Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 01-29-2013, 05:21 PM   #961
Stinger9
My Ride: '04 330Ci
Originally Posted by 7xWDC-MSC View Post
There isn't anything in the cooling system that will eat copper.
+1
Used to make radiators out of copper tubing, and anti-freeze has always been ethylene glycol.
Old 01-29-2013, 05:55 PM   #962
My Ride: Lexus
coppers fine. put car on ramps to bleed is best. drive it up on ramps w/ or w/o coolant. doesn't matter
Old 01-30-2013, 06:32 PM   #963
SeattleLSB
My Ride: 2003 330XI, 2003 M3
Got the thing out what a pain my my you know what. Tried for an hour and lost the bolt in the subframe. Special order part from BMW! I'm hoping I can get it back in so I can complete the overhaul. The XI's engine drain location is so hard to get to.
Mango, I've read some post that you state to install the Expansion Tank and Bracket onto the Radiator before installing. Have you done this for the AT yet?
The car really needed the overhaul, all parts appears to have 05/06 dates but the pulleys/idlers were so worn you could see where the belt was imprinted into the pulley!
Joe
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 01-30-2013, 06:46 PM   #964
My Ride: Lexus
I ordered a new INA pulley. mine had developed some play in it after 30k miles. kinda dissapoint
Old 01-30-2013, 08:33 PM   #965
SeattleLSB
Not sure if I follow. Can you confirm I should put the new exp tank bracket, tank ontot he radiator before I put the radiator into the car is it easier?
Joe
Old 01-30-2013, 08:37 PM   #966
caleb6
My Ride: 2005 330XI
I would put the bracket on first, then install the radiator, then the ET. I just did this two weeks ago. But really, once you have it apart, you can see what works best for you.
Sent from my Galaxy 10.1 Tablet on bimmer app.
RIP Bach: 11/4/2003 - 3/9/2013
caleb6 is offline   Reply With Quote
Old 01-30-2013, 08:48 PM   #967
Stinger9
My Ride: '04 330Ci
+1 for the way you did the job.
Old 01-31-2013, 12:26 AM   #968
CrazyOneToo
My Ride: 1999 328i 4dr
I agree. I did it that way with mine and it seemed easier than finding how to re mount it by feel or flashlight.
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
Old 01-31-2013, 05:51 PM   #969
TonyJ
My Ride: E46 330i
What brand is your old pulley?
TonyJ is offline   Reply With Quote
Old 01-31-2013, 06:07 PM   #970
My Ride: Lexus
BMA said F.A.G.
Old 02-02-2013, 08:54 PM   #971
always-there
My Ride: 2002 BMW 330I
So can a bad coolant temperature sensor cause sluggish acceleration and cause a fan clutch to engage more often, Mango?
Old 02-04-2013, 01:29 AM   #972
ClaytonL
My Ride: 2003 325i
I have an INA tensioner and a Meyle deflection pulley that I had replaced when doing my cooling refresh 31,000 miles ago. When doing my normal inspection this weekend I noticed my pulleys both had play. The INA had more than the Meyle. Actually, INA kept spinning. Decided not to order anything less than OEM, I'll be happily inspecting/replacing these every 30,000 miles or every year for me from now on. I feel these should be inspected by everyone sooner than every 60,000-80,000 miles for the cooling system.
ClaytonL is offline   Reply With Quote
Old 02-04-2013, 10:28 AM   #973
My Ride: Lexus
That's true. I agree. By play do you mean spinning like a skateboard play or back and forth play like if you wiggle it? mine was wiggling a little bit in addition to some dry sounding spinning action (though not that bad)
I feel these pulleys start feeling dry after about a month or so of use. maybe they can use some better grease packed into them? like Redline CV2? would be afraid of damaging the seal though.
Old 02-04-2013, 10:29 AM   #974
My Ride: Lexus
Not really sure. I've never had one go bad on me. It's so cheap to replace, I don't question it. Just replace it
Old 02-04-2013, 02:24 PM   #975
ClaytonL
My Ride: 2003 325i
I have both the back and forth play as well as the dry skateboard wheel feel. For the record, the INA doesnt have any play but was REALLY dry and kept spinning for about 4 seconds. The Meyle had enough play to cause an audible click when wiggling but did not keep spinning as much as the INA. Both had that dry bearing sounds when I messed with them. To me, the INA held up better since I'd rather have zero play in my pulleys.
I thought about greasing them but I'm worried about their integrity once they are on the car again. I'm scared they might come apart on my daily commute and I live too far to be worrying about that all the time. When I get my new pulleys I will try and take apart the old ones and see about the greasing. For now, just replacing the pulleys every 30,000 miles is good enough insurance for me. Maybe Genuine BMW pulleys will hold up longer? Better quality INA? I don't really know...
Old 02-04-2013, 02:41 PM   #976
Stinger9
My Ride: '04 330Ci
Pulleys too cheap to grease.
Consequences too large to not replace with new.
Old 02-04-2013, 03:28 PM   #977
My Ride: Lexus
no no. i'm talking greasing them brand new out of the box with higher quality grease.
Old 02-05-2013, 10:27 AM   #978
My Ride: Lexus
Bleed video: (can a mod put it in the bleed part of the post?)
Old 02-05-2013, 04:07 PM   #979
NickBMW
My Ride: 2001 BMW 325i sport
bleeding cooling system
mango where is the drain bolt to drain out old coolant?
NickBMW is offline   Reply With Quote
Old 02-05-2013, 04:13 PM   #980
My Ride: Lexus
above passenger side engine mount
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
