Australia
Old 02-04-2013, 12:53 AM   #1
gabileung
My Ride: 330ci
FS[SYD]: Bilstein PSS10 B16 RideControl CoilOver n Other suspesion bits
Hi guys
for some reason the old thread no longer existed in AU section. (but appear on googel seach tho)
anyways price update for quck sale.
was asking $2500, now $2000ono
for E46 non-M
come with 12mm shock mount upgrade kit to accomadate the EDC wiring.
this is brand new just unboxed to check item upon arrival.
part#GA5-D512-H0.
grab yourself a bargin if you looking for a set or similar simply upgrade.
The RideControl can electronically adjust the preset damper.
The adjustable spring perch which lowers your non-M e46 between 30mm and 50mm from standard ride height.
import a new set will easily set you up 1k+ for shipping/import duties/taxes etc. for what I'm asking.
other e46 part for sale as well:
item description |part number
$150 Front Strut Top Mount & Bearing (L+R) |31336769582
$100 Control Arm bushes (pair)
$600 OEM M-Tech control arms (L+R) |31122282121/31122282122
$200 tie-rod comeplete (L+R)
$150 OEM Steering Swivel & universal joint (lower) |32306761571
$150 OEM Pulse generator, camshaft (exhaust side) |12147518628
$400 Power Steering pump(LF-20 ) |32416760034
various PS pump hoses and CCV hoses
Brembo 4 pot brake kit (E36)
additional pics available upon request
happy to post interstate at buyer expense
will consider reasonable offer with multiple items
cheers
gabileung is offline   Reply With Quote
