Old 02-08-2013, 12:22 PM   #1
Jemmacandili
My Ride: BMW 325ci 2001
Difficulty to start up the engine ( help )
Hi guys I have 2001 325ci it really drive good, but unfortunately this past few days I'm really having hard time starting it up, I went to autozone to check my battery and alternator their system says it good. Worst thing happened to me is my car is shutting down off automatically , like I'm at the stop light then suddenly it will turn off.
What do you think is the problem? Please help me guys!
Jemmacandili is offline   Reply With Quote
Old 02-08-2013, 01:13 PM   #2
NukeMiller
My Ride: 2005 325i
Was Autozone able to read your check engine codes?
NukeMiller is offline   Reply With Quote
Old 02-08-2013, 05:40 PM   #3
Jemmacandili
Yes codes are
P0444
P0440
P0313
P0344
Please help me thank you!
Old 02-08-2013, 06:11 PM   #4
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Outback
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
looks like a loose gas cap and a bad intake cam sensor.
VALMONT is offline   Reply With Quote
Old 02-09-2013, 11:02 PM   #5
NukeMiller
My Ride: 2005 325i
Originally Posted by Jemmacandili View Post
Yes codes are
P0444 - purge control valve failure
P0440 - Purge Valve Failure
P0313 - Running Lean
P0344 - Cam Position sensor
The purge valve is located on your cylinder head..access to it requires removing you intake filter box....
Bad Cam sensor is a bad cam sensor...P0334 is for the intake cam...replace with OEM and you should be fine...neither part should break your pocket book and are relatively easy to replace
Old 02-09-2013, 11:04 PM   #6
NukeMiller
My Ride: 2005 325i
I've had the loose gas cap and never recieved the purge valve error...I always got the EVAP small leak error...have you experienced different?
Old 02-09-2013, 11:58 PM   #7
Jemmacandili
I think I need to change camshaft sensor cause my car just shuts off by him self I think camshaft sensor is the reason. Can't give that electric power. Correct me I I'm wrong?
Old 02-10-2013, 12:21 AM   #8
NukeMiller
My Ride: 2005 325i
Yes..the camshaft sensor is definately the one turning your car off
Old 02-10-2013, 12:22 AM   #9
Jemmacandili
Yes cause my car is always shutting off by himself it always happens when I stopped then the engine is little but slower there's a big difference my mechanic told me its the camshaft sensor
