Old 02-06-2013, 11:53 PM   #1
rediahad
My Ride: 330CIC
What are these wires?
2003 330cic, i found these cut wires, they look like they are for some fog lights cause i can't find a fog wire and something else. let me know if anyone recognizes those colors
rediahad is offline   Reply With Quote
Old 02-07-2013, 12:03 AM   #2
RKiepper
My Ride: 1999 E46 328I x2
Where are these wires coming from?
Need more info, there are more then a few places these wires could run.
RKiepper is offline   Reply With Quote
Old 02-07-2013, 12:09 AM   #3
rediahad
My Ride: 330CIC
they are coming from the driver side, right next to air box, the wiring runs with the headlight wires, my phone was running out of batteries so i couldn't use the flash
Old 02-07-2013, 12:25 AM   #4
RKiepper
I'll list everything that the drivers headlight harness encompasses.
Low beam
High beam
Turn signal
Fog light
Horn
Ambient temperature sensor
Horn
Coolant level sensor (90% on this)
Check all of these, figure out what doesn't have wires.
Old 02-07-2013, 12:58 AM   #5
rediahad
My Ride: 330CIC
so the blue and blue/red= temp sensor
what are brown and yellow/brn
and purple and red for, my horn works one of the sets is for fogs i'm sure but that still leaves another set. the coolant sensor is coming off the other set of wires. all my lights work too.
Old 02-07-2013, 01:25 AM   #6
RKiepper
You have two horns inside the front bumper aluminum support, one on each side. Your certain the drivers side is wired still?
I'm racking my brain, but if the temp sensor and fog light wires are cut, the wiring for the horn runs down along with those other two groups of wires.
Old 02-07-2013, 02:03 AM   #7
rediahad
My Ride: 330CIC
maybe ill check tomorrw, where is the horn on driver side mounted?
Old 02-07-2013, 02:21 PM   #8
RKiepper
Just to the outside of the bumper shock, I do believe. One on either side.
Old 02-07-2013, 06:31 PM   #9
DonaldE
My Ride: 2002 330i
Damn. There is two horns? I unplugged one thinking that was my ambient temp pig tail plugged into the wrong spot
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
Old 02-07-2013, 07:33 PM   #10
rediahad
My Ride: 330CIC
no one has a wiring diagram
Old 02-07-2013, 07:39 PM   #11
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
Sent from my HTC One X using Bimmer App
VALMONT is offline   Reply With Quote
Old 02-07-2013, 07:42 PM   #12
VALMONT
The De46vil's Army
VALMONT's Avatar
oh wait that was for a wagon, you have a CiC, do you have xenons? (different diagrams)
Old 02-08-2013, 12:43 AM   #13
rediahad
My Ride: 330CIC
i think mine came with halogens stock
