General Off-Topic
Old 01-28-2013, 08:24 PM   #21
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
I figured it out.
Ok, one last problem. I need to pull the max value from two arrays and compare them. I've tried
Code:
max(sound) = s_max
Where sound is the array I'm pulling from but it doesn't work. It pulls values, but not the correct ones. I've also tried
Old 01-28-2013, 08:47 PM   #22
Saintluk2
My Ride: 2000 323i sedan
max_fps 200
Saintluk2 is offline   Reply With Quote
Old 01-28-2013, 08:52 PM   #23
v8 5
My Ride: 6 speed BMW
cmd_rate 15000
cl_updaterate 15000
Gutted with a Getrag
We have 4 websites within the family.
v8 5 is offline   Reply With Quote
Old 03-17-2013, 11:34 AM   #24
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Ok, who knows arrays?
I have two arrays, 1D and 2D. I need to plot plot the 1D on the X axis and the rows of the 2D on the Y. So for every X value, I have a row in the 2D array that should be plotted in the Y. I can plot the 1D against a single value from the 2D, but I keep getting a dimensional mismatch error when I try to plot the entire row against the 1D, and I'm not sure why.
Here I'm trying to plot a single row against the 1D array, the end goal plotting every row against every value in the 1D array.
Code:
plot(drive_force[0:j],theta[2,0:n])
drive_force is 1 x j and theta is n x j. Would it work if I transposed theta to j x n?
Old 03-17-2013, 12:45 PM   #25
Redline
Redline's Avatar
My Ride: ///M3 Vert
I can't math
k.
///M
Old 03-17-2013, 12:47 PM   #26
nikkeiS2K
My Ride: N/A
Send a message via ICQ to nikkeiS2K Send a message via AIM to nikkeiS2K Send a message via MSN to nikkeiS2K Send a message via Yahoo to nikkeiS2K
you need a nested for loop
nikkeiS2K is offline   Reply With Quote
Old 04-27-2013, 10:18 AM   #27
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
edit: Igore that, I figured it out.
So let's say I have a 2D array filled with integers of either 1 or -1. How could I assign each value a color and plot the array? For example, -1==blue, 1==red and I want to plot them as a grid showing the value of each point in the array.
Old 04-27-2013, 10:27 AM   #28
So Lowww
My Ride: E36M
Came in for the Counter Strike, saw math and almost shot myself
S T A N C E | W O R K S
So Lowww is offline   Reply With Quote
Old 04-27-2013, 11:52 AM   #29
z00
Banned User
My Ride: E46 M3 Manual
Iterate over each element of the array and assign a color, then plot the array. What's the problem?
z00 is offline   Reply With Quote
Old 04-27-2013, 10:31 PM   #30
nikkeiS2K
My Ride: N/A
First you need to iterate through the 2D array then you can either a) determine what element you are looking at and plot it as a certain color or b) assign each element a color value and then plot them.
Old 04-27-2013, 10:37 PM   #31
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
It was a lot easier than that. Python has a function that does it automatically
If any of you are interested, I'm running the Ising model on a 100x100 lattice and investigating how magnetizing certain parts of the grid affects the overall energy & mangetization
