Old 01-08-2013, 10:00 PM   #1
jknutter
My Ride: 2002 325Ci
Replacement Rubber boot
I installed LED Angel eyes on my Bi-xenon lights and now have the dreaded fogging problem with my left headlight. I've had apart about 1/2 a dozen times and cannot figure out how the moisture is getting into it. I've even gone as far as using silcone to reseal the lens in place. Anyway the last time I had it apart I tore the rubber boot that is on the rear of the assembly on the high beam fixture.
Does anyone know where I can find a replacement for it?
jknutter is offline   Reply With Quote
Old 01-23-2013, 05:13 PM   #2
sillieidiot
My Ride: '06 AW 330ci
tearing that boot wouldn't affect anything as it's in the engine bay pretty much. if you're having fogging problems, most likely the headlight gasket is the one you need to replace. it's the rubber piece that the headlight lens touches on the headlight.
Old 01-30-2013, 11:42 AM   #3
jknutter
My Ride: 2002 325Ci
I figured out my problem. One of the locating tabs for the lens got folded into the gasket so it was pinched between the lens and the gasket. I don't know how I missed that..... Even the silicone didn't fix that one. I did order and installed the high beam boot because the old one was torn wide open. Enjoying my fog free HIDs!
Old 01-31-2013, 12:13 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
^ I was just about to say that. The most common issue with condesation after the lenses are removed.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
