Go Back   E46Fanatics > E46 BMW > Regional Forums > Australia
Australia
Old 02-04-2013, 10:48 AM   #1
Commando
My Ride: 'O2 325Ci TiAg Man
F.S. {WA} M3 Starter Motor, Alternator, SMG, DME etc.
A few parts I've collected that are gathering dust.
Most of these parts are from an 89,000 km 2002 M3 and were working when removed.
All of these bits have been sitting around for 2 years.
Before I bung them on Ebay I thought I'd put them up here - its free and I prefer buying things here.
Any questions fire away.
If any prices are crazy high or low, please let me know.
M3 starter motor - not sure about other engines $100
M3 DME 2005 High Performance 64kB model to suit an SMG $350
M3 SMG Controller 2005? $150
Ignition Coil Harness $50
Idle Air Actuator, Evap Emissions Valve and hoses etc. $50
EDR Throttle drive $100
Getrag S6S420G with hydraulics and harness. Even the salmon relay?
I can separate these parts. I also have the engine harness.
Gearbox $700
Hydraulics $100
Harness $50
6 Speed Clutch - **Under offer**
Bluetooth $30
Cam sensor $30
Another cam sensor? $30
SMG Hydraulic Pump and Solenoids
There is 6 of these $30 each
Not Another sensor $30
Wow Another Sensor TPS $30
Ignition Switch Suits most models $30
Where is the machine for these? Ping sensors X 2 $30 each
Rear window motors for 2 doors $30 each
I like this piece. Pump is good, Left hand threads are good. I can separate the solenoids if that's all you need. Caps are gone. I need some if you have them.
P.S Its the VANOS.
Last edited by Commando; 02-10-2013 at 04:51 AM. Reason: added photos corrected typos - it was late ok.
Commando is offline   Reply With Quote
Old 02-09-2013, 02:21 AM   #2
Shuey168
My Ride: M3 e46
Clutch and Bluetooth
Hi mate
How much is the clutch ?
What is the Bluetooth for ? Can it integrate iPod ?
Cheers
I'm in Perth
Shuey168 is offline   Reply With Quote
Old 02-09-2013, 03:07 AM   #3
Commando
Hi Shuey - Its always good to know another local driver.
Somebody has said they will take the clutch seems genuine waiting on postage etc.
The bluetooth antenna is an OEM item . It has a FAKRA connector ad works with the phone. No idea about iPod.
What about a Mk IV Nav computer?
Cheers,
Rob
Old 02-09-2013, 03:18 AM   #4
selien
My Ride: 330CI
Send a message via ICQ to selien Send a message via AIM to selien Send a message via MSN to selien Send a message via Yahoo to selien Send a message via Skype™ to selien
will this gearbox setup fit in a 330?
selien is offline   Reply With Quote
Old 02-09-2013, 04:56 AM   #5
Commando
Will it fit? -yes it will -change the mounts and the tail shaft. Got a clutch?
Will the SMG work? - it can be done. This was my intention. I've got most of the parts you will need too but there are a few details that need to be sorted like running your car on the M3 DME as this controls the shifts. Saves finding a clutch pedal though.
Alternatively
If you have an auto then converting the box to manual and getting a clutch pedal may be your preferred option. I already have a 5 speed MT so for me the work involved going to 6 gears seemed unwarranted for normal road usage. Furthermore the 6 speed is 2X stronger than the 5 speed and better suited to the 3.0 motor.
FWIW There was an SMG I (SSG?) fitted to some non-M E46's. This was not the same. The gear I have for sale came from an E46 M3 and is SMG II.
Cheers
Old 02-09-2013, 11:27 PM   #6
Shuey168
My Ride: M3 e46
Hi Rob
Hope all is well
Will have to some research on the Bluetooth.. Can you tell me any more ?
I have a UUC light flywheel and clutch for sale if you know any one looking
Cheers Shuey
Old 02-10-2013, 12:11 AM   #7
Commando
Originally Posted by Shuey168 View Post
Hi Rob
Hope all is well
Cheers Shuey
ALL is well and so am I thank you.
About the BT Antenna the part nr. 6928461. It comes with the mounting bracket as pictured too.
I don't think there is anything wrong with the factory DM clutches unless you are making extraordinary horsepower and using it. I would also not recommend moving away from the OEM clutch if you have SMG and don't know how to set it up for the take-up characteristics of a different type of clutch.
Put a price on your UUC clutch so people know where you are coming from. Even eBay is moving towards fixed price sales.
Cheers, Rob
Old 02-10-2013, 02:38 PM   #8
Davconelectric
My Ride: 330
Do it
Davconelectric is offline   Reply With Quote
Old 05-10-2013, 10:38 PM   #9
willoug4
My Ride: E46 M3 Convertible
Used M3 DME For Sale
Is that DME still available?
willoug4 is offline   Reply With Quote
Old 05-11-2013, 12:56 PM   #10
Commando
Sure is. Its not from a 2002 M, I assume you knew that from the numbers.
