General Off-Topic
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average.
Old 02-08-2013, 01:29 AM   #3641
HellRaiser1
My Ride: TiAg 330Ci
I find my battery life MUCH better with the new update
18"LM Reps/Eibach ProKit/CAI/UUC TSE1/3.38/UUCflywheel/BremboRotors+akebono pads/Rogue Pullies/UUC EVO SSK/ UUC Sways/EuroSpec StrutBar/DME Reflash/ZHP knob/CSL front/ SRS rear/CSL trunk/CF roof/M3 hood/M3 mirrors/M3 steering wheel/M3 interior/M3 FrontRear Seats/Predator Chromiums/EE LED tails/Xenon interior lighting/Avic-D3/35%tint/V1 Concealed
HellRaiser1 is offline   Reply With Quote
Old 02-08-2013, 05:04 PM   #3642
Grande D
My Ride: zhpppppp (o-m-g!)
I've noticed zero change in battery life with the various updates.
Formerly zhp43867
Old 02-08-2013, 10:36 PM   #3643
Darkside213
My Ride: 04 TSX daily, 01 M3
Send a message via AIM to Darkside213
Originally Posted by alphawhiskey View Post
I'm on 6.1 and battery life is fine for me. Slightly less than 6.0.1 (which was the best battery life for me), but there are so many variables it is effectively the same.
People complain about this every time there is a new update. What is probably happening is that people or the phones are backing up/restoring/syncing after the update, and the battery is draining as a consequence of that, not the update itself.
I think the only legitimate complaint was for 6.0, as there was a problem where it would switch to LTE even when you had wifi when you were asleep. 6.0.1 fixed that problem.
However, I did notice the same problem once when I was on 6.0.2. The battery life overall was fine, but it showed LTE when I woke my phone up and I was connected to wifi. So I'm not sure if the problem crept back in.
I've gone something like 2 days on standby, and 8-10 hours of usage. Wifi most of the time, but the phone wasn't babied otherwise. I just use it when I need it. That includes leaving it unplugged overnight while I sleep.
I have noticed that on 6.0.1, it drained maybe 1% overnight, but now it is 5%+. I am running trillian now, though, so it's an uncontrolled for variable.
Mine drained 19% over night (I slept 6 hours) with only wifi on
"We live in the grey."
Vouch for: nitro3421
Vouches from: nitro3421
Darkside213 is offline   Reply With Quote
Old 02-08-2013, 10:48 PM   #3644
alphawhiskey
My Ride: Foxtrot
Might want to check any 3rd party apps that may be draining it.
alphawhiskey is offline   Reply With Quote
Old 02-09-2013, 12:02 AM   #3645
Darkside213
Everything was closed. Just wifi was on
Old 02-09-2013, 03:36 AM   #3646
Five_seveN
My Ride: rover james
Send a message via AIM to Five_seveN
Why does it show these lines instead of time intervals? I had it charged to 100% before usage. Is this normal?
Originally Posted by Ballistic325 View Post
Five, your second rocket booster, pop-up umbrella and hip flask have failed.
Five_seveN is offline   Reply With Quote
Old 02-09-2013, 03:46 AM   #3647
alphawhiskey
My Ride: Foxtrot
Because you have been respringing after downloading cydia apps/tweaks.
It will work again after your next full charge. But if you respring in the middle of a discharge cycle, it will show that again.
Old 02-09-2013, 03:52 AM   #3648
alphawhiskey
My Ride: Foxtrot
It's something on your phone. Are you telling me you kill all your apps before you go to bed? Even if you are not running it with it open, some things run in the background.
You can try killing all apps before you sleep one night, and seeing if that helps. You can try another night with killing apps and putting the phone on airplane mode to see if that helps. If neither of those help (~1% drain over night), then you may have a bad battery. You can try restoring the phone via itunes to double check.
Or you can try calibrating the battery. Slowly drain it all the way down to 1%, shut down the phone, then let it charge to 100%.
Old 02-09-2013, 07:37 AM   #3649
Darkside213
Yes, that particular night I turned everything off, closed all apps and only had wifi on. I'll turn on airplane mode and test it.
There is a rather lengthy thread on apple forums about this very problem. I'm not the only one
Old 02-09-2013, 10:02 AM   #3650
Five_seveN
The system is completely stock. Cydia or other tweaks are not installed
Old 02-09-2013, 10:08 AM   #3651
Grande D
If you reset your phone or charge a bit in the middle of a discharge the same thing happens.
Formerly zhp43867
Old 02-09-2013, 11:25 AM   #3652
v8 5
My Ride: 6 speed BMW
My battery is draining way faster now
Gutted with a Getrag
v8 5 is offline   Reply With Quote
Old 02-09-2013, 11:32 AM   #3653
Shaban
My Ride: 2005 CBR600
My battery has never been a problem. Took it off the charger at 9am, have been on Facebook, Twitter, Internet, played games, texting, and phone calls, and I'm still at 90% at 12:30
- Alex
Shaban is offline   Reply With Quote
Old 02-09-2013, 11:53 AM   #3654
KwhyLE
My Ride: '04 325i Alpine
Send a message via AIM to KwhyLE
What is your brightness at?
My phone drained 4% on standby with 10 email alerts over 8 hours.
KwhyLE is offline   Reply With Quote
Old 02-09-2013, 12:16 PM   #3655
Shaban
Brightness is about 1/4. No bluetooth, rarely use wifi since LET is faster, I close all apps after I use them except whatsapp is always open. I take a lot of pictures, play a few games, instagram, fb, twitter, etc.
- Alex
Old 02-09-2013, 12:18 PM   #3656
v8 5
Are you sure you know how the iPhone works?
Old 02-09-2013, 12:23 PM   #3657
Shaban
... background apps.
- Alex
Old 02-09-2013, 01:58 PM   #3658
slo323ci
My Ride: 00 323ci
Brightness is about 1/4. No bluetooth, rarely use wifi since LTE is faster, I close all apps after I use them except whatsapp is always open. I take a lot of pictures, play a few games, instagram, fb, twitter, etc.
And LTE is what is killing your battery.
slo323ci is offline   Reply With Quote
Old 02-09-2013, 02:18 PM   #3659
Shaban
My battery isn't being killed lol, my battery is great. Also, according to Apple, 3G and 4G LTE use the same amount of battery (8 hours on 3G or 4G LTE, 10 hours on WiFi).
- Alex
Old 02-09-2013, 03:59 PM   #3660
Five_seveN
are you serious? so it constantly has to be on to show a reading there?
Rate This Thread
