Auto Trans doesnt engage - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 01-30-2013, 05:12 PM   #1
RidwanKazi
My Ride: 2004 E46 330xi
I have been having issues with my 2004 330xi not getting into gear when i shift to Drive. I have an automatic transmission and just baught the car a month ago. This issue has happened two times in the same manner. I park my car in the garage and in the morning (usually very cold due to me living in the Midwest) I turn the car on, warm it for a few seconds, shift it to Drive, and go but i ieither dotn move and my engine revs up or i go really slow (also my speedometer does not move at all). The problem goes away after a little while or if shift to the steptronic option and gear down or up. Anyone have any input?
RidwanKazi is offline   Reply With Quote
Old 01-30-2013, 05:48 PM   #2
SamDoe1
My Ride: 4cyl of fury
Change the transmission fluid and filter. It's cold, most auto transmissions act sluggish in the cold.
Old 02-02-2013, 09:32 PM   #3
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
Check trans fluid level
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-03-2013, 04:38 PM   #4
shadow 2
My Ride: 07 328i
Would not expect your speedometer to move if your car is not. I have same issue. Too cold to check level and no jack stands to get under the car. Will try to find out in the next few weeks if more work is needed.
shadow 2 is offline   Reply With Quote
Old 02-06-2013, 12:01 AM   #5
wedge39
My Ride: 2003 325xi
If it only happens when you start the car and try to go for the first time, it's a known e46 issue. I had it on my 2003 325xi AT. There is a bulletin (not a recall) out there for it. Dealership reprogrammed computer for a little over $150 and issue went away. It's likely always been like that, and as far as I know it won't cause any problems to leave it that way, you just have to rev it twice sometimes.
wedge39 is offline   Reply With Quote
Old 02-06-2013, 08:01 AM   #6
shadow 2
My Ride: 07 328i
Like you, I am very hesitant to rev my car when cold in sub freezing weather. Will call dealer and see if the software can be updated.
Old 02-06-2013, 10:46 AM   #7
SamDoe1
I wouldn't wait that long. If fluid level is low, lots of bad things could be happening in there. I recommend taking it to a shop to have it looked at if you can't do it yourself.
Old 02-06-2013, 08:21 PM   #8
redbull 325is
My Ride: 325xit/6
i've got a spare trans from my swap
Old 02-07-2013, 10:32 PM   #9
shadow 2
My Ride: 07 328i
Curious how the tranny can get low on fluid in a closed system with no leaks. I changed fluid and filter about 50k miles ago. Mine runs fine if temp above 37 or so. My indie thinks it just needs a software upgrade for more internal pressure at start up.
