E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 07-25-2011, 10:00 PM   #41
Itadienekes
My Ride: 2002 BMW 325xi
Here's an attempt at showing how it currently looks, after pushing in the new axle:
Small gap, not sure wtf is going on there:
Another angle
Last one:
Thanks!
Itadienekes is offline   Reply With Quote
Old 07-26-2011, 07:46 AM   #42
Kubica
My Ride: 2003 325xi
That looks fine as long as the snap ring is engaged.
The first photo looks like the cv joint separated a bit, which you should avoid doing.
Old 07-26-2011, 11:43 AM   #43
hammerheart
My Ride: 02 330XI
I have differential oil leakage on both left and right side after the axle replacement. I used genuine shaft seals and re-man a1-cardone axles. Is the leakage from the seal, or the axle mating surface, or the assembly process?Thanks.
hammerheart is offline   Reply With Quote
Old 08-06-2011, 01:40 PM   #44
Itadienekes
BUMP.
I've finally received the last missing parts and I'm putting things back together.
Now I'm a little paranoid. I pushed the left side axle back into the hub, and it rotates fine when the whole assembly is straight, but when I turn it to an angle, the CV/axle has a very hard time rotating - is it something that will work itself out with a little use, or did I separate the joint, as mentioned above, and not put it back together properly, and now it's stuck?
How do I put a separated joint back together if that's the case?
Old 08-06-2011, 10:45 PM   #45
BLAU III
My Ride: eat's cars.
Thanks!
I just got done with this job. i had the exact same question with the cardone axles. I finally said (after 3 beers and an hour of trying different ways to get it in) let's button it back up and see if it works... no issues what so ever.
Originally Posted by CollinsE90 View Post
I would battle a pack of wolverines in a porta potty with my hand tied behind my back, yielding nothing but a shake weight taped to my forehead, just to hear her fart over a walkie talkie.
BLAU III is offline   Reply With Quote
Old 08-08-2011, 10:42 AM   #46
markusvt
My Ride: 330xi
Same issue, I am pulling it and putting in the Leobro axle.
markusvt is offline   Reply With Quote
Old 08-08-2011, 12:15 PM   #47
Itadienekes
Phew!!! What a job... not to discourage anyone, but there's a lot of hidden extra work that comes with CV/axle replacement when a) the car is old and rarely been worked on and b) you've never done it before. Lots of seized on bolts & nuts, rust & grime to remove, lots of hammering to get axle out and back in, lots of wondering if you're doing it right when there's tiny gaps that turn out not to matter when everything's back together.
Overall AWESOME experience, and the car is 100% better now! So stoked. I took a few pictures here and there, I'll try to post a short write up. In short, I ended up doing a whole front-end workover: new cv/axle left and right, new left and right lower control arms, new inner ball joints, new tie rod ends, new sway links, new control arm polyurethane bushings, MAJOR cleanup of the CV-boot-grease mess. Stoked!
Old 08-10-2011, 03:02 AM   #48
jerryscott
My Ride: 2002 325xi
here is a video now that you mentioned seized bolts and stuff, i did this video by popping the ball joint to install the axle
jerryscott is offline   Reply With Quote
Old 12-11-2012, 11:08 PM   #49
Sammy325xi
My Ride: 05 325xi Dark Green
I have same issue 05 325xi driver side inner boot leaking I'm debating if to fix just the cv boot or replace the whole axle with a GKN oem supplier from PelicanParts.com
Sammy325xi is offline   Reply With Quote
Old 12-12-2012, 06:44 PM   #50
Itadienekes
^^ I'd say it depends on how long it's been leaking and how many miles are on the axle. If the boot's been busted for a while, don't take the risk, just replace the axle, it doesn't take any longer.
Just found out my passenger side outer boot is busted, AGAIN. ~14 months since I replaced it with brand new reman'ed Cardone one. Argh.
Old 01-31-2013, 02:46 PM   #51
flashgordon1027
My Ride: harley
KUBICA
Thanks for your input/fix/and parts your replacement of the front axles on the xi and parts list is extreamly precise .i was shop foremen at Wide World of Cars and could not have researched this as fast as i found it in Your post Great Job Flash Gordon BMW Master Tech 16 years.
flashgordon1027 is offline   Reply With Quote
Old 12-29-2013, 01:07 PM   #52
Chilton88
My Ride: 325ci, 325xi
Thanks for the write up
Chilton88 is offline   Reply With Quote
Old 12-29-2013, 01:33 PM   #53
Sammy325xi
Re: 325xi Front CV/Axle Repair
@itanekes it has been leaking for like 5 months and the car has 93k on it where can I find cheap brand new replacement axles passenger side anyone $100-$250 range
Sent from my SPH-L720 using BimmerApp mobile app
Old 12-29-2013, 06:47 PM   #54
Chilton88
Why not read the forums...it says pelican parts or Rock Auto...
Old 12-29-2013, 06:53 PM   #55
Sammy325xi
@chliton88 cause I wanted to see if you guys knew of any other I usually buy from pelican parts or Bavauto or Northside auto parts
Old 01-02-2014, 05:27 AM   #56
Chilton88
Replaced the left front with Cardone from Rockauto, and they are clunking and vibrating even at low spreads. Anyone have this issue?
Old 04-24-2015, 01:12 PM   #57
awszach
My Ride: 2001 BMW 325xit5mt
awww man.
(pelican parts)
front left axle assembly
GKN Loebro (oem supplier) $272.25
USA Industries $84.25
Im all about putting quality into my car but damn thats a good price difference. 323%.
awszach is offline   Reply With Quote
Old 04-24-2015, 01:36 PM   #58
markusvt
My Ride: 330xi
You want it to last 10k or 100K miles? You decide.
Old 04-24-2015, 08:00 PM   #59
mp333
My Ride: 2003 325XI
^+1. Go
GKN or expect to replace often. The other option is to have you original rebuilt at a local shop. I had mine rebuilt locally for $80 per axle.
E46 & E90 Rocks
mp333 is offline   Reply With Quote
