Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 01-29-2013, 03:57 PM   #1
andy e46 318ci
My Ride: 318ci
accelerater pedal wont move
Help! !!!! Just bein driving my 318ci and it went dead got it started again but accelerater pedal wont go dwn no matterhow hard i press it any 1 have any ideas why
andy e46 318ci is offline   Reply With Quote
Old 02-17-2013, 04:29 AM   #2
129c
My Ride: BMW 318ci
Have you solved this? I know exactly why this has happened if not.
129c is offline   Reply With Quote
Old 02-17-2013, 06:16 AM   #3
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Sounds like you should inspect the accelerator cable.
E46 Coupe is offline   Reply With Quote
Old 02-17-2013, 03:16 PM   #4
129c
My Ride: BMW 318ci
The throttle flap will almost certainly be sealed shut with carbon. Same happened to me recently.
Old 02-21-2013, 03:06 PM   #5
dushant
My Ride: BMW 318i
Get under the hood and reach the screws at the end of the accelerator cable, slowly turn them till the metal cable inside has no slack. Do this while the engine is off. Once done turn the engine on and try to rev the engine by pressing the pedal hard, it should start working. This happens because of cruise control problem, you may have accidently turned it on. BMWs have trouble with stuck accelerator pedals because of them.
For safety reasons do it in an isolated area.
dushant is offline   Reply With Quote
