Old 01-22-2013, 04:06 PM   #1
caleb6
My Ride: 2005 330XI
Beyond Maintenance
I think with the assistance of this site and the internet in general, most maint items can be done by the backyard hack mechanic, myself included. And I think most of the posts on these sites are related to those maint items.
With the help of youtube and step by step DIY's, just about everything is covered from simple oil changes to driveline bushings.
What I don't see are the more in depth items like internal engine component replacements. Is it because these items, like internal seals and rods and piston rings last a LONG time and should only be messed with when they fail, or is it just because they are too difficult to get to and replace?
I would think with the proper step by step procedure, they could be done, and the cars could go on for a LONG, LONG time.
What is the most common, in your opinion, failure item in this regard? Pistons, seals, rings??? Beyond the bushings, mounts, shocks/struts...things that are discussed on here normally. And what can we do to prolong those type failures - of course changing the oil with a recommended oil, stuff like that - but is there anything else?
Who are the Einstein mechanics out there that are holding back their secrets that we all need to know, that haven't posted them yet?
Oh well, thought this was an interesting topic so i posted it.
caleb6 is offline   Reply With Quote
Old 01-22-2013, 04:27 PM   #2
WDE46
My Ride: '13 128i, '04 330Ci
Those things only seem to fail with neglect. Not changing your oil regularly will cost you in later miles. Zchild has well over 300,000 miles on his engine and it's still going strong. Nothing needs to be done inside the engine unless you **** up...generally. Change your oil, keep you cooling system up to date (prevent overheats), and don't thrash your engine all the time (especially while cold).
As far as complex DIYs (like head gaskets or piston rings), I think you don't see them for several reasons:
1. They don't need doing very often
2. they take enough time as it is, pics/video only slows you down
3. small target audience (people who have also ****ed up)
Old 01-22-2013, 04:34 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I think Zchild has a new engine now, but his old one might have done over 300K. I'm only at 240K miles and haven't done anything inside the engine.
We need to change the oil?
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 01-22-2013, 04:43 PM   #4
My Ride: Lexus
http://forum.e46fanatics.com/showthread.php?t=899347
One of the forgotten contributors
Old 01-22-2013, 04:58 PM   #5
WDE46
That should be a sticky in general.
Old 01-22-2013, 05:00 PM   #6
caleb6
My Ride: 2005 330XI
Yeah, I do remember seeing this awhile ago. Very cool. Thanks for the reminder.
Old 01-22-2013, 05:07 PM   #7
wildirish317
My Ride: 2004 325Ci vert
OP, by the time I got married in 1984, I had overhauled (or helped my dad overhaul) the following: 1963 Volkswagen engine, 1968 VW engine, 1963 Chevy six, 1974 Chevy Vega four (twice), 1978 Chevette four, and a 1968 Corvette 327 engine. Since that time, I had a camshaft bearing spin on an '82 Datsun pickup, and had to pull the head and get it machined.
I guess what I'm saying is that they use better lubricants and better wear materials than they used to. The most mileage I've put on a vehicle was a 2000 Sienna which had 197k miles when I traded it in. The only engine issue it had was a leaking valve cover gasket.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
Last edited by wildirish317; 01-22-2013 at 05:12 PM. Reason: Changed bear to camshaft bearing
wildirish317 is offline   Reply With Quote
Old 01-22-2013, 06:48 PM   #8
caleb6
My Ride: 2005 330XI
That is a cool story. My daughter is turning 16 this April, and son will be 14 this year. He likes working on things with me, her not so much. But I've been thinking of picking up an E39 for them, and working on it with them to "restore" it. I'm by no means a mechanic or even really that experienced with the engine stuff, but redoing the normal maintenance items would be fun and worth it if I can find one in decent shape and obviously taken care of.
Old 01-22-2013, 07:33 PM   #9
wildirish317
I have three daughters, and none of them showed any interest in the mechanical side of automobiles. I might suggest an E30 as a project car. Lots of fanatics for that car, maybe moreso than the E46.
Old 01-30-2013, 07:36 PM   #10
caleb6
My Ride: 2005 330XI
Yeah, I meant to say E30. Easy to work on and reliable when taken care of.
Sent from my Galaxy 10.1 Tablet on bimmer app.
RIP Bach: 11/4/2003 - 3/9/2013
Old 01-30-2013, 08:50 PM   #11
dmax
dmax's Avatar
Well, the issue with the E30 is that its safety features are going to be a bit outdated. Airbags, explosive seat belt tensioners, abs, dsc/asc, and probably more technology into the design of crush zones and the like.
Just saying...easy to work on and reliable, but not as good in an accident. Sorry...something serious to think about. e46 is pretty good in that regard...although I'm sure newer models have more airbags hiding around.
Mangofy your E46!
Old 01-30-2013, 08:52 PM   #12
Johal E32
My Ride: BMW's
Yeah, pre 2000 cars have explosive airbags (I think).
Johal E32 is offline   Reply With Quote
Old 01-30-2013, 08:54 PM   #13
caleb6
My Ride: 2005 330XI
Good info. Thanks for adding DP's. :o
Old 01-30-2013, 09:16 PM   #14
dmax
dmax's Avatar
My '92 e36 just had one in the steering wheel, but not on the passenger side.
The e30 goes back to, what, mid-80's? It had a long run iirc, didn't it?
Anyway...just something to think about, especially with kids in the car.
Mangofy your E46!
