Car Care & Detailing
Get detailing answers and tips here |
Rating:
#3261 |
My Ride: '06 M3 Coupe
Greg, not sure if these questions have been asked (i.e. i did not read the entire thread), but i have a few:
1. what do you recommend that is 100% safe to clean anodized wheels? i was planning on using a dilution of p21s total auto wash on the wheels when they are cold 2. what do you recommend for protection/sealant for the wheels? i was told that prima wheel armour is safe. i have a brand new bottle of that. i had used poorboy's world wheel sealant on clearcoated wheels in the past and was happy with the results/protection. i was also told that this product is safe for anodized finishes/surfaces. 3. what wax do you recommend for the painted surfaces under the hood? i am looking for a high temp wax. so far, i have only confirmed auto finesse mint rims wheel wax as being one. tia. |
#3262 | |
I apologize I didn't get to this thread sooner! I'm going to answer some of the more recent questions now. If you ever need a quicker response please e-mail us at support at detailed image dot com.
Greg @ DI
#3263 | |
Greg @ DI
#3264 | |
Greg @ DI
#3265 | |
It's always hard to tell from a picture but I'm optimistic you can make a big improvement in the finish of the paint. A small portion of the scratch looks a bit too deep, but again hard to say. I would highly recommend you wash and clay the surface to help clean it. Next start off with a light polish like the Meguiar's Ultra Finishing Polish M205 but most likely you'll need to move up to the Meguiar's Ultra-Cut Compound M105 to remove more of the imperfections. Follow up the M105 with the M205 to remove any haze left behind and that area should look significantly better. Good luck! Greg @ DI
#3266 | |
1.) I would avoid cleaning those wheels in direct sun when possible, because often times the mineral deposits in water can leave residue behind or tech in to the wheels as it dries. If you do work in direct sun rinse them frequently. For maintenance cleanings soap and water is just fine. When you need a stronger cleaner the SONAX Wheel Cleaner Full Effect is top notch and it should be safe on all finishes including anodized wheels. To be safe I still always recommend testing a small area with any new product on any new surface. The P21S Wheel Cleaner should also be safe on those wheels, but I haven't use P21S TAW on them to say for sure. 2.) I haven't used Prima so I don't have any experience to share there. For normal protection the Poorboy's World Wheel Sealant is top notch! It is very resistant to high temperature brake dust and it should help contaminants rinse clean. Another option has recently come about for wheel protection called the 22ple VM1 Rim and Metal Coating. This stuff is incredibly strong and resistant to contaminants and brake dust. It should protect the wheels for a year or more! It's more expensive but it does work really well and the wheels look great afterward. 3.) Sealants are far more resistant to heat than any natural wax, so I'd highly recommend a sealant for under the hood. If you have a sealant handy you can certainly use that. If not the Klasse All In One (AIO) is one of my favorites, it's very durable and it helps clean while protecting. Greg @ DI
#3267 | |
gotcha on not cleaning in direct sun. i never do but this is a good reminder ![]() i already use sonax for wheels, so i am set there. i have used poorboys wheel sealant before on clearcoated wheels and loved it. i try as sealant on the anodized wheels. yeah, i actually was gonna ask about 22ple. as far as you know, is it safe on anodized finish for sure? i was not able to get a confirmation on this. i have menzerna power lock but also have lots of klasse AIO left. i can use the latter. thanks again. |
#3268 |
What are your thoughts on the drivethrew brown bear car washes?
Sent from my SGH-T959V using Bimmer App |
#3269 |
Whats best way to remove scratches in clear coat?
Sent from my GT-P7510 using Bimmer App |
#3270 |
Hello Greg
I have a black sedan and was wondering what would be the process of meguair products I should use? How is meguairs ultimate compound?
#3271 |
M105, M205, then what?
Greg,
My BMW 330Ci TiSilber looks fine but I'd like to take it to the next level as far reflectivity and clarity. So, what should I use? 1800 grid wet paper? Thanks, Mark |
#3272 |
Hi. I am painting my car doing a full co lour change from topaz blue to ford frozen white with blue pearl through the clear coat. i am aware that you cant wax the car for a certain time. im wondering is it still okay to snow foam it and hand wash it and what products can i put on to protect the paint and give off a nice lasting shine?
thanks Robaidh |
#3273 |
Hi D.I., I'm sure the answer is in this thread, but even with a search I couldn't find it. I recently purchased about everything I need for wash/dry and polish (foam gun, mitts, orbital polisher, all the bits and pieces and soaps and polishes etc) And plan on doing my first polish soon. I get confused on the sealant process. I have some chemical guys citrus wash, which I understand will remove any wax/sealant that is on the car. What's the process at this point if I want to wash/dry, clay bar, polish and apply new sealant? Thanks!
#3274 |
I'm not sure if this has been asked but, my friend gave me a tire shine to use on my ///M and it dried out my tires and it looks horrible. Is there any product out there you would recommend to use to fix this ? I find myself with a nicely washed and clean car with these dried out looking tires. Thanks.
![]() CarbonBlackCinnamon 30% Tint/Black Grilles And Gills/CF Wrapped Trim/MeganRacingExhaust/DepoSmokedCorners |
#3275 |
Would you be willing to set up a package and discount code for e46fanatics members for a complete DIYer setup soap, was towels, mitts, polish, clay bar, wax, etc of your recommended products? Thanks.
| Rate This Thread | |
