///M3 Forum
Old 05-30-2012, 01:00 AM   #21
Rockyminator
My Ride: :)
Originally Posted by n3985 View Post
Because they sell the diff fluid WITHOUT FM booster too.
What he said! ^^
HPF Stage 2.5 BMW M3
Rockyminator is offline   Reply With Quote
Old 05-30-2012, 05:32 AM   #22
dafoe
My Ride: LSB M3
OP, OEM Diff fluid ALWAYS!! That stuff it liquid GOLD!
2001 M3, LSB 6spd, purchased 6/09 with 25K miles.
Mods: Coyne Performance built ///M3
dafoe is offline   Reply With Quote
Old 06-02-2012, 07:37 PM   #23
nyredeye21
My Ride: 2003 E46 M3
Thanks for all the replies. I bought that kit from ecs tuning and I got it but some of it leaked out. I will most likely change it tomorrow
nyredeye21 is offline   Reply With Quote
Old 06-03-2012, 07:54 AM   #24
duramax
My Ride: 2002 BMW M3
diff fluid
redline 75/90
duramax is offline   Reply With Quote
Old 06-05-2012, 08:44 AM   #25
hassmaschine
My Ride: '91 325ix
if I had an M3, royal purple products wouldn't come anywhere near it..
really - how often do you have to change the diff fluid? maybe 3-4 times over the life of the car? I feel the same way with coolant. Yeah, it's an extra $20 for the BMW stuff - but that's spread out over two years. I've seen the damage from using cheap fluids and it's just not worth it. BMW stuff is formulated exactly for your car, you don't have to guess or hope it will work.
hassmaschine is offline   Reply With Quote
Old 06-06-2012, 07:31 PM   #26
dafoe
My Ride: LSB M3
FWIW, I have 391 gears recently installed, they used non OEM diff fluid, and it made noise, added the OEM with FM booster, no more noise, AT ALL! I'm telling you guys, the stuff is unmatched!
Old 01-23-2013, 12:47 PM   #27
TopazID
i apologize for bumping such an old thread.. but has anyone tried the Redline Limited Slip Friction Modifier?? If so, any thoughts or reviews about it?
I recently changed my diff fluid with RL 75W-140 and i started hearing the whine. My shop recommended this:
http://www.redlineoil.com/product.aspx?pid=41&pcid=4
TopazID is offline   Reply With Quote
Old 01-25-2013, 03:23 PM   #28
TopazID
Originally Posted by PowerM3 View Post
I used royal purple and had noise from my diff. Do yourself a favor and use OEM!
I used readline 75w-140 and it made loud chattering, whining noise. Swithed back to OEM expensive but it fixed the problem
Old 01-25-2013, 08:21 PM   #29
46smg
My Ride: 2003 M3
Exactly, expensive but at least you know it fixes the problem the first time. Somethings you can use aftermarket, but somethings you just stick to oem.
46smg is offline   Reply With Quote
Old 01-31-2013, 02:32 PM   #30
KhanArt
My Ride: 04 M3 JB/Cinn
+1, OEM trans, diff, oil..
2004 Jet Black/Cinnamon 6spd ///M3
Build///Journal
Tuning Tech Frank Smith /// Custom Performance Innovations /// Active Autowerke
IG: Khan_Art_
KhanArt is offline   Reply With Quote
Old 02-01-2013, 09:45 PM   #31
emax
My Ride: 06 M3
OEM! I used a few years ago and its still good. The BMW limited slip diff is very picky and likes the FM booster...and no you can't by the booster by itself. If you swap the locker, you can use different fluid.
'06 CB/IR w/SMG/NAV/HK/19" BBS RGR/Hankooks
emax is offline   Reply With Quote
Old 02-01-2013, 10:20 PM   #32
M3 FOR LIFE
My Ride: BMW M3 E46
Use oem only...
M3 FOR LIFE is offline   Reply With Quote
Old 02-02-2013, 10:11 AM   #33
KhanArt
OEM.. I put that sh1t on everything!
Build///Journal
IG: Khan_Art_
Old 02-02-2013, 11:08 PM   #34
Prdquik
My Ride: 04 M3 Coupe
Now that's funny.
Prdquik is offline   Reply With Quote
Old 02-05-2013, 08:08 AM   #35
Ridnfly
My Ride: 01, Imola, 6MT, vert
I had this same issue with 75-90, went with OEM and all is well. Expensive lesson.
Ridnfly is offline   Reply With Quote
Old 02-05-2013, 09:35 AM   #36
KashM3
My Ride: ///M
YES! FRANKS.....
made my morning
OP: OEM + FM. Why risk the chance of strange noises...
S14.NET O.G. S54 E30 ///M3
Mike Rad boosted avus e36
AW E46 ///M SMG
Still on the hunt for a low mileage 997 GT3.2 !Herro Rennlist....
KashM3 is offline   Reply With Quote
