Old 02-07-2013, 02:36 AM   #61
WALKD U
My Ride: Just Fast!
Looking good
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 02-07-2013, 11:24 AM   #62
lutzperformance
Lutz Performance-FL BMW F/I
My Ride: 1995 BMW M3, 04 Z06
Send a message via AIM to lutzperformance
Thank you guys, exhaust is almost done
lutzperformance is offline   Reply With Quote
Old 02-10-2013, 05:33 AM   #63
e60fan
My Ride: 525i
Nice work!
About MS45 builtin torque control - it's true. When calculated TQ exceeds stock DME goes in limp mode. I checked this myself on M54B25 with B30 head + intake + exhaust and tune attempt by me. When bhp exceeds stock its OK but if TQ more than stock DME goes in limp mode. Because of this I'm thinking about Pro48 (no knock control, but budget) or AEM or MS3 + stock DME and Parallel ECU mode...
Good question was about what to do with non availablity injectors and coils at stock DME after rewiring to aftermarket ECU? Or stock DME will be happy with this by default?
e60fan is offline   Reply With Quote
Old 02-10-2013, 07:16 AM   #64
bimer21
My Ride: stick 325i
Sexy build, good luck with it
bimer21 is offline   Reply With Quote
Old 02-10-2013, 12:06 PM   #65
WALKD U
My Ride: Just Fast!
OP look sick! Can't wait to see results. Not sure if I missed this or not OPN? And the fixed harmonics of the crank issue?
Originally Posted by e60fan View Post
Nice work!
Should post up a new thread about this. I am plan to run a PiggyBack Stand-Alone system if I can't get my car tuned correctly...
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 02-10-2013, 01:51 PM   #66
e60fan
My Ride: 525i
Done...
http://forum.e46fanatics.com/showthread.php?t=970357
Old 02-11-2013, 04:56 PM   #67
A4RingedONE8T
My Ride: Turbo ///M Roadster
Exhaust done, wheels mounted, hotside charge pipe complete
A4RingedONE8T is offline   Reply With Quote
Old 02-11-2013, 05:09 PM   #68
GGray
My Ride: 00 330it Wagonator
Nice work!
If your having problems like above.. You need to stop trying to tune it yourself...
Aftermarket ECU's tend to not work well with the rest of the E46. CAN-BUS needs to have CAN-BUS to communicate with. Cheap ECU's normally don't have it. The BMW ECU is very tunable you just have to know how...
Gary
Need parts, or a race shop?
email us - info@simod.net
Follow us on facebook
If you can take it apart you can make it faster
GGray is offline   Reply With Quote
Old 02-11-2013, 05:11 PM   #69
WALKD U
My Ride: Just Fast!
LMK when u an Expert in MS45 DME's...
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 02-11-2013, 05:21 PM   #70
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Looking good so far
AMG-ETR is offline   Reply With Quote
Old 02-11-2013, 05:54 PM   #71
GGray
I know who to contact to do my tuning... And I know how CAN-BUS works.. Meaning you cannot just slap an aftermarket ECU, or piggy back in the E46 without a boat load of problems from the other systems that tie into the ECU and communicate with each other... EWS, ABS, traction control,etc... if not happy it will send the E46 into limp mode, or even a no crank situation if EWS is not happy.
Gary
Old 02-11-2013, 10:22 PM   #72
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
I have the latest firmware Unichip Q+.
I can control fuel/timing (retard,advance), DISA, DBW and so far no issue with intake cam timing. Unichip can tap into CAN BUS too for things like speed limiters, rpm limiters or sometimes torque control.
luckily for the MS45 torque control comes by the way of throttle actuation. DBW on the MS45 is easier to control then cars that use the 300mV - 2.6V feedback signals. MS45 uses 500mV - 4.5V feedback signals.
No issues here after so much experimentation the past few months.
www.E46Turbo330Ci.com
WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo
The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter
NIVO is offline   Reply With Quote
Old 02-12-2013, 04:49 PM   #73
A4RingedONE8T
Hot side piping complete w/ Tial Q BOV
Old 02-12-2013, 05:14 PM   #74
WALKD U
My Ride: Just Fast!
Any reason why having the BOV so far away from the manifold? (Long Vacuum Line = delay responds?) Other then that Sick Setup so far!!!
I also noticed No MAF Alpha-N tuning!?!
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 02-13-2013, 01:54 AM   #75
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
Cool
Originally Posted by str8dum1 View Post
i'd be very wary about that Level 10 transmission. terrible track record...
BS! or should i say that is simply not true.
I had a Level10 Tranny custom built for a Subaru SVX Back in 99'. 1st they've built and it was truly "Bullet proof"
back then, after mine they sold 4 more and they ALL performed beyond expectation.
i have since left the subaru scene obviously but i beg to differ. level10 is one of the best in this country.
track record, they build transmissions for our military special ops vehicles.
But to not go too far off Topic this does Look S!CK!!!
In for dyno and road video of it in Action!
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline   Reply With Quote
Old 02-13-2013, 02:26 AM   #76
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Looking good Shawn!
Old 02-13-2013, 07:04 AM   #77
SweTurbo
Big Pimpin'
My Ride: 323i -98
It's not that far away from the manifold, by the looks of it it's placed infront of the drivers-side front wheel.
Old 02-13-2013, 07:23 AM   #78
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Technically, I'd put the BOV as close to the compressor as possible...at least that's what all the motorsport engineers do. Why bother pumping all that air through the intercooler, adding more heat to cooling element, only to blow it off to atmosphere?
Old 02-13-2013, 07:52 AM   #79
WALKD U
My Ride: Just Fast!
I get your point
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 02-13-2013, 09:05 AM   #80
A4RingedONE8T
Tial uses a pretty large vac line compared to what's really needed. I've put Tial valves all over the place all with different length vac lines and none have ever shown any delayed response. The one on my car is probably the longest/furthest I have done and still no issues
I put the BOV where it is just for best fitment, no other reason.
I get your point
BOV can be placed a variety of places to alter the performance of the setup. Closest to the turbo is best for the turbo because it's instantly venting any pressure from coming back at the turbo causing compressor surge. Close to the turbo also creates the most lag as it is completely venting any positive pressure from the source and will cause the most lag between shifts. Primarily as it has to completely "refill" the desired boost before the pull starts again in the next gear. Moving the BOV away from the turbo lessens the amount of lag because it is keeping some positive pressure on the turbo side of the system. Most of the time I go for where works best with what's going on with that particular setup. I chose the location on this car for ease of fitment, clearance with fog lights, lack of clearance on the hot side because of turbo placement, and also far enough away from the blow through MAF that will be in the straight piece of pipe directly before the throttle body.
