Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 02-06-2013, 12:25 PM   #1
diederik
My Ride: bmw e46 323ci 1999
Send a message via MSN to diederik
bmw e46 323 g power kit
hellow i have an e46 323 ( i'm from belgium so tax on bigger engines is retarded high trust me an 2.5 is a quite a big engine here ) .
I bought an g power supercharger kit , but to be safe i'm searching for an fuel regulator that fits with the original lines with 4.5 bar of pressure . does that exist ?
I heard something about and modded e39 fuel filter that shoud fit ? is that correct . thanks you very much .
Greetings diederik
diederik is offline   Reply With Quote
Old 02-07-2013, 10:14 AM   #2
diederik
nobody ? greetings
Old 02-07-2013, 04:19 PM   #3
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
5.0 bar fuel rail pressure reg from the S54 M3 will fit in the M52TUB25 fuel rail.
BMW part number: 13531404089
E46 Coupe is offline   Reply With Quote
Old 02-07-2013, 04:22 PM   #4
E46 Coupe
E46 Coupe's Avatar
Bosch don't actually make a static 4.5 bar reg unit, they have adjustable units, but static units are usually 3.5, 3.8, 4.0, 5.0 in that range.
http://www.bosch-motorsport.de/conte.../html/2829.htm
Old 02-09-2013, 12:46 PM   #5
diederik
thanks very much for the info
Old 02-09-2013, 12:59 PM   #6
jeff_smg
My Ride: //HPF M3 E46 Vert'
Send a message via MSN to jeff_smg
Hello,
As tu fini le montage ?
Dyno yet ?
Turbo M3 E46 //HPF ... 647 BHP
jeff_smg is offline   Reply With Quote
Old 02-09-2013, 05:35 PM   #7
E46 Coupe
E46 Coupe's Avatar
You're welcome. Just so you know as well, there isn't a pressure reg in a M52 fuel filter like a M54 afaik.
Old 02-10-2013, 08:28 AM   #8
diederik
ok so as i understand the m52 filter had nog got a pressure regulator of does it ? srr englich is not ma native languige , i speak dutch as main and englich , german and french .
Where does the m52 has it pressure regulator on the engine ?
And to jef smg no this just prep for the car i need to get some stuf , just taking my time to get the info and the extra stuf for the car , bether to wait some time and do it right .
Old 02-10-2013, 08:36 AM   #9
diederik
ow anybody good a good brand for other injectors of wil m3 injectors work and fit ? greetings
Old 02-16-2013, 02:43 PM   #10
diederik
bump
Old 02-24-2013, 01:22 PM   #11
diederik
so can anybody tel me how jack up the feul pressure ? greetings
Old 02-25-2013, 06:42 PM   #12
BDUB328I
My Ride: bmw 328i sedan (E46)
add the ekp fuel relay and switch to e46 m3 fuel pumps.
CHECK OUT MY M3 SEDAN SWAP!!
http://forum.e46fanatics.com/showthr...978&highlight=
AND MY 328I PARTS FOR SALE
http://forum.e46fanatics.com/showthr...057&highlight=
SPONSORS: |Good 'N Plenty Restaurant, 150 Eastbrook Road Smoketown, PA| |TheBMWpartStore.com|
BDUB328I is offline   Reply With Quote
Old 02-28-2013, 04:35 PM   #13
diederik
can you explain pls add the ekp fuel relay ?
greetings , i can go warlboro feul pump ?
Old 02-28-2013, 04:37 PM   #14
diederik
btw thanks for the info
Old 02-28-2013, 07:08 PM   #15
BDUB328I
delete
Old 02-28-2013, 07:11 PM   #16
BDUB328I
I dunno if ur dme is set up for it. But there is a lot of info on it. Search Ekp relay. Or click the link in my sig to my build thread. I talk about it there. I installed it on my car because it's needed to run the s54 and 5 bar of fuel pressure
Old 03-04-2013, 04:22 PM   #17
diederik
ok thanks for the info , very very helpfull , thanks
