Old 02-01-2013, 05:31 PM   #1
ECSTuning
ECSTuning's Avatar
My Ride: BMW
:: ECS Tuning :: EMP Stewart High Performance Water Pump| In Stock
No more Mister Nice Guy. Fire your under-achieving stock pump and replace it with a High Performance water pump from EMP Stewart.
This is the pump your BMW should have had from day one. Designed for performance and durability, EMP decided to do it right the first time, increasing flow a full 20 percent over stock, while reducing parasitic draw with a highly efficient stainless steel impeller.
Add a heavy-duty bearing and high quality water seal, and you have a pump durable enough for daily driving; tough enough for the track.
Don't Wait for the Too-Late Light
Fitment:
E36 M50/M52/S50/S52
E46 3 Series M54
E53 X5 M54
E60 5 Series M54
E83 X3 M54
Click HERE to order today
Old 02-22-2013, 05:31 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I have that pump in my car.
Old 03-15-2013, 04:22 PM   #3
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Old 03-28-2013, 04:29 PM   #4
ECSTuning
ECSTuning's Avatar
My Ride: BMW
As do I! One of the best options for anyone who's planning on keeping their car long term.
Old 04-17-2013, 04:28 PM   #5
ECSTuning
ECSTuning's Avatar
My Ride: BMW
You've tried the rest are you ready for the best?
Old 04-18-2013, 08:05 AM   #6
turbotalon1g
My Ride: '02 330i
I'm a noob, but why use this over a stock style?
turbotalon1g is offline   Reply With Quote
Old 04-18-2013, 09:01 AM   #7
ECSTuning
ECSTuning's Avatar
My Ride: BMW
The Stewart flows 20% more coolant over the stock pump, this helps keep the system operating efficiently. The bearing design is far superior to the factory pump (and other factory style pumps) giving you a more reliable long lasting pump as well as less drag in the system over other water pumps. Also the pump carries a life time warranty from Stewart.
Old 04-18-2013, 09:07 AM   #8
turbotalon1g
My Ride: '02 330i
Thanks for explaining that to me, that mean it can go longer between changes?
Or i can perhaps get them warrantied when I'm ready to do my 60k service on them?
Old 04-18-2013, 09:13 AM   #9
ECSTuning
ECSTuning's Avatar
My Ride: BMW
The warranty is against failure on Stewart pump. It would be rather rare for one to fail with only 60k on it.
Old 04-18-2013, 09:19 AM   #10
Blueandwhite85
My Ride: E46
Running this along with your black aluminum WP pulley. Getting a shipment of stuff from you today, too. ECS... I love you guys an gals. My favorite vendor!
Blueandwhite85 is offline   Reply With Quote
Old 04-19-2013, 03:07 PM   #11
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Thanks for the kind words!
Old 04-19-2013, 03:23 PM   #12
BonesM80
My Ride: 02 330ci
When i do my coolant overhaul next month id like to go with the stewart. Is there other components to get that are better then the flawed BMW designed parts. Or do i have to use the stewart with oem
BonesM80 is offline   Reply With Quote
Old 04-19-2013, 03:38 PM   #13
ECSTuning
ECSTuning's Avatar
My Ride: BMW
I wouldn't call the BMW water pump flawed as it was designed with replacement intervals in mind.
The plastic bleeder screws have tendency to become brittle over time causing the heads to snap off or round out, I always suggest replacing them with the brass version found HERE.
Old 08-26-2014, 03:44 PM   #14
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Old 04-24-2015, 09:55 AM   #16
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Click HERE for your E36 I6 Stewart High Performance Water Pump
Old 04-24-2015, 01:39 PM   #17
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Click HERE for your E34 525i Stewart High Performance Water Pump
cooling, maintenance, replace, waterpump
