Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Strut tower reinforcement plates - does mine already have them??
I'm not sure if the previous owner installed strut tower reinforcement plates on the 05 330i zhp I purchased about 2 years ago. I bought the plates from a dealer several months back and have just put off installing them. I then started wondering if there is a way of "seeing" the plates from the top?
Last thing I would want to have happen is go to the effort of dropping the strut down to discover it already has them. |
#2 |
It just a black disc that goes between the top of the strut and body of the car.
Looks like this: |
#3 |
Mister TechnoMeister
looks like you do.
if you didnt, above the strut would be that same grey color.
#4 |
I'm not the OP
#5 |
Hahahah totally read that all as one post
#6 |
Lol
I like the camber in your sig |
#7 |
#8 |
Hah thanks. It's about -4.2 there
#9 | |
#10 |
does anyone know if these raise the car at all?
i'm wanting to raise my front maybe 2 mm and this would be a nice and easy way to get a little lift. i don't want to take the springs out and put different spring pads on.
#11 | |
http://www.mcmaster.com/#standard-al...sheets/=l95ty1 |
#12 | |
The reinforcement plates are shaped specifically for the strut towers. Using a flat piece of aluminum creates stress points, and mushrooms your towers even quicker. If by “machining” you imply that you’ll be shaping them, why go to all that effort? BMW sells the plates for around $10 each, and yes they’ll add about 2mm to the ride height. |
#13 | |
#14 |
