Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 01-17-2013, 08:34 AM   #701
moiz21
My Ride: 1999 323i 5-SPD
9006 is for the fog lights. H7 are the halogen headlights, you need this harness to convert to HID's.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 01-17-2013, 09:03 AM   #702
beattie_03
My Ride: 2002 318i
100%? So that Canbus H7 harness I linked to is the only one I will need?
beattie_03 is offline   Reply With Quote
Old 01-24-2013, 05:23 PM   #703
erice46
My Ride: 2002 325I
Hey guys so I took apart some depo projectors to paint the shroud. And now I have everything taken apart ... I have some projectors that I took out of my last e46 that was totaled... anyway they are aftermarket on the projectors it says sonar. Anybody know anything bout them
erice46 is offline   Reply With Quote
Old 01-24-2013, 07:06 PM   #704
Tiag46
My Ride: e46
Yeh, they're going to fail on you sonar rather than later.
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is online now   Reply With Quote
Old 01-24-2013, 07:57 PM   #705
erice46
My Ride: 2002 325I
Ok so the sonar are crap? Also what should I yse to clean off the projector? Windex? Alcohol?
Sent from my SAMSUNG-SGH-I747 using Bimmer App
Old 01-25-2013, 07:25 PM   #706
erice46
My Ride: 2002 325I
Anybody know were I can get one of these
Old 02-01-2013, 12:18 AM   #707
Arpee
My Ride: E30 M3/ 323ci
Where do you connect the wire from the back of the projector?
Arpee is offline   Reply With Quote
Old 02-02-2013, 01:43 AM   #708
prisonerofdoom83
My Ride: E46 E30 Tacoma
this looks like i would make a complete mess with all these parts . this is my next upgrade i might just have to shell out the big bucks and buy some that are already converted
prisonerofdoom83 is offline   Reply With Quote
Old 02-02-2013, 01:10 PM   #709
antc101
My Ride: 323ci (2000)
Guys, I have just finished reading every single post spanning 36 pages. Took me about a week in between long hard days at work and sleeping, but every piece of info one could possibly need is here...except this: I have everything from TRS, the ballasts, bulbs, and h7 harness. Will I need any sort of canbus harness also to avoid flickering/dash errors or will it be okay to work with what I have already?
It's going in a 2000 323ci if that matters at all.
Thank you!
antc101 is offline   Reply With Quote
Old 02-02-2013, 02:37 PM   #710
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I'm really serious about doing this very soon...I can't take my lights anymore...and I didn't read all 36 pages!
I looked at the kits, but haven't a clue what all I need or don't need. I'm oldstyle headlight, so at least can get my lens cover off with no problem...but from there, I'm really lost.
Can I do projector hids in a pre-facelift? Anyway, you lighting guys are speaking a language I haven't quite picked up on...all I can figure out is I need a projector, a bulb, and ballast...maybe some other electronic gizmo too...and then I need to get the car flashed...or is that optional?
Could I leave it as it is...have four bulbs on with high lights and have flash to pass as I am now? I have day time running lights too...if the flash is necessary, does that 'kill' the drl?
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-02-2013, 02:47 PM   #711
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I have a vid. EXTREMELY simple. Watch it and decide
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 02-02-2013, 06:27 PM   #712
Tiag46
My Ride: e46
^nice quads SJ
Old 02-02-2013, 06:35 PM   #713
Solidjake
Zero. Leaks.
Solidjake's Avatar
Thanks!!
Old 02-03-2013, 08:48 AM   #714
sandman512
My Ride: 2005 325I
Solid,
What is wire for on the projector?
Thanks!
sandman512 is offline   Reply With Quote
Old 02-07-2013, 01:19 AM   #715
325adam
My Ride: 02 330i
How is everyone installing the wires through the headlight from the projector? Drilling holes?
325adam is offline   Reply With Quote
Old 02-07-2013, 01:57 AM   #716
TerraPhantm
My Ride: M3 & ZHP
You can do HIDs in a prefacelift. You should be able to follow this thread more or less exactly. Or you can buy a set of OEM HIDs and use those.
Technically recoding the LCM is optional if you use an error canceler... but I think recoding it is the best way to go. If you're willing to buy a cable, I can guide you to coding your LCM.
Old 02-07-2013, 08:37 PM   #717
Rezist09
My Ride: 325i sedan
Where do u guys get the rings ?
Rezist09 is offline   Reply With Quote
Old 02-07-2013, 09:05 PM   #718
trentcdrums
My Ride: BMW 323i Sedan
Originally Posted by sandman512 View Post
Solid,
Thanks!
To tap into the high beam for the bi-xenon option.
Old 02-07-2013, 09:07 PM   #719
prisonerofdoom83
so my lenses are trash and so are my gaskets they leak in on my stock halogens . so rather than retrofit which i doubt i could do anyway as stated above . i plan on getting these http://www.ebay.com/itm/170984733149...84.m1423.l2649
whats up with this ds2 projector and bulb conversion it has installed in it . is it comparable to what you guys are recommending . these are supposed to be the best model projectors he has for sale
Old 02-09-2013, 03:36 AM   #720
TerraPhantm
My Ride: M3 & ZHP
Hey guys -- just FYI, I found that the E39 HID gasket for the rear of the headlight is a pretty good fit on our E46s. You do have to stretch it a little, but it seals quite well for those running external ballasts -- especially if using d2s bulbs. Part number: 63126904047
Pic:
Rate This Thread
