Old 02-06-2013, 09:02 PM   #1
Afrosheen
My Ride: 2004 330ci ZHP
Question What should I be aware of before starting my first brake pad change?
I'm going to be initiating my first brake pad change and I'm wondering what things other people who did this themselves wished to have thought of before they started the project?
• I'm driving a 2005 325i with 99,800 miles on it.
• I'm going to install Performance Friction Carbon Metallic Brake Pad 0558.20 for the front wheels.
• My father replaced the rear pads with Duralast pads at $50 which he says has lifetime warranty on them. I don't particularly trust them — probably replace them some time after I replace the front pads.
• Do I need to purchase new brake sensors each time I buy new brake pads, or can I reuse the ones that are on there? My father didn't regard this when he replaced the rear pads and the brake light was still on. Don't know whether it was because he wasn't aware of knowing how to properly reconnect them or whether the light is for the front.
• Anything else that I'm not thinking about but should be aware of before I buy and install the brake pads?
Thanks for the consideration.
Afrosheen is offline   Reply With Quote
Old 02-06-2013, 09:54 PM   #2
Mflara20
My Ride: 04 330i
It's pretty straight forward of you DYI inclined. You need to buy new sensor wires if you want the brake dash light to go off an really tell you when you need new pads.
Mflara20 is offline   Reply With Quote
Old 02-06-2013, 10:11 PM   #3
Unforgivable818
My Ride: 2001 325ci
Send a message via AIM to Unforgivable818 Send a message via Yahoo to Unforgivable818
If it's not too late, try to exchange those PFC Carbon Metallics for the Z-Rated version. Trust me on this one. What type of rotors will you use? Brembo blanks got chewed up by the Z-Rated pads so choose wisely!
2nd Owner - 2001 325ci - ZSP/ZPP - Build Date: 05/01 - 194k miles - ZF 5HP-19 - Jet Black - Black Leather
BFG G-Force Sport Comp2 - ATE PremiumOne rotors - PFC Z-Rated pads - Koni Yellows / e36 m3 shocks - Vogtland Springs - ZHP CAs - Z4M CABs
Unforgivable818 is offline   Reply With Quote
Old 02-06-2013, 10:14 PM   #4
wildirish317
My Ride: 2004 325Ci vert
Brake pads are an easy DIY. If the pad sensor caused the SEL light to come on, it's toast. Replace it. If you check your pads regularly, and don't need a sensor to tell you it's time, plug it in but wire it back away from the caliper and you'll never have to replace it again. Replace the one your father left in as well.
Also, replace the rotors when you do the pads. They are cheap. If you are going to start running metallic pads, you'll have to replace them with the pads anyway.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-06-2013, 10:19 PM   #5
TurnersInOz
My Ride: 2004 325i
If you got a warning light then the sensor must be replaced. From the sounds of what you wrote, you need to replace the rear sensor anyway. You might as well get two (one front, one rear). The way the sensors works is that when they contact the rotor (i.e. your pads are worn) the sensor wears away and triggers the light. They can be re-used only if this has not happened and they are in good working condition.
What condition are the rotors in?
Read thru the DIY's on this. It's a straight-forward job to do.
TurnersInOz is offline   Reply With Quote
Old 02-07-2013, 12:45 AM   #6
Afrosheen
Thanks for the input guys. This has helped me a lot. But in regards to the rotors, how necessary is it to get new ones? They were replaced through the dealer when the car still had warranty in the middle of 2011. I'm thinking of buying the pads first then when installing them I'll inspect the rotors. But looking at them through the wheel, they still look pretty good.
Old 02-07-2013, 01:10 AM   #7
MJLavelle
My Ride: 2001 BMW 330ci
Buy a tool for compressing the caliper pistons. Don't use a C clamp or Channel locks to compress the piston. You can get the piston cocked, and damage the bore, or the piston ring. Do it the right way, with the right tool. It is also much easier with the correct tool. They run from simple, to somewhat complex sets that work on most models of cars. Even a simple screw type is better than winging it.
Old 02-07-2013, 01:15 AM   #8
Guest021715
Account closed.
^ Any type of lever is fine so long as you're not being dumb with placement.
Old 02-07-2013, 01:27 AM   #9
heechkass
My Ride: 323i Touring, 2000
Since you're a newb on this....which light is on? brake light or brake sensor light? They are two different things.
Also since you may have close to 100000 miles on these rotors, you most likely should replace them.
Also replace the guide pin bushings. And the anti rattle clip.
Make sure you clean caliper slide thoroughly before installing new parts. Use brake grease on metal on metal parts.
heechkass is offline   Reply With Quote
Old 02-07-2013, 02:07 AM   #10
Redflea
My Ride: 2005 330Ci/2003 530i
My favorite DIY, 'cause you get to work sitting down.
I've done a lot of brake jobs w/out a compression tool for the calipers as well, but there's nothing dumb about having appropriate tools for the job.
Have fun.
And be careful, 'cause if you f it up, you will die.
Redflea is offline   Reply With Quote
Old 02-07-2013, 02:11 AM   #11
Nerdy46
My Ride: 328i
Compress the caliper using the old pad and a c clamp.... works fine.
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 02-07-2013, 02:12 AM   #12
Nerdy46
My Ride: 328i
Id never pad slap rotors on a car i cared about.
Old 02-07-2013, 03:33 AM   #13
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Advice - I didn't see it brought up yet, regardless of what pads you go with BED the brakes after you get the job done. It's a process that deposits brake pad material into the metal in the rotor from repeated braking while the rotors get ultra hot. It makes for very smooth consistent braking down the road.
Search, there are some very good articles that explain the process in detail. It's worth the time to look it up believe me.
/// MODS
Old 02-07-2013, 03:53 AM   #14
MJLavelle
That is fine, if you know exactly how to do it. For someone asking for advice on how to do a brake job, then the right tool is better.
