Sponsored by BimmerWorld
Old 01-31-2013, 04:21 PM   #1
Eurogasm
My Ride: 2000 328Ci
Question DIY difficulty level to replace rear shocks.
Hi everyone, my 2000 328Ci is in need of a new pair of shocks in the back. I would prefer to do the work myself if possible to save myself the money and gain the knowledge. I was wondering what the difficulty level is of this project is and if its somthing I can do or somthing better left to a professional. I'm no mechanical genius but I can figure most things out if pointed in the right direction. Also, any special tools needes or other parts that should be replaced at the same time? Thanks guys
Eurogasm is offline   Reply With Quote
Old 01-31-2013, 04:23 PM   #2
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
no special tools, very easy
VALMONT is offline   Reply With Quote
Old 01-31-2013, 05:56 PM   #3
Eurogasm
My Ride: 2000 328Ci
Anyone else? Further details would be appreciated
Old 01-31-2013, 05:58 PM   #4
VALMONT
The De46vil's Army
VALMONT's Avatar
2 bolts in the trunk one on the lower shock mount (for each side).
Old 01-31-2013, 05:59 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Extremely easy.
- Remove the two nuts for the shock mount
- Remove the main bolt (I don't remember exactly) on top of the shock
- Remove the bolt at the bottom
- Pop it out and reverse order
Old 01-31-2013, 06:05 PM   #6
jerseyzillest
My Ride: 325 CI
1-10
.5/10
Photobucket
^Taken with iPhone^
:rofl:
jerseyzillest is offline   Reply With Quote
Old 01-31-2013, 06:06 PM   #7
Eurogasm
My Ride: 2000 328Ci
How about compression before tightening the last bolts? Would I tighten one end first and lower the car off the jack before tightening the others?
Old 01-31-2013, 06:10 PM   #8
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
You can compress the shock with a jack to line up perfectly. Attach the top first.
Or you can instal the bottom first then cut the packaging line and it'll decompress itself.
It's self explanatory and very easy.
Old 01-31-2013, 06:16 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
You'll be fine, don't worry
Old 01-31-2013, 07:36 PM   #10
Eurogasm
My Ride: 2000 328Ci
Appreciate the help guys
Old 01-31-2013, 07:50 PM   #11
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
the hardest part would be taking out the trunk liner and putting it back in. taking out the shock itself is only 3 bolts total.
as long as you can jack up the car and have a socket wrench set handy, you're golden.
Devious1 is offline   Reply With Quote
Old 02-01-2013, 01:17 PM   #12
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Should be really straight forward!
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-05-2013, 04:05 PM   #13
330iPilot
My Ride: Titanium Silver 330i
What about the shock mounts? Is it always a good idea to replace those as well or are they replaced only if they look like they are squashed flat?
330iPilot is offline   Reply With Quote
Old 02-05-2013, 06:31 PM   #14
dan_1337
My Ride: 330CiC
It's really easy. I'm not technically inclined at all and can probably do it in sub 1 hour.
dan_1337 is offline   Reply With Quote
Old 02-05-2013, 06:51 PM   #15
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Very easy job. 1 out of a 10.
Replace your shock mounts at the same time.
You will need to cut the sound deadening in order to get to the shock mount, and the mount bolts.
Make sure you do not let the wheel hub hang without support under it. It can break the shock mount if it drops.
BMWCaptain is online now   Reply With Quote
Old 02-05-2013, 07:33 PM   #16
drumsauce
My Ride: 2000 323it
SUPER easy on a coupe or sedan. DiY.
Now on a touring....that is a little more time consuming.
Do it! You will be happy with the money you saved and what you learned about your car.
Good luck!
drumsauce is offline   Reply With Quote
Old 02-05-2013, 10:10 PM   #17
BMWCaptain
Originally Posted by Solidjake View Post
Extremely easy.
you don't take the shock nut off. You remove the 2 nuts for the shock mount and the lower bolt and then pull the shock out .
you remove the shock from the shock mount outside the car. It requires you to hold the shock stem with a wrench, them you turn the nut on top to remove the shock from the mount .
