Go Back   E46Fanatics > BMW News from around the Web
Submit the latest BMW news from around the world for other E46Fanatics members to check out.
Thread Tools Search this Thread Rating: Thread Rating: 794 votes, 4.98 average. Display Modes
Old 06-15-2012, 02:26 PM   #821
dvsntt
My Ride: 01 325xi
Does someone have a PDF of the service bulletin for the sub-frame inspection? Tahnsk.
dvsntt is offline   Reply With Quote
Old 06-18-2012, 01:28 PM   #822
TrickTizzle
My Ride: 325i
Originally Posted by simsima325 View Post
^ i think you may have voided your warranty somewhere along the line...
Old 06-18-2012, 05:57 PM   #823
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 06-18-2012, 09:32 PM   #824
ice2003
My Ride: 02 330ci ZSP,ZPP,ZCW
Nice! How much did it cost ya? Just the plates or foam too?
ice2003 is offline   Reply With Quote
Old 06-18-2012, 09:56 PM   #825
2000_328CI
2000_328CI's Avatar
Just the plates and all welding required to reinforce everything
Old 06-20-2012, 10:46 PM   #826
WALKD U
My Ride: Just Fast!
I would foam it....
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 06-22-2012, 05:15 PM   #827
jdny516
My Ride: Oxford Green M5
my subframe went yesterday...turner kit on monday
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Frank Smith Tune
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
DINAN Front Strut Brace
Storm Motorwerks Products
2003 BMW X5 4.6iS | Black Sapphire Metallic | Black Sport | Titan Trim
2000 323Ci | TiAg | Gray | 5MT | SOLD My Progress Thread
jdny516 is offline   Reply With Quote
Old 06-26-2012, 04:08 PM   #828
2000_328CI
2000_328CI's Avatar
Originally Posted by TrippinBimmer View Post
I would foam it....
Is this something I can do?
Old 06-26-2012, 05:22 PM   #829
jdny516
this is what happened to mine.......currently being fixed at RRT
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
Old 06-27-2012, 08:53 AM   #830
2000_328CI
2000_328CI's Avatar
Wow yours also broke through a bit. Crazy to see how common an issue this is
Old 07-02-2012, 02:24 AM   #831
FLiprayzin240sx
My Ride: 2003 325it Wagon
Do wagons have this same issue?
FLiprayzin240sx is offline   Reply With Quote
Old 09-05-2012, 12:48 AM   #832
FreshMint
My Ride: 2000 323ci
Originally Posted by Scooby24 View Post
What's the consensus on why some cars are fine and others fail? Metal fatigue due to exposure to the elements? Driving habits? Bushings failing causing excessive movement at the mounting point?
I just cleaned up and thoroughly inspected my rear subframe mounting points and found no cracks or signs of failures. My car has 109k miles on with and was a florida car its whole life so very little exposure to snow/salt. All the rubber bushings on the car seem to be in unusually good shape given the mileage. I am curious to know if it's as simple as keeping up on the bushings to ensure the subframe is mounted securely with movement reduced as much as possible to ensure the mounting point isn't constantly being flexed.
This looks to me like classic metal fatigue and fracture propagation - and unfortunately looks to be due to a lack of proper fatigue analysis at this joint. The only preventative measures you could really take at this point are to somehow reduce the stresses in this joint, strengthen the joint, or harden the surface in an attempt to arrest any new cracks from nucleating and growing.
In all honesty, all these measures involve nearly the same amount of labor and effort as repairing the fracture once it occurs. The measures some BMW shops took to "fix" these issues by filling the cracks with a resin is completely stupid and no-more than a band-aid to the issue.
Stress concentrations that cause cracks to grow occur at the crack tips where plastic deformation occurs. Filling a growing crack with a substance only band-aids the issue while temporarily increasing the force necessary to open the crack, the stress concentration is still present at the tips and the crack will eventually continue to propagate.
So if you do end up getting the issue fixed - make sure the area is properly repaired with the sheet metal "kits" that are available, do NOT let BMW fill the crack with a resin or compound.
FreshMint is offline   Reply With Quote
Old 09-05-2012, 07:17 AM   #833
ShootyzGruve
My Ride: 2003 325i
You're a materials guy eh?
ShootyzGruve is offline   Reply With Quote
Old 09-05-2012, 06:21 PM   #834
7to3_enthusiast
My Ride: '02 AW 6spd M3
subscribed.
94 VR R2 Rx7 SOLD
02 AW/IR M3 MaxPSI 2(.5) PT 6870, 3.5" custom exhaust
14 CW 1.8T Beetle - Wife's dream car
02 4.6is X5 - The Work Horse
04 LSB M3 SOLD
7to3_enthusiast is offline   Reply With Quote
Old 09-06-2012, 11:44 AM   #835
FreshMint
My Ride: 2000 323ci
Sort of - I'm a stress/failure analyst. Materials guys are a bit more...microscopic. Usually working in labs developing and testing materials. Usually stress engineers are not working on the materials themselves, but the application of them.
Old 09-06-2012, 07:17 PM   #836
mattfarrington
My Ride: 04 325xi
Damn... I'm too late......
Luckily it hasn't cracked in my 325xi.
mattfarrington is offline   Reply With Quote
Old 09-21-2012, 02:56 PM   #837
Technik Dynamik
My Ride: 2004 325i Sport
In all my reading, I don't think I've seen any sedans that have been affected. It seems to be limited to coupes.
I wish I knew why, but if we knew then we'd know a whole lot else that isn't being disseminated.
Technik Dynamik is offline   Reply With Quote
Old 10-31-2012, 04:42 AM   #838
wardpower
My Ride: 99' 328i Sedan
My 1999 328i sedan was repaired by the dealer. I asked my service guy how many cars with the subframe mounting damage they've seen and he said they'd checked a few hundred and mine was only the third.
wardpower is offline   Reply With Quote
Old 01-30-2013, 04:12 PM   #839
AtlSully
My Ride: 2000 323i
I have a 2000 323i, manual. Just rolled 286k this morning on it. I had the repair completed last year.
AtlSully is offline   Reply With Quote
Old 01-30-2013, 04:18 PM   #840
casoeli2
My Ride: 99 323i 5spd
I had my 05/99 323i repaired may '11 at bmw's expense sans the "other" damaged parts from the frame tearing so bad. ~130k on the clock at the time
P.s. they did the whole floorpan repair
casoeli2 is offline   Reply With Quote
