
My Ride: Lexus
For sure. Honestly I really have no idea what I am doing with this repair and could use an extra set of eyes. Too bad we aren't in Jersey
Old 01-28-2013, 04:48 PM   #15438
WDE46
Who needs that when you can just use "Great Stuff"? It's obviously superior for all applications.
Old 01-28-2013, 05:04 PM   #15439
My Ride: Lexus
Who needs that when you can just use "Good Stuff"? It's obviously superior for all applications.
I'm going to rehearse this and do a couple of "dry runs." i think i'll buy some cake batter and fill a soda can or something
Old 01-28-2013, 06:01 PM   #15440
100mileperhour
My Ride: 2006 330i Sport
I now have heat on my feet!!!!
While pulling my blower motor out and cleaning, I noticed that my fresh air blender was disconnected. Now when I press the controls in the cabin, I now control the air flow and temp! Yeah ME!!!!
Now, back to the garage and with these unseasonably warm temps for the next few days, I'm going to pull my rear brake pads off and lube up the guides. Seems the they are sticking a bit.
Full brake kit coming when I get my IRS refund!!!!
Sold 2000 323ci ZSP Sport Package 223,000 miles and climbing 140 miles a day!
For Sale- 1984 Porsche 944 N/A 132,000 miles/Speed Yellow
1991 Toyota MR2 N/A 113,000 miles/Aqua Marine Blue/Green
100mileperhour is offline   Reply With Quote
Rate This Thread
