Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 02-08-2013, 04:31 AM   #1
Big Ginger
My Ride: 3 Series E46
Boot lid electrics
Hiya
I have a 320D SE saloon with electrical problems.
The boot lid has four bulbs, two reversing lights and two side lights.
I have put the ignition to stage 2 (engine off) with the gear stick in reverse with the lights switched on.
Only one bulb lights up fully (the off side reversing light), the other three are very dim.
When I put a meter on each connection it reads 3v (o/s reversing light) and 1v from the other three connections.
If it helps, the parking sensors are not working now either - are these connected??
Big Ginger is offline   Reply With Quote
Old 02-08-2013, 04:45 AM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Assuming you've switched bulbs and cleaned contacts, next step is the wires in the 'elephant boot.' See my thread of that title for further details. Bet it's a bad wire or 2...or 4!
Upcoming comedy shows: April 23, Tierney's Tavern, Montclair, NJ, 7:00 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-08-2013, 06:03 AM   #3
Big Ginger
Thanks Dmax, when it stops raining I will have a look at the wiring loom.
Old 02-08-2013, 09:33 PM   #4
dmax
dmax's Avatar
Read my thread...in all likelihood, looking won't tell you anything. You need to grab the wires inside the loom and try to yank them apart. The one's giving you an issue will break. The wires break inside the insulation and you can't otherwise see them broken.
Yank them apart...read my thread to get an idea of what you're doing.
HTH
Mangofy your E46!
