Old 01-27-2013, 05:34 AM   #21
BBBoy323i
My Ride: 01' 325ci
I got an AL brand when I ordered my lenses, almost a year with no issues. Make sure you regularly clean your lenses too, check for any oxidation
BBBoy323i is offline   Reply With Quote
Old 01-27-2013, 06:20 AM   #22
sillieidiot
My Ride: '06 AW 330ci
for our generation cars bosch = AL. bosch owned AL and sometime during near the end of the e46 era they split into separate companies. the zkw xenons are the only replacements that you can't get because they are made of glass. all other lights use plastic lenses
Old 01-27-2013, 06:26 AM   #23
goblinsplace
My Ride: 330i ZHP
So I've got one zkw and one AL headlight.
Can I use the Bosch lenses on both?
goblinsplace is offline   Reply With Quote
Old 01-27-2013, 06:39 AM   #24
sillieidiot
not sure. i've never tried a plastic lens on a zkw xenon headlight before.
but bosch lens will work for the AL headlight. though they are normally labeled AL for facelift sedans.
Old 01-27-2013, 12:16 PM   #25
afstud
My Ride: 2003 ZHP 6-speed
all you need to know is all E46 headlights are plastic, PERIOD, the Bosch ones will work on all the headlights no matter what make they are, just order the correct ones from khoalty and youll be set
2003 330i ZHP 6 speed
afstud is offline   Reply With Quote
Old 01-27-2013, 01:27 PM   #26
TT330i
My Ride: 2003 330i
+1
I ordered these from Khoalty and they are fine. Def worth new ones over polishing. We luck out with our cars, most japanese cars etc you have to buy the whole housing and it can be over $1000 each. At 70 bucks you can't go wrong
TT330i is offline   Reply With Quote
Old 02-02-2013, 08:42 AM   #27
Racinghart
My Ride: 03 330i ZHP
Send a message via AIM to Racinghart
Got a set from Khaolty and they are awesome. Highly recommended.
- Bruce
Racinghart is offline   Reply With Quote
Old 02-02-2013, 09:26 AM   #28
DonaldE
My Ride: 2002 330i
Bosch is AL...
DonaldE is offline   Reply With Quote
Old 02-02-2013, 07:58 PM   #29
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
Just get the new ones from khoalty. Totally worth it.
Sent from my ADR6425LVW using Bimmer App
rizwan1377 is offline   Reply With Quote
Old 02-02-2013, 08:04 PM   #30
goblinsplace
My Ride: 330i ZHP
Hi. I'm the OP. I should prob chime in here. I did! I did! I listened! They arrive on Monday!
Old 02-02-2013, 09:25 PM   #31
fgin
My Ride: e46 facelift
Hey did you have ZKW lights or AL headlights ? What brand lenses did you get ?
I am wondering if the AL lens will fit ZKW and vice versa?
fgin is offline   Reply With Quote
Old 02-02-2013, 09:42 PM   #32
goblinsplace
My Ride: 330i ZHP
I have one on each size. I'll know Monday night! I hope so. According to everyone on here they are unisex.
Old 02-02-2013, 11:10 PM   #33
fgin
Ok, I originally had AL halogens and then retrofitted ZKW Xenons. So i had the AL Halogens in storage. Pulled them out just now and swapped the lenses and they fit perfectly. They are exactly the same, BMW and even pelicanparts are listing the AL lenses as if they wont fit ZKW. ZKW lenses are priced double. What a rip off! but in a way no one will know until its tried. Hope my experience will be useful to someone.
btw: Im referring to this part (lens)
Old 02-03-2013, 02:40 AM   #34
goblinsplace
My Ride: 330i ZHP
And here we have it folks!
Old 02-03-2013, 02:54 AM   #35
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
glad you chose new lenses instead of BS polishing
/_________\
O==[][]==O
Old 02-05-2013, 08:28 PM   #36
goblinsplace
My Ride: 330i ZHP
Hi. I'm the OP.
Khoalty sent me lenses. They are NOT Bosch. They were DJAUTO.....
Not cool....... Wtf..
So back to the origion conv... Use DJauto not perfect fitment lenses or have my OEM lenses polished....
Kicking rocks. Everyone was so confident but what a fail.
Old 02-05-2013, 08:55 PM   #37
sillieidiot
well you can polish them if you want, but you'll need to clearcoat them after. if you don't, it'll start to haze up like crazy each time
Old 02-05-2013, 08:57 PM   #38
goblinsplace
My Ride: 330i ZHP
Will lamin-x prevent hazing?
What kind of clear coat? Spray paint grade? Or body shop grade?
Old 02-05-2013, 09:03 PM   #39
TallSkinnyMatt
My Ride: E92 M3 ZCP
So is the fitment really off? Or why not just use the DJAUTO lenses? The khoalty lenses should be OEM quality either way.
TallSkinnyMatt is offline   Reply With Quote
Old 02-05-2013, 09:09 PM   #40
goblinsplace
My Ride: 330i ZHP
Its so frustrating. They said that only the 02-05 sedans are off brand.... Wtf... They could be more clear about that.........
So I'm wondering what the best move is next.
