Old 02-07-2013, 03:24 PM   #1
sandman512
My Ride: 2005 325I
Do Angel Eyes eventually burn out?
I have a set of Projector 46's. I have had them for about 7 years. One of the rings is completely out. Tried a new ballast, no luck. So do they eventually burn out?..
THANKS
Sent from my SPH-L710 using Bimmer App
sandman512 is offline   Reply With Quote
Old 02-07-2013, 03:49 PM   #2
Jesse M
My Ride: 05' ZHP
What kind of lights are they? You said ballast so I assume they are CCFL's, and yes, they do burn out much much faster than an LED.
Jesse M is offline   Reply With Quote
Old 02-07-2013, 04:46 PM   #3
sandman512
My Ride: 2005 325I
Sorry, yes they are CCFL'S. Sort of sucks, one ring is out.
Old 02-07-2013, 05:19 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Take them out and put in LED angel eyes.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 02-07-2013, 05:23 PM   #5
sandman512
My Ride: 2005 325I
Solid,
They came preinstalled in the P46's. I'm not up to messing around with them. I'm actually going to do the upgrade on my original lights to projectors using the DIY, looks fairly easy and cheap. My question is that the DIy does not mention anything about using a dremel, but in a video, yours I think, you use one. Any reason? Thanks!
Old 02-07-2013, 05:32 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
The shrouds that go around the projector are too bit and don't fit into the bowls. You will have to cut about 1/2" around to make them fit inside.
Old 02-07-2013, 05:33 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
Look at the 8 minute mark in my vid
Old 02-07-2013, 05:43 PM   #8
sandman512
My Ride: 2005 325I
Thanks, Solid, I appreciate it. I'm glad I watched the video because I did not see any mention of that in that write up.
Old 02-07-2013, 05:45 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yup
