Go Back   E46Fanatics > Everything Else > The Off-Topic > Health & Fitness
Health & Fitness
Discuss any topics related to heath and fitness here.
Old 02-01-2013, 06:41 PM   #1
z00
Banned User
My Ride: E46 M3 Manual
Squats and deallifts misc questions
1- Squatting and deadlifting barefoot feels much more natural. What do you think? After I tried it once last year, I never squat or DL with sneakers.
2- What to do as my DL weights get heavy? I still can do more reps but my wrists and forearms are getting tired. I read using straps is not good long term and for overall natural muscle development. I do use the inverse grip (palms facing each other)
z00 is offline   Reply With Quote
Old 02-01-2013, 06:52 PM   #2
B_Cyrus
Banned User
My Ride: Malfouf
1. I agree, I am the usually the only guy in the gym doing squats/deadlifts in the gym without shoes. I really only do it because I slip around in my shoes.
2. I am dealing with the same issues. Anything above 400 and my grip starts to go haywire.
B_Cyrus is offline   Reply With Quote
Old 02-01-2013, 07:02 PM   #3
z00
Banned User
1- Good to know. I get some funny looks from people but who cares.
2- My grip gets weak around 285, I weigh 165
Originally Posted by B_Cyrus View Post
1. I agree, I am the usually the only guy in the gym doing squats/deadlifts in the gym. I really only do it because I slip around in my shoes.
Old 02-01-2013, 07:10 PM   #4
dabears
My Ride: 2003 BMW M3
I squatted barefoot before I started using my very flat Lacoste shoes.
Try an alternating grip (dominant palm facing, other out)
I'm not at the point where I need straps/chalk and I have similar numbers
dabears is offline   Reply With Quote
Old 02-01-2013, 07:11 PM   #5
DylloS
My Ride: nothing
I used to squat barefoot but now since my floor is ice cold I do it in my minimalist new balances.
As for the grip. Try over under or chalk.
DylloS is offline   Reply With Quote
Old 02-01-2013, 07:11 PM   #6
sadpanda03
My Ride: 2003 330i
Barefoot is probably the best you can do. Or use chucks if you want shoes. The more flat your feet are the better. It forces you to use your musles in your legs.
I use Nike frees because I am flat footed and they provide good arch support, forcing a proper footing.
Its pretty sad how few people do squats and deadlifts, they are among the most important lifts to gain size and overall body strength.
Sent from my HTC One X+ using Bimmer App
sadpanda03 is offline   Reply With Quote
Old 02-01-2013, 07:13 PM   #7
sadpanda03
My Ride: 2003 330i
Do you use wraps? I'd recommend them if your grip starts to slack on the higher weights. Or you can try tucking your thumb under your fingers instead of on top. It is sort of awkward at first but you get used to it.
Old 02-01-2013, 07:25 PM   #8
Sensi09
My Ride: __
Always plan to get some new flat workout shoes, but always end up buying shoes that I'd wear out instead.
Anyhow, I use a running type of shoe and really no problems. I've taken some videos when I DL and can't visibly see any compression and notice that I'm more on my toes (not sure if that's bad form). One thing about flat shoes or bareboot, is that when you compare to actual weightlifting shoes, the dedicatied weightlifting shoes typically have a heel and are not flat.
Had some big grip issues before switching to over/under. Now my grip isn't the issue....just the weight doesn't get off the ground sometimes.
Sensi09 is offline   Reply With Quote
Old 02-01-2013, 08:22 PM   #9
z00
Banned User
That's the grip I use and I inverse the grip on every set to keep grip balance
Since you have similar numbers, when I get to 4th-5th rep my wrists and arms just pretty much lose all strength. The rest of my body still has strength in it to do a couple more reps. Don't you have this issue?
I don't use wraps. I read for safety reasons and over all grip strength it's good to have a natural grip (thumps on top).
I tried with my Taek Won Do shoes (very flat) and I still find barefoot most natural and best feeling while squatting and deadlifting. I can get the bar off the ground fine, it's just in the last few reps where my grip and arms give up
Old 02-01-2013, 08:29 PM   #10
dabears
nope no grip issues, my PR is 315 x 1 and it was my legs that failed me on the second rep attempt getting off the ground.
deadlifting, chinups/pullups will greatly improve your grip strength over time
Old 02-01-2013, 08:34 PM   #11
z00
Banned User
How long do you keep the bar on the ground? For max weights I see some guys bouncing the weights off the rubber mats. It's hard to explain but pretty much the bar touches the floor and comes back up right away. Forgot the the technique's name.
Old 02-01-2013, 08:34 PM   #12
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
My grip failed at 525
BreakMyWallet is offline   Reply With Quote
Old 02-01-2013, 08:40 PM   #13
B_Cyrus
Banned User
My Ride: Malfouf
Old 02-01-2013, 08:41 PM   #14
dabears
my reps are very controlled, i lock out at the top then bar touches body all the way as I "sit" back down, I let weight rest on floor and then start next rep.
The weight doesn't sit on floor for more than 2-3 seconds, enough time to set myself again / adjust my grip. No added momentum.
Old 02-01-2013, 09:01 PM   #15
sadpanda03
My Ride: 2003 330i
Thanks for letting me know about the thumb placement. Didn't know it was bad!
Old 02-02-2013, 09:53 AM   #16
z00
Banned User
Also for bench and any other grip, thumps on top is better and safer.
Old 02-02-2013, 09:54 AM   #17
z00
Banned User
I don't do any dedicated forearms exercise. Do you? Maybe I should start to improve grip strength.
Old 02-02-2013, 01:15 PM   #18
AmazingNutz
Banned User
My Ride: carpet
Does anyone DL using the Sumo posture? I switched over from the traditional position because it was hurting my back, maybe I had bad form.
Back on topic, I work out at home and squat and DL with house slippers. I'm gonna try barefoot because I slip and slide a little with the slippers.
Sent from my G6
AmazingNutz is offline   Reply With Quote
Old 02-02-2013, 01:20 PM   #19
dabears
Deadlifts should fatigue the back, but not cause pain. Out of the big 3 (squat/benchpress/deadlift) I personally think its the hardest form to learn, and when I see people deadlifting almost 99% of the time there is something wrong with their form.
Sumo is more leg intensive, and as you found out, takes away from the "back" part of the exercise. Stick to squats and romanian (stiff legged) deadlifts for quad / hamstring development and deadlift conventional with proper form to get a ripped back.
Old 02-02-2013, 01:25 PM   #20
Act of God
My Ride: Longboard
Send a message via ICQ to Act of God Send a message via AIM to Act of God Send a message via Yahoo to Act of God
I've been working forearms 2x a week whenever I can fit them in, got wicked bad golfer's elbow. Be careful.
"If you reject laissez faire on account of man's fallibility and moral weakness, one must for the same reason reject every kind of government action." Ludwig von Mises
Act of God is offline   Reply With Quote
